查看: 15250|回复: 5
AD9850模块程序问题
发表于 2015-5-13 15:47:13 | 显示全部楼层 |阅读模式
从网上找了一段用AD9850模块做信号发生器的代码,出现了
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
求教各位大神这个问题,怎么解决。
下面是原代码
**  Device: AD9850/9851                                             **
**  File:   EF_AD9850.cpp v1.2                  **
**  Created by ElecFreaks Robi.W /28 Oct 2011                       **
**  Description:                                                    **
**  This file is a sample code for your reference.About AD9850/9851 **
**  module use on Arduino with serial mode. And then show the       **
**  square wave and sine wave by LXARDOSCOPE which is an free       **
**  Arduino based oscilloscope Linux, using the Xforms library.     **
**  Note:This library just Serial mode for AD9850                   **
**  This demo code is free software; you can redistribute it and/or **
**  modify it under the terms of the GNU Lesser General Public      **
**  License as published by the Free Software Foundation; either    **
**  version 2.1 of the License, or (at your option)           **
**  any later version.                **
**  Copyright (C) 2011 ElecFreaks Corp.                           **
**  http://www.elecfreaks.com                                       **
#include <EF_AD9850.h>
//Define for LXARDOSCOPE
int sensorValue = 0;        // value read from the pot
byte lb;
byte hb;
//BitData - D8, CLK - D9, FQUP - D10, REST - D11
EF_AD9850 AD9850(9, 10, 11, 8);
  AD9850.init();
  AD9850.reset();
  AD9850.wr_serial(0x00, 200); //200Hz
  // initialize serial communications at 115200 bps:
  Serial.begin(115200);
void loop(){
  // read A0:
  sensorValue = analogRead(A0);
// shift sample by 3 bits, and select higher byte
  hb=highByte(sensorValue<<3);
// set 3 most significant bits and send out
  Serial.print(hb|224,BYTE);
// select lower byte and clear 3 most significant bits
  lb=(lowByte(sensorValue))&31;
// set bits 5 and 6 and send out
  Serial.print(lb|96,BYTE);
// read A1
  sensorValue = analogRead(A1);
  Serial.print(hb|96,BYTE);
发表于 2015-5-13 19:26:05 | 显示全部楼层
版本问题,BYTE该关键字不支持
 楼主| 发表于 2015-5-14 14:29:33 | 显示全部楼层
suoma 发表于 2015-5-13 19:26
版本问题,BYTE该关键字不支持
那怎么改呢?
发表于 2015-5-15 10:23:35 | 显示全部楼层
剑门细雨 发表于 2015-5-14 14:29
那怎么改呢?
换成1.0之前的试一下
发表于 2015-5-15 10:24:36 | 显示全部楼层
应该有相关键字替代,我没用过byte,char行不行?
 楼主| 发表于 2015-5-15 17:09:44 | 显示全部楼层
我又从其他网站新找了一段新代码解决了,多谢了。
GMT+8, 2024-5-20 07:36 , Processed in 0.067010 second(s), 20 queries .
