先看下笔者的XML协议描述:- <?xml version="1.0" encoding="utf-8"?>
- <metalib>
- <macro name="HEAD_SIZE" value="3" />
- <macro name="MAX_BUFFER_SIZE" value="60" />
- <macro name="FORWARD_DIR" value="0" />
- <macro name="BACKWARD_DIR" value="1" />
- <macro name="STOP_DIR" value="2" />
- <macro name="PWM_ENA_PIN" value="3" />
- <macro name="PWM_ENB_PIN" value="5" />
- <macro name="PWM_IN1_PIN" value="8" />
- <macro name="PWM_IN2_PIN" value="7" />
- <macro name="PWM_IN3_PIN" value="12" />
- <macro name="PWM_IN4_PIN" value="11" />
- <macro name="LINE_MOVE_CMD" value="100" />
- <macro name="MOVE_CMD" value="101" />
- <struct name="LineMove">
- <field name="dir" type="uchar" />
- <field name="speed" type="uchar" />
- </struct>
- <struct name="Move">
- <field name="left_dir" type="uchar" />
- <field name="left_speed" type="uchar" />
- <field name="right_dir" type="uchar" />
- <field name="right_speed" type="uchar" />
- </struct>
- <struct name="Head">
- <field name="cmd" type="uchar" />
- <field name="body_len" type="ushort" />
- </struct>
- </metalib>
复制代码 通过gencode.exe程序生成的代码:
proto.h- /*This head file is generated by code. Please do not edit!*/
- #ifndef proto_H
- #define proto_H
- #ifdef __cplusplus
- extern "C" {
- #endif
- #define HEAD_SIZE 3
- #define MAX_BUFFER_SIZE 60
- #define FORWARD_DIR 0
- #define BACKWARD_DIR 1
- #define STOP_DIR 2
- #define PWM_ENA_PIN 3
- #define PWM_ENB_PIN 5
- #define PWM_IN1_PIN 8
- #define PWM_IN2_PIN 7
- #define PWM_IN3_PIN 12
- #define PWM_IN4_PIN 11
- #define LINE_MOVE_CMD 100
- #define MOVE_CMD 101
- #pragma pack(1)
- typedef struct {
- unsigned char dir;
- unsigned char speed;
- }LineMove;
- extern inline int serialize_LineMove(LineMove *linemove, void *buffer, const int offset);
- extern inline int deserialize_LineMove(void *buffer, LineMove *linemove, const int offset);
- typedef struct {
- unsigned char left_dir;
- unsigned char left_speed;
- unsigned char right_dir;
- unsigned char right_speed;
- }Move;
- extern inline int serialize_Move(Move *move, void *buffer, const int offset);
- extern inline int deserialize_Move(void *buffer, Move *move, const int offset);
- typedef struct {
- unsigned char cmd;
- unsigned short body_len;
- }Head;
- extern inline int serialize_Head(Head *head, void *buffer, const int offset);
- extern inline int deserialize_Head(void *buffer, Head *head, const int offset);
- static int serialize(void *stru, void *buffer, int size, const int offset);
- static int deserialize(void *buffer, void *stru, int size, const int offset);
- #pragma pack()
- #endif
- #endif
复制代码 proto.c- /*This source file is generated by code. Please do not edit!*/
- #include "proto.h"
- char *p_stru = (char *)stru;
- char *p_buffer = (char *)(buffer + offset);
- while(*p_buffer++ = *p_stru++, size--);
- return size + offset;
- while(*p_stru++ = *p_buffer++, size--);
- inline int serialize_LineMove(LineMove *linemove, void *buffer, const int offset)
- return serialize(linemove, buffer, sizeof(*linemove), offset);
