查看: 9041|回复: 0
参考迷你强的中断教程以后 步进电机还是会动
发表于 2012-11-26 16:58:10 | 显示全部楼层 |阅读模式
线路也跟迷你强接的一模一样 按钮处也加了上拉电阻   当按钮按下时 步进电机还是转 只是转的极慢而已 板子用的是arduino duemilanove 中断教程的地址:http://www.geek-workshop.com/thread-1983-1-1.html
  1. int pbIn = 0;                  // 定义中断引脚为0,也就是D2引脚
  2. int ledOut = A0;                // 定义输出指示灯引脚
  3. volatile int state = LOW;      // 定义默认输入状态
  4. #define DIR_PIN_Y 4
  5. #define STEP_PIN_Y 5
  6. void setup()
  7. {
  8.   pinMode(DIR_PIN_Y, OUTPUT);
  9.   pinMode(STEP_PIN_Y, OUTPUT);
  10.   // 置ledOut引脚为输出状态
  11.   pinMode(ledOut, OUTPUT);
  12.   // 监视中断输入引脚的变化
  13.   attachInterrupt(pbIn, stateChange, LOW);
  14. }
  15. void loop()
  16. {
  17.   // 模拟长时间运行的进程或复杂的任务。
  18.   for (int i = 0; i < 100; i++)
  19. {rotateDeg_Y(i,1);
  20. delay(2000);}
  21. }
  22. void stateChange()
  23. {
  24.   state = HIGH;
  25.   digitalWrite(ledOut, state);
  26. }
  27. void rotateDeg_Y(float deg, float speed){
  28.   //rotate a specific number of degrees (negitive for reverse movement)
  29.   //speed is any number from .01 -> 1 with 1 being fastest - Slower is stronger
  30.   int dir = (deg > 0)? LOW:HIGH;
  31.   digitalWrite(DIR_PIN_Y,dir);
  32.   unsigned int steps = abs(deg)/(0.003125);
  33.   float usDelay = (1/speed) * 80;
  34.   for(int i=0; i < steps; i++){
  35.     digitalWrite(STEP_PIN_Y, HIGH);
  36.     delayMicroseconds(usDelay);
  37.     digitalWrite(STEP_PIN_Y, LOW);
  38.     delayMicroseconds(usDelay);
  39.   }
  40. }
GMT+8, 2024-5-2 19:05 , Processed in 0.044831 second(s), 17 queries .
