问题出在prtpage函数上,难道要考虑数组退化?
- * OLED_Arduino-3.0.ino
- * Created by Jack, April 5, 2015.
- * FUNCTION: This is a driver program to display some pics or words
- * on the OLED screen.
- * OLED INFORMATION:
- * 96` 128*64,
- * driver chip: SSD1306,
- * INTERFACE: 4-wire SPI.
- #define SDIN 9 //D1
- #define SCLK 10 //D0
- #define DC 11
- #define RST 13
- #define CS 12
- typedef struct insert {
- uint8_t page;
- uint8_t start;
- }insert;
- insert in = {0, 0};
- void OLED_INIT ();
- void w_cmd (uint8_t c);
- void w_data (uint8_t d);
- void clear_display ();
- void oprint (uint8_t w, insert *in);
- void oled_printf (char text[]);
- void prtpage (char c1[], char c2[], char c3[], char c4[]);
- // ASCII - buff
- uint8_t buff_0[2][8] = {
- 0xF0, 0xF8, 0x0C, 0xC4, 0x0C, 0xF8, 0xF0, 0x00,
- 0x03, 0x07, 0x0C, 0x08, 0x0C, 0x07, 0x03, 0x00
- uint8_t buff_1[2][8] = {
- 0x00, 0x10, 0x18, 0xFC, 0xFC, 0x00, 0x00, 0x00,
- 0x00, 0x08, 0x08, 0x0F, 0x0F, 0x08, 0x08, 0x00
- uint8_t buff_2[2][8] = {
- 0x08, 0x0C, 0x84, 0xC4, 0x64, 0x3C, 0x18, 0x00,
- 0x0E, 0x0F, 0x09, 0x08, 0x08, 0x0C, 0x0C, 0x00
- uint8_t buff_3[2][8] = {
- 0x08, 0x0C, 0x44, 0x44, 0x44, 0xFC, 0xB8, 0x00,
- 0x04, 0x0C, 0x08, 0x08, 0x08, 0x0F, 0x07, 0x00
- uint8_t buff_4[2][8] = {
- 0xC0, 0xE0, 0xB0, 0x98, 0xFC, 0xFC, 0x80, 0x00,
- 0x00, 0x00, 0x00, 0x08, 0x0F, 0x0F, 0x08, 0x00
- uint8_t buff_5[2][8] = {
- 0x7C, 0x7C, 0x44, 0x44, 0x44, 0xC4, 0x84, 0x00,
- uint8_t buff_6[2][8] = {
- 0xF0, 0xF8, 0x4C, 0x44, 0x44, 0xC0, 0x80, 0x00,
- 0x07, 0x07, 0x08, 0x08, 0x08, 0x0F, 0x07, 0x00
- uint8_t buff_7[2][8] = {
- 0x0C, 0x0C, 0x04, 0x84, 0xC4, 0x7C, 0x3C, 0x00,
- 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00
- uint8_t buff_8[2][8] = {
- 0xB8, 0xFC, 0x44, 0x44, 0x44, 0xFC, 0xB8, 0x00,
- 0x07, 0x0F, 0x08, 0x08, 0x08, 0x0F, 0x07, 0x00
- uint8_t buff_9[2][8] = {
- 0x38, 0x7C, 0x44, 0x44, 0x44, 0xFC, 0xF8, 0x00,
- 0x00, 0x08, 0x08, 0x08, 0x0C, 0x07, 0x03, 0x00
- uint8_t buff_a[2][8] = {
- 0x00, 0xA0, 0xA0, 0xA0, 0xE0, 0xC0, 0x00, 0x00,
- 0x07, 0x0F, 0x08, 0x08, 0x07, 0x0F, 0x08, 0x00
- uint8_t buff_b[2][8] = {
- 0x04, 0xFC, 0xFC, 0x20, 0x60, 0xC0, 0x80, 0x00,
- 0x00, 0x0F, 0x0F, 0x08, 0x08, 0x0F, 0x07, 0x00
- uint8_t buff_c[2][8] = {
- 0xC0, 0xE0, 0x20, 0x20, 0x20, 0x60, 0x40, 0x00,
- 0x07, 0x0F, 0x08, 0x08, 0x08, 0x0C, 0x04, 0x00
- uint8_t buff_d[2][8] = {
- 0x80, 0xC0, 0x60, 0x24, 0xFC, 0xFC, 0x00, 0x00,
- uint8_t buff_e[2][8] = {
- 0xC0, 0xE0, 0xA0, 0xA0, 0xA0, 0xE0, 0xC0, 0x00,