- inline int deserialize_LineMove(void *buffer, LineMove *linemove, const int offset)
- return deserialize(buffer, linemove, sizeof(*linemove), offset);
- inline int serialize_Move(Move *move, void *buffer, const int offset)
- return serialize(move, buffer, sizeof(*move), offset);
- inline int deserialize_Move(void *buffer, Move *move, const int offset)
- return deserialize(buffer, move, sizeof(*move), offset);
- inline int serialize_Head(Head *head, void *buffer, const int offset)
- return serialize(head, buffer, sizeof(*head), offset);
- inline int deserialize_Head(void *buffer, Head *head, const int offset)
- return deserialize(buffer, head, sizeof(*head), offset);
复制代码 下面是使用以上生成代码的Arduino主文件sample.ino- /** 示例
- By Apache([email protected]) 2012/11/30
- #define SET_LEFT_PWM(SPEED) analogWrite(PWM_ENB_PIN, (SPEED))
- #define SET_RIGHT_PWM(SPEED) analogWrite(PWM_ENA_PIN, (SPEED))
- #define SET_DIR(DIR, XPIN, YPIN) \
- do { \
- if(DIR != STOP_DIR) {\
- digitalWrite(XPIN, (DIR)); \
- digitalWrite(YPIN, !(DIR)); \
- }else {\
- digitalWrite(XPIN, 0); \
- digitalWrite(YPIN, 0); \
- }while(0)
- #define SET_LEFT_DIR(DIR) SET_DIR(DIR, PWM_IN3_PIN, PWM_IN4_PIN)
- #define SET_RIGHT_DIR(DIR) SET_DIR(DIR, PWM_IN1_PIN, PWM_IN2_PIN)
- #define SET_MOTOR(LSPD, LDIR, RSPD, RDIR) \
- do { \
- SET_LEFT_PWM((LSPD)); \
- SET_RIGHT_PWM((RSPD)); \
- SET_LEFT_DIR((LDIR)); \
- SET_RIGHT_DIR((RDIR)); \
- }while(0)
- static uint8_t waiting_head = 1;
- static Head head;
- void init_pin()
- uint8_t outputs[] = {
- PWM_ENA_PIN, PWM_IN1_PIN, PWM_IN2_PIN,
- PWM_ENB_PIN, PWM_IN3_PIN, PWM_IN4_PIN };
- uint8_t inputs[] = {};
- uint8_t i, ocnt = sizeof(outputs), icnt = sizeof(inputs);
- for(i = 0; i < ocnt; i++) {
- pinMode(outputs[i], OUTPUT);
- for(i = 0; i < icnt; i++) {
- pinMode(inputs[i], INPUT);
- void setup()
- Serial.begin(9600);
- init_pin();
- void on_line_move(uint8_t *buffer)
- LineMove linemove;
- deserialize_LineMove(buffer, &linemove, 0);
- SET_MOTOR(linemove.speed, linemove.dir, linemove.speed, linemove.dir);
- void on_move(uint8_t *buffer)
- Move move;
- deserialize_Move(buffer, &move, 0);
- SET_MOTOR(move.left_speed, move.left_dir, move.right_speed, move.right_dir);
- void proto_process(uint32_t cmd, uint8_t *buffer)
- switch(cmd) {
- case LINE_MOVE_CMD:
- on_line_move(buffer);
- break;
- case MOVE_CMD:
- on_move(buffer);
- break;
- default:
- break;
- void recv_package()
- int nbytes;
- uint8_t buffer[MAX_BUFFER_SIZE] = "";
- nbytes = Serial.available();
- if(waiting_head) {
- if(nbytes >= HEAD_SIZE) {
- Serial.readBytes((char *)buffer, HEAD_SIZE);
- deserialize_Head(buffer, &head, 0);
- waiting_head = 0;
- else {
- if(nbytes >= head.body_len) {
- Serial.readBytes((char *)buffer, head.body_len);
- proto_process(head.cmd, buffer);
- waiting_head = 1;
- void loop()
- recv_package();
复制代码 下面是自动生成的python代码:
proto.py- #-*- coding: utf-8 -*-
- # This script is generated by code. Please do not edit!
