替换的字模文件如下:
字模文件里的前4字节:0x0c, 0x10, 0x30, 0x05,
前2个是字模大小,表示12×16的字体,
第3位是ASCII码,0x30是字符『0』,所以myGLCD.print("01234", 0, 0);显示『黄河入海流』。
第4位是字模数量,即使设错也影响不大。
[pre lang="arduino" line="1" file="myFonts.c"]#if defined(__AVR__)
#include <avr/pgmspace.h>
#define fontdatatype const uint8_t
#elif defined(__PIC32MX__)
#define PROGMEM
#define fontdatatype const unsigned char
#elif defined(__arm__)
#define PROGMEM
#endif
fontdatatype Hanzi16x16[] PROGMEM =
0x10, 0x10, 0x30, 0x05,
/*-- 文字: 白 --*/
/*-- 新宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
0x00,0x00,0xF8,0x08,0x08,0x0C,0x0A,0x09,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,0x00,
0x00,0x00,0xFF,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0xFF,0x00,0x00,0x00,
/*-- 文字: 日 --*/
0x00,0x00,0x00,0xFE,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0xFE,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xFF,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x00,0x00,0x00,0x00,
/*-- 文字: 依 --*/
0x00,0x80,0x60,0xF8,0x07,0x08,0x08,0xC8,0x39,0xCE,0x08,0x08,0x08,0x88,0x08,0x00,
0x01,0x00,0x00,0xFF,0x04,0x02,0x01,0xFF,0x40,0x21,0x06,0x0A,0x11,0x20,0x40,0x00,
/*-- 文字: 山 --*/
0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,
0x00,0x00,0x3F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x7F,0x00,0x00,0x00,
/*-- 文字: 尽 --*/
0x00,0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0x22,0xE2,0x22,0x22,0x7E,0x00,0x00,0x00,
0x10,0x08,0x06,0x01,0x10,0x10,0x22,0x22,0x44,0x80,0x01,0x02,0x04,0x08,0x08,0x00,
fontdatatype Hanzi12x16[] PROGMEM =
/*-- 文字: 黄 --*/
/*-- 新宋体9; 此字体下对应的点阵为:宽x高=12x12 --*/
/*-- 高度不是8的倍数,现调整为:宽度x高度=12x16 --*/
0x08,0xEA,0xAA,0xAF,0xAA,0xFA,0xAA,0xAF,0xAA,0xEA,0x08,0x00,0x00,0x0B,0x06,0x02,
0x02,0x03,0x02,0x02,0x06,0x0B,0x00,0x00,
/*-- 文字: 河 --*/
0x10,0x22,0x04,0x00,0xF2,0x12,0x12,0xF2,0x02,0xFE,0x02,0x00,0x04,0x02,0x01,0x00,
0x03,0x01,0x01,0x09,0x08,0x0F,0x00,0x00,
/*-- 文字: 入 --*/
0x00,0x00,0x01,0x81,0x72,0x0C,0x70,0x80,0x00,0x00,0x00,0x00,0x08,0x04,0x02,0x01,
0x00,0x00,0x00,0x01,0x02,0x04,0x08,0x00,
/*-- 文字: 海 --*/
0x11,0x22,0x48,0xC4,0x7B,0x4A,0x6A,0x4A,0x4A,0xFA,0x42,0x00,0x04,0x02,0x00,0x03,
0x02,0x02,0x03,0x0A,0x0A,0x07,0x02,0x00,
/*-- 文字: 流 --*/
0x22,0x44,0x00,0x24,0xB4,0x2C,0xA5,0x26,0xA4,0x34,0x64,0x00,0x04,0x02,0x08,0x04,
0x03,0x00,0x0F,0x00,0x07,0x08,0x0E,0x00,
[/code] |
