查看: 8117|回复: 2
三个按键外加一个串口程序问题
发表于 2015-7-4 16:10:09 | 显示全部楼层 |阅读模式
用三个按键来做上、下、确定按钮,并将现在的数值通过串口打印出来。
但是这个程序调试了半天都没调出来,哪位能否帮忙看一下?
程序代码如下:
  1. int choose_UP_pin = 2;
  2. int choose_DOWN_pin = 3;
  3. int ENTER_pin = 4;
  4. int State_Key = 1;
  5. boolean choose_UP = LOW;
  6. boolean choose_DOWN = LOW;
  7. boolean ENTER = LOW;
  8. void setup() {
  9.   // put your setup code here, to run once:
  10.   Serial.begin(9600);
  11.   pinMode(choose_UP_pin,INPUT);
  12.   pinMode(choose_DOWN_pin,INPUT);
  13.   pinMode(ENTER_pin,INPUT);
  14. }
  15. void loop() {
  16.   // put your main code here, to run repeatedly:
  17. choose_UP = digitalRead(choose_UP_pin);
  18.   if(choose_UP == HIGH)
  19.   {
  20.     State_Key++;
  21.     if(State_Key == 11)
  22.     {
  23.       State_Key = 1;
  24.     }
  25.     while(digitalRead(choose_UP_pin) == HIGH);
  26.   }
  27.   choose_DOWN = digitalRead(choose_DOWN_pin);
  28.   if(choose_DOWN == HIGH)
  29.   {
  30.     State_Key--;
  31.     if(State_Key == 0)
  32.     {
  33.       State_Key = 10;
  34.     }
  35.     while(digitalRead(choose_DOWN_pin) == HIGH);
  36.   }
  37.   ENTER = digitalRead(ENTER_pin);
  38.   if(ENTER == HIGH)
  39.   {
  40.     Serial.write(State_Key);
  41.     while(digitalRead(ENTER_pin) == HIGH);
  42.   }
  43. }
发表于 2015-7-4 21:40:32 | 显示全部楼层
感觉程序没问题啊。检查一下电路吧
发表于 2015-8-11 23:01:24 | 显示全部楼层
初学者学习
GMT+8, 2024-4-26 17:16 , Processed in 0.057689 second(s), 19 queries .