- from struct import pack, unpack
- PACK_TYPE_DICT = {
- "char": ("b", 1),
- "uchar": ("B", 1),
- "short": ("h", 2),
- "ushort": ("H", 2),
- "int": ("i", 4),
- "uint": ("I", 4),
- "long": ("l", 4),
- "ulong": ("L", 4),
- "longlong": ("q", 8),
- "ulonglong": ("Q", 8),
- "float": ("f", 4),
- "double": ("d", 8),
- class Codec:
- @classmethod
- def serialize(self, obj):
- __buffer = []
- for field_pktype in obj._field_pktype:
- field, pktype = field_pktype[0], PACK_TYPE_DICT[field_pktype[1]][0]
- value = obj.__dict__.get(field)
- if not value: value = 0
- __buffer.append(pack(pktype, value))
- return ''.join(__buffer)
- @classmethod
- def deserialize(self, obj, buffer):
- offset = 0
- field = field_pktype[0]
- pktype, size = PACK_TYPE_DICT[field_pktype[1]]
- obj.__dict__[field] = unpack(pktype, buffer[offset: offset + size])[0]
- offset += size
- return offset
- class MetaClass(type):
- def __init__(cls, name, bases, dict):
- def _init(cls, **_dict):
- for field, val in _dict.items():
- setattr(cls, field, val)
- def _serialize(cls, **args):
- return dict["_codec"].serialize(cls, **args)
- def _deserialize(cls, buffer, **args):
- return dict["_codec"].deserialize(cls, buffer, **args)
- for field, _ in dict["_fields"]:
- setattr(cls, field, None)
- setattr(cls, "__init__", _init)
- setattr(cls, "_field_pktype", dict["_fields"])
- setattr(cls, "serialize", _serialize)
- setattr(cls, "deserialize", _deserialize)
- delattr(cls, "_fields")
- delattr(cls, "_codec")
- super(MetaClass, cls).__init__(name, bases, dict)
- HEAD_SIZE = 3
- MAX_BUFFER_SIZE = 60
- FORWARD_DIR = 0
- BACKWARD_DIR = 1
- STOP_DIR = 2
- PWM_ENA_PIN = 3
- PWM_ENB_PIN = 5
- PWM_IN1_PIN = 8
- PWM_IN2_PIN = 7
- PWM_IN3_PIN = 12
- PWM_IN4_PIN = 11
- LINE_MOVE_CMD = 100
- MOVE_CMD = 101
- LineMove = MetaClass(
- name="LineMove",
- bases=(),
- dict=dict(
- _codec=Codec,
- _fields=(
- (u'dir', u'uchar'),
- (u'speed', u'uchar')
- Move = MetaClass(
- name="Move",
- bases=(),
- dict=dict(
- _codec=Codec,
- _fields=(
- (u'left_dir', u'uchar'),
- (u'left_speed', u'uchar'),
- (u'right_dir', u'uchar'),
- (u'right_speed', u'uchar')
- Head = MetaClass(
- name="Head",
- bases=(),
- dict=dict(
- _codec=Codec,
- _fields=(
- (u'cmd', u'uchar'),
- (u'body_len', u'ushort')
复制代码 烧进去代码的后,我使用上面的py文件写了一个测试脚本:
test_proto.py- #-*- coding: utf-8 -*-
- #示例, 测试LineMove协议
- #By Apache([email protected]) 2012/11/20
- import sys
- try:
- import serial
- except ImportError:
- print "Import serial error"
- sys.exit(1)
- import proto
- from time import sleep
- COM = "COM3"
- BAUND=9600
- print u"正在打开串口..."
- try:
- ser = serial.Serial(COM, BAUND)
- sleep(2)
- except Exception, e:
- print e
- sys.exit(1)
- print u"已打开, 开始协议测试..."
- class TestLineMove:
- def __init__(self):
- self.head = proto.Head(cmd=proto.LINE_MOVE_CMD)
- self.body = proto.LineMove()
- def __sendpkg(self):
- body_buffer = self.body.serialize()
- self.head.body_len = len(body_buffer)
- head_buffer = self.head.serialize()
- ser.write("%s%s" % (head_buffer, body_buffer))
- def __line_move(self, msg, dir=0, speed=100, t=2):
- self.body.dir = dir
- self.body.speed = speed
- print msg
- self.__sendpkg()
- sleep(t)
- def test(self):
- print u"LineMove协议测试"
- self.__line_move(u"低速前进两秒", dir=0, speed=100, t=2)
- self.__line_move(u"高速前进两秒", dir=0, speed=200, t=2)
- self.__line_move(u"低速后退两秒", dir=1, speed=100, t=2)
- self.__line_move(u"高速后退两秒", dir=1, speed=200, t=2)
- self.__line_move(u"停止", dir=2, speed=0, t=0)
- if __name__ == "__main__":
- TestLineMove().test()
- ser.close()
复制代码 运行该脚本,测试效果良好,以后可以不用总是发ASCII码了……
下面是gencode的使用帮助:
更多的详细说明和示例代码见附件:
