楼主 |
发表于 2012-12-17 08:40:10
显示全部楼层
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <math.h>
int BH1750address = 0x23;
byte buff[2];
// for yeelink api
#define APIKEY "0**********************e15" // 这里用您的yeelink API key替换
#define DEVICEID 1299 // 这就是您yeelink网站上的设备号,请参见Yeelink平台手册获取
#define SENSORID 1643 // 这个更换成您的传感器号码,如何取得请参阅Yeelinkreplace your sensor ID
// assign a MAC address for the ethernet controller.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// initialize the library instance:
EthernetClient client;
//char server[] = "api.yeelink.net"; // yeelink API 的服务器名称
IPAddress server(202,136,60,231); // 这里填的是yeelink平台的入口服务器IP
unsigned long lastConnectionTime = 0; // 上次连接到服务器的时间,毫秒
boolean lastConnected = false; // 上次连接状态
const unsigned long postingInterval = 30*1000; // 默认发送间隔30秒
Wire.begin();
// start serial port:
Serial.begin(57600);
// start the Ethernet connection with DHCP:
if (Ethernet.begin(mac) == 0) {
for(;;)
else {
Serial.println("Ethernet configuration OK");
// if there's incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected) {
Serial.println();
client.stop();
// if you're not connected, and ten seconds have passed since
// your last connection, then connect again and send data:
if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
// read sensor data, replace with your code
int sensorReading = readLightSensor();
//send data to server
sendData(sensorReading);
// store the state of the connection for next time through
// the loop:
lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void sendData(int thisData) {
// if there's a successful connection:
if (client.connect(server, 80)) {
// send the HTTP PUT request:
client.print("POST /v1.0/device/");
client.print(DEVICEID);
client.print("/sensor/");
client.print(SENSORID);
client.print("/datapoints");
client.println(" HTTP/1.1");
client.println("Host: api.yeelink.net");
client.print("Accept: *");
client.print("/");
client.println("*");
client.print("U-ApiKey: ");
client.println(APIKEY);
client.print("Content-Length: ");
// calculate the length of the sensor reading in bytes:
// 8 bytes for {"value":} + number of digits of the data:
int thisLength = 10 + getLength(thisData);
client.println(thisLength);
client.println("Content-Type: application/x-www-form-urlencoded");
client.println("Connection: close");
client.println();
// here's the actual content of the PUT request:
client.print("{\"value\":");
client.print(thisData);
client.println("}");
else {
// if you couldn't make a connection:
Serial.println();
client.stop();
// note the time that the connection was made or attempted:
// This method calculates the number of digits in the
// sensor reading. Since each digit of the ASCII decimal
// representation is a byte, the number of digits equals
// the number of bytes:
int getLength(int someValue) {
// there's at least one byte:
int digits = 1;
// continually divide the value by ten,
// adding one to the digit count for each
// time you divide, until you're at 0:
int dividend = someValue /10;
while (dividend > 0) {
dividend = dividend /10;
digits++;
// return the number of digits:
return digits;
// 获取光纤传感器的读书,可以把这部分替换掉,换成你自己的传感器
int readLightSensor()
uint16_t val=0;
BH1750_Init(BH1750address);
delay(200);
if(2==BH1750_Read(BH1750address))
val=((buff[0]<<8)|buff[1])/1.2;
Serial.print("Sensor value is: ");
Serial.println((int)val);
return val;
int BH1750_Read(int address) //
int i=0;
Wire.beginTransmission(address);
Wire.requestFrom(address, 2);
while(Wire.available()) //
buff[i] = Wire.read(); // receive one byte
i++;
Wire.endTransmission();
return i;
void BH1750_Init(int address)
Wire.write(0x10);//1lx reolution 120ms
