查看: 10375|回复: 1
贡献开源的位操作函数
发表于 2012-9-22 18:09:15 | 显示全部楼层 |阅读模式
[pre lang="C" line="1"]/* This Source Code Form is subject to the terms of the Mozilla Public
* License, v. 2.0. If a copy of the MPL was not distributed with this
* file, You can obtain one at http://mozilla.org/MPL/2.0/. */
uint64_t read_bit (uint64_t source_bits, uint_fast8_t source_width, uint_fast8_t n)  //Lowest order is 0
  const uint_fast8_t MAXIMUM_WIDTH_BIT = 64;
  if ((source_bits >> source_width) not_eq 0)
    return source_bits;
  if (source_width > MAXIMUM_WIDTH_BIT)
    return source_bits;
  if (n >= source_width)
    return source_bits;
  return (source_bits >> n) bitand ((uint64_t)0x01);
uint64_t write_bit (uint64_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
    return source_bits;
    return source_bits;
    return source_bits;
  if ((a_bit >> 1) not_eq 0)
    return source_bits;
  (a_bit == 0) ? (source_bits and_eq (compl(((uint64_t)0x01) << n))) : (source_bits or_eq (((uint64_t)0x01) << n));
  return source_bits;
uint64_t xor_bit (uint64_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
    return source_bits;
    return source_bits;
    return source_bits;
    return source_bits;
  return source_bits xor (((uint64_t)a_bit) << n);
}[/code]
纯C11草案标准写的
加了输入参数范围检查
有什么使用问题欢迎留言
 楼主| 发表于 2012-10-13 02:45:56 | 显示全部楼层
为更方便大家应用,变更了开源许可证
GMT+8, 2024-6-3 15:20 , Processed in 0.039769 second(s), 17 queries .
