查看: 11365|回复: 1
自平衡车,卡尔曼滤波
发表于 2016-8-9 16:19:47 | 显示全部楼层 |阅读模式
我用printf("%0.2f    %0.2f    %0.2f\r\n",Angle,Angle_ax,Gyro_y);函数分别读取的加速度,角速度和倾角,我发现当我快速的改变板子的倾角的时候,比如快速变化10度,Angle(卡尔曼滤波后的倾角)瞬时变化非常快,可能会瞬间变化几十度然后回到正常角度,而当我缓慢变化10度的时候,Angle变化是正常线性变化到10度,在这两种变化中,Angle_ax(从MPU6050读取的值经过处理后的陀螺仪的Y轴数据)的变化一直都是线性正常的,并且Angle的值特别接近Angle_ax的值
问题:1,我快速改变板子倾角时Angle的变化正常吗?
      2,Angle正常变化的时候是应该与Angle_ax的值相近吗?
*************读取数据********************
//定义MPU6050内部地址
#define        SMPLRT_DIV                0x19        //陀螺仪采样率 典型值 0X07 125Hz
#define        CONFIG                          0x1A        //低通滤波频率 典型值 0x00
#define        GYRO_CONFIG                0x1B        //陀螺仪自检及测量范围                 典型值 0x18 不自检 2000deg/s
#define        ACCEL_CONFIG        0x1C        //加速度计自检及测量范围及高通滤波频率 典型值 0x01 不自检 2G 5Hz
#define INT_PIN_CFG     0x37
#define INT_ENABLE      0x38
#define INT_STATUS      0x3A    //只读
#define        ACCEL_XOUT_H        0x3B
#define        ACCEL_XOUT_L        0x3C
#define        ACCEL_YOUT_H        0x3D
#define        ACCEL_YOUT_L        0x3E
#define        ACCEL_ZOUT_H        0x3F
#define        ACCEL_ZOUT_L        0x40
#define        TEMP_OUT_H                0x41
#define        TEMP_OUT_L                0x42
#define        GYRO_XOUT_H    0x43
#define        GYRO_XOUT_L                0x44
#define        GYRO_YOUT_H        0x45
#define        GYRO_YOUT_L                0x46
#define        GYRO_ZOUT_H        0x47
#define        GYRO_ZOUT_L                0x48
//读取寄存器原生数据
        MPU6050_Raw_Data.Accel_X = (buf[0]<<8 | buf[1]);
        MPU6050_Raw_Data.Accel_Y = (buf[2]<<8 | buf[3]);
        MPU6050_Raw_Data.Accel_Z = (buf[4]<<8 | buf[5]);
        MPU6050_Raw_Data.Temp =    (buf[6]<<8 | buf[7]);
        MPU6050_Raw_Data.Gyro_X = (buf[8]<<8 | buf[9]);
        MPU6050_Raw_Data.Gyro_Y = (buf[10]<<8 | buf[11]);
        MPU6050_Raw_Data.Gyro_Z = (buf[12]<<8 | buf[13]);
        //将原生数据转换为实际值,计算公式跟寄存器的配置有关
        MPU6050_Real_Data.Accel_X = -(float)(MPU6050_Raw_Data.Accel_X)/8192.0;
        MPU6050_Real_Data.Accel_Y = -(float)(MPU6050_Raw_Data.Accel_Y)/8192.0;
        MPU6050_Real_Data.Accel_Z = (float)(MPU6050_Raw_Data.Accel_Z)/8192.0;
              MPU6050_Real_Data.Gyro_X=-(float)(MPU6050_Raw_Data.Gyro_X - gyroADC_X_offset)/65.5;
        MPU6050_Real_Data.Gyro_Y=-(float)(MPU6050_Raw_Data.Gyro_Y - gyroADC_Y_offset)/65.5;
        MPU6050_Real_Data.Gyro_Z=(float)(MPU6050_Raw_Data.Gyro_Z - gyroADC_Z_offset)/65.5;
//******卡尔曼参数************
const float Q_angle=0.001;
const float Q_gyro=0.003;
const float R_angle=0.5;
const float dt=0.01;                          //dt为kalman滤波器采样时间;
const char  C_0 = 1;
float Q_bias, Angle_err;
float PCt_0, PCt_1, E;
float K_0, K_1, t_0, t_1;
float Pdot[4] ={0,0,0,0};
float PP[2][2] = { { 1, 0 },{ 0, 1 } };
/*****************卡尔曼滤波**************************************************/
void Kalman_Filter(float Accel,float Gyro)
        Angle+=(Gyro - Q_bias) * dt; //先验估计
        Pdot[0]=Q_angle - PP[0][1] - PP[1][0]; // Pk-先验估计误差协方差的微分
        Pdot[1]= -PP[1][1];
        Pdot[2]= -PP[1][1];
        Pdot[3]=Q_gyro;
        PP[0][0] += Pdot[0] * dt;   // Pk-先验估计误差协方差微分的积分
        PP[0][1] += Pdot[1] * dt;   // =先验估计误差协方差
        PP[1][0] += Pdot[2] * dt;
        PP[1][1] += Pdot[3] * dt;
        Angle_err = Accel - Angle;        //zk-先验估计
        PCt_0 = C_0 * PP[0][0];
        PCt_1 = C_0 * PP[1][0];
        E = R_angle + C_0 * PCt_0;
        K_0 = PCt_0 / E;
        K_1 = PCt_1 / E;
        t_0 = PCt_0;
        t_1 = C_0 * PP[0][1];
        PP[0][0] -= K_0 * t_0;                 //后验估计误差协方差
        PP[0][1] -= K_0 * t_1;
        PP[1][0] -= K_1 * t_0;
        PP[1][1] -= K_1 * t_1;
        Angle        += K_0 * Angle_err;         //后验估计
        Q_bias        += K_1 * Angle_err;         //后验估计
        Gyro_y   = Gyro - Q_bias;         //输出值(后验估计)的微分=角速度
******************倾角计算*****************
void Angle_Calculate(void)
/****************************加速度****************************************/
        Accel_x  =  MPU6050_Real_Data.Accel_X;          //读取X轴加速度
        Angle_ax = Accel_x*1.2*180/3.14;     //弧度转换为度
/****************************角速度****************************************/
         Gyro_y = MPU6050_Real_Data.Gyro_Y;
时间dt,所以此处不用积分
/***************************卡尔曼融合*************************************/
        Kalman_Filter(Angle_ax,Gyro_y);       //卡尔曼滤波计算倾角
 楼主| 发表于 2016-8-9 18:11:10 | 显示全部楼层
现在情况就是,就算我是在减小倾角,只要我快速地改变,它显示的倾角都会先增大再减小,而如果我慢速改变的话,倾角就会缓慢减小而不会出现那些增大的角
GMT+8, 2024-5-3 19:32 , Processed in 0.037639 second(s), 18 queries .