- uint8_t buff_f[2][8] = {
- 0x40, 0xF8, 0xFC, 0x44, 0x0C, 0x18, 0x00, 0x00,
- 0x08, 0x0F, 0x0F, 0x08, 0x00, 0x00, 0x00, 0x00
- uint8_t buff_g[2][8] = {
- 0xC0, 0xE0, 0x20, 0x20, 0xC0, 0xE0, 0x20, 0x00,
- 0x27, 0x6F, 0x48, 0x48, 0x7F, 0x3F, 0x00, 0x00
- uint8_t buff_h[2][8] = {
- 0x04, 0xFC, 0xFC, 0x40, 0x20, 0xE0, 0xC0, 0x00,
- 0x08, 0x0F, 0x0F, 0x00, 0x00, 0x0F, 0x0F, 0x00
- uint8_t buff_i[2][8] = {
- 0x00, 0x00, 0x20, 0xEC, 0xEC, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x08, 0x0F, 0x0F, 0x08, 0x00, 0x00
- uint8_t buff_j[2][8] = {
- 0x00, 0x00, 0x00, 0x00, 0x20, 0xEC, 0xEC, 0x00,
- 0x00, 0x30, 0x70, 0x40, 0x40, 0x7F, 0x3F, 0x00
- uint8_t buff_k[2][8] = {
- 0x04, 0xFC, 0xFC, 0x80, 0xC0, 0x60, 0x20, 0x00,
- 0x08, 0x0F, 0x0F, 0x01, 0x03, 0x0E, 0x0C, 0x00
- uint8_t buff_l[2][8] = {
- 0x00, 0x00, 0x04, 0xFC, 0xFC, 0x00, 0x00, 0x00,
- uint8_t buff_m[2][8] = {
- 0xE0, 0xE0, 0x60, 0xC0, 0x60, 0xE0, 0xC0, 0x00,
- 0x0F, 0x0F, 0x00, 0x07, 0x00, 0x0F, 0x0F, 0x00
- uint8_t buff_n[2][8] = {
- 0x20, 0xE0, 0xC0, 0x20, 0x20, 0xE0, 0xC0, 0x00,
- 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x0F, 0x0F, 0x00
- uint8_t buff_o[2][8] = {
- 0xC0, 0xE0, 0x20, 0x20, 0x20, 0xE0, 0xC0, 0x00,
- uint8_t buff_p[2][8] = {
- 0x40, 0x7F, 0x7F, 0x48, 0x08, 0x0F, 0x07, 0x00
- uint8_t buff_q[2][8] = {
- 0x07, 0x0F, 0x08, 0x48, 0x7F, 0x7F, 0x40, 0x00
- uint8_t buff_r[2][8] = {
- 0x20, 0xE0, 0xC0, 0x60, 0x20, 0xE0, 0xC0, 0x00,
- uint8_t buff_s[2][8] = {
- 0x40, 0xE0, 0xA0, 0x20, 0x20, 0x60, 0x40, 0x00,
- 0x04, 0x0C, 0x09, 0x09, 0x0B, 0x0E, 0x04, 0x00
- uint8_t buff_t[2][8] = {
- 0x20, 0x20, 0xF8, 0xFC, 0x20, 0x20, 0x00, 0x00,
- 0x00, 0x00, 0x07, 0x0F, 0x08, 0x0C, 0x04, 0x00
- uint8_t buff_u[2][8] = {
- 0xE0, 0xE0, 0x00, 0x00, 0xE0, 0xE0, 0x00, 0x00,
- uint8_t buff_v[2][8] = {
- 0x00, 0xE0, 0xE0, 0x00, 0x00, 0xE0, 0xE0, 0x00,
- 0x00, 0x03, 0x07, 0x0C, 0x0C, 0x07, 0x03, 0x00
- uint8_t buff_w[2][8] = {
- 0xE0, 0xE0, 0x00, 0x80, 0x00, 0xE0, 0xE0, 0x00,
- 0x07, 0x0F, 0x0C, 0x07, 0x0C, 0x0F, 0x07, 0x00
- uint8_t buff_x[2][8] = {
- 0x20, 0x60, 0xC0, 0x80, 0xC0, 0x60, 0x20, 0x00,
- 0x08, 0x0C, 0x07, 0x03, 0x07, 0x0C, 0x08, 0x00
- uint8_t buff_y[2][8] = {
- 0xE0, 0xE0, 0x00, 0x00, 0x00, 0xE0, 0xE0, 0x00,
- 0x47, 0x4F, 0x48, 0x48, 0x68, 0x3F, 0x1F, 0x00
- uint8_t buff_z[2][8] = {
- 0x60, 0x60, 0x20, 0xA0, 0xE0, 0x60, 0x20, 0x00,
- 0x0C, 0x0E, 0x0B, 0x09, 0x08, 0x0C, 0x0C, 0x00
- void setup (){
- OLED_INIT ();
- clear_display ();//一切好像总是等待那里,指向着同样的事情...
- void loop (){
- //prtpage ("", " but0n", "", "");
- //prtpage ("", " knowledge", " is", " power");
- //prtpage (" qq", "", " 32700567", "");
- //while (1){}
- void OLED_INIT (){
- pinMode (SDIN, OUTPUT);
- pinMode (SCLK, OUTPUT);
- pinMode (DC, OUTPUT);
- pinMode (RST, OUTPUT);
- pinMode (CS, OUTPUT);
- // You can find Initial Sequence on the datasheet
- digitalWrite (RST, HIGH); // Set RES# as High
- delay (1); // 3us Delay Recommended
- digitalWrite (RST, LOW); // Reset
- delay(10);
- w_cmd (0xAE); // 1.Set Display Off
- w_cmd (0xD5); // 2.Set display Clock Divide Ratio/Oscillator Frequency
- w_cmd (0x80);
- w_cmd (0xA8); // 3.Set Multiplex Ratio
- w_cmd (0x3F);
- w_cmd (0xD3); // 4.Set Display Offset
- w_cmd (0x00);
- w_cmd (0x40); // 5.Set Display Start Line
- // 6.Set Segment Re-Map 0xA1 ***
- // 7.Set COM Output Scan Direction 0xC8 ***
- // 8.Set COM Pins Hardware Configurartion 0xDA, 0x12 ***
- // 9.Set Contrast Control 0x81, 0x66 **^
- // 10.Set Pre-Charge Period 0xD9, 0xF1 ***
- // 11.Set VCOMH Deselect Level 0xDB, 0x30 **^
- // 12.Set Entire Display On/Off 0xA4 ***
- // 13.Set Normal/Inverse Display 0xA6 ***
- // Clear Screen
- // w_cmd (0x8D);// 14.Set Charge Pump
- // w_cmd (0x14);
- // 15.Set Display On 0xAF ***
- w_cmd (0x20);
- w_cmd (0x10); //0x00
- w_cmd (0xA1); // 6.Set Segment Re-Map
- w_cmd (0xC8); // 7.Set COM Output Scan Direction
- w_cmd (0xDA); // 8.Set COM Pins Hardware Configurartion
- w_cmd (0x12);
- w_cmd (0x81); // 9.Set Contrast Control 0x66
- w_cmd (0x66); // 0xCF
- w_cmd (0xD9); // 10.Set Pre-Charge Period
- w_cmd (0xF1);
- w_cmd (0xDB); // 11.Set VCOMH Deselect Level 0x30
- w_cmd (0x30); // 0x40
- w_cmd (0xA4); // 12.Set Entire Display On/Off
- w_cmd (0xA6); // 13.Set Normal/Inverse Display
- w_cmd (0x8D);// 14.Set Charge Pump
- w_cmd (0x14);
- w_cmd (0xAF); // 15.Set Display On
- void w_cmd (uint8_t c){
- digitalWrite (CS, HIGH);
- digitalWrite (DC, LOW); // Command
- digitalWrite (CS, LOW);
- shiftOut (SDIN, SCLK, MSBFIRST, c);
- void w_data (uint8_t d){
- digitalWrite (DC, HIGH); // Data
- shiftOut (SDIN, SCLK, MSBFIRST, d);
- void clear_display (){
- w_cmd (0xAE);
- in = {0, 0};
- uint8_t x, y; // x = SEG [0:127] y = PAGE [0:7]
- for (y = 0; y < 8; y++){
- w_cmd (0xB0 + y); // Set Page Number
- w_cmd (0x00); // Set Low (4bit)
- w_cmd (0x10); // Set High (4bit)
- for (x = 0; x<128; x++)
- w_data (0x00);
- w_cmd (0xAF);
- void oprint (uint8_t w, struct insert *in){
- if (in->page > 7 ){
- *in = {0, 0};
- delay (500);
- clear_display ();
- uint8_t t, n;
- for (t = 0; t < 2; t++){
- w_cmd (0xB0 + in->page + t);
- w_cmd (in->start & 0x0F);
- w_cmd (((in->start >> 4) & 0x0F) | 0x10);
- for (n = 0; n < 8; n++){
- switch (w){
- case '0':
- w_data (buff_0[t][n]);
- break;
- case '1':
- w_data (buff_1[t][n]);
- break;
- case '2':
- w_data (buff_2[t][n]);
- break;
- case '3':
- w_data (buff_3[t][n]);
- break;
- case '4':
- w_data (buff_4[t][n]);
- break;
- case '5':
- w_data (buff_5[t][n]);
- break;
- case '6':
- w_data (buff_6[t][n]);
- break;
- case '7':
- w_data (buff_7[t][n]);
- break;
- case '8':
- w_data (buff_8[t][n]);
- break;
- case '9':
- w_data (buff_9[t][n]);
- break;
- case 'a':
- w_data (buff_a[t][n]);
- break;
- case 'b':
- w_data (buff_b[t][n]);
- break;
- case 'c':
- w_data (buff_c[t][n]);
- break;
- case 'd':
- w_data (buff_d[t][n]);
- break;
- case 'e':
- w_data (buff_e[t][n]);
- break;
- case 'f':
- w_data (buff_f[t][n]);
- break;
- case 'g':
- w_data (buff_g[t][n]);
- break;
- case 'h':
- w_data (buff_h[t][n]);
- break;
- case 'i':
- w_data (buff_i[t][n]);
- break;
- case 'j':
- w_data (buff_j[t][n]);
- break;
- case 'k':
- w_data (buff_k[t][n]);
- break;
- case 'l':
- w_data (buff_l[t][n]);
- break;
- case 'm':
- w_data (buff_m[t][n]);
- break;
- case 'n':
- w_data (buff_n[t][n]);
- break;
- case 'o':
- w_data (buff_o[t][n]);
- break;
- case 'p':
- w_data (buff_p[t][n]);
- break;
- case 'q':
- w_data (buff_q[t][n]);
- break;
- case 'r':
- w_data (buff_r[t][n]);
- break;
- case 's':
- w_data (buff_s[t][n]);
- break;
- case 't':
- w_data (buff_t[t][n]);
- break;
- case 'u':
- w_data (buff_u[t][n]);
- break;
- case 'v':
- w_data (buff_v[t][n]);
- break;
- case 'w':
- w_data (buff_w[t][n]);
- break;
- case 'x':
- w_data (buff_x[t][n]);
- break;
- case 'y':
- w_data (buff_y[t][n]);
- break;
- case 'z':
- w_data (buff_z[t][n]);
- break;
- default:
- case ' ':
- w_data (0x00);
- break;
- } //switch
- }//for
- in->start += 8;
- if (in->start >= 128){
- in->start = 0;
- in->page += 2;
- void oled_printf(char text[]) {
- int c, q;
- for (c = 0; text[c] != NULL; c++)
- oprint (text[c], &in);
- for (q = 0; q < (16 - c); q++)
- oprint (' ', &in);
- void prtpage (char c1[], char c2[], char c3[], char c4[]) {
- w_cmd (0xAE);
- oled_printf (c1[], &in);
- oled_printf (c2[], &in);
- oled_printf (c3[], &in);
- oled_printf (c4[], &in);
- w_cmd (0xAF);
- delay (1200);
- clear_display ();
- delay (800);
复制代码 |
