查看: 20854|回复: 10
打开LabVIEWInterface例程报错,求助
发表于 2016-12-22 13:31:43 | 显示全部楼层 |阅读模式
安装了Labview软件和labview interface for arduino,打开LabVIEWInterface例程,编译报错如下,
报错信息
  1.   This report would have more information with
  2.   "Show verbose output during compilation"
  3.   enabled in File > Preferences.
  4. Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
  5. In file included from LabVIEWInterface.ino:20:
  6. D:\Arduino\libraries\RobotIRremote/IRremoteInt.h:187: error: 'RAWBUF' was not declared in this scope
  7. LabVIEWInterface:95: error: [color=Red]expected constructor, destructor, or type conversion before '*' token[/color]
  8. LabVIEWInterface:99: error: 'IRsend' does not name a type
  9. LabVIEWInterface.ino: In function 'int checkForCommand()':
  10. LabVIEWInterface:119: error: 'COMMANDLENGTH' was not declared in this scope
  11. LabVIEWInterface:125: error: 'currentCommand' was not declared in this scope
  12. LabVIEWInterface:127: error: 'currentCommand' was not declared in this scope
  13. LabVIEWInterface:127: error: 'processCommand' was not declared in this scope
  14. LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)':
  15. LabVIEWInterface:140: error: 'checksum_Test' was not declared in this scope
  16. LabVIEWInterface:167: error: 'writeDigitalPort' was not declared in this scope
  17. LabVIEWInterface:210: error: 'analogReadPort' was not declared in this scope
  18. LabVIEWInterface:231: error: 'sevenSegment_Config' was not declared in this scope
  19. LabVIEWInterface:235: error: 'sevenSegment_Write' was not declared in this scope
  20. LabVIEWInterface:306: error: 'spi_setClockDivider' was not declared in this scope
  21. LabVIEWInterface:330: error: 'spi_sendReceive' was not declared in this scope
  22. LabVIEWInterface:341: error: 'servos' was not declared in this scope
  23. LabVIEWInterface:342: error: 'Servo' was not declared in this scope
  24. LabVIEWInterface:342: error: expected primary-expression before ')' token
  25. LabVIEWInterface:342: error: expected `;' before 'malloc'
  26. LabVIEWInterface:420: error: 'lcd_print' was not declared in this scope
  27. LabVIEWInterface:485: error: 'acqMode' was not declared in this scope
  28. LabVIEWInterface:486: error: 'contAcqPin' was not declared in this scope
  29. LabVIEWInterface:487: error: 'contAcqSpeed' was not declared in this scope
  30. LabVIEWInterface:488: error: 'acquisitionPeriod' was not declared in this scope
  31. LabVIEWInterface:489: error: 'iterationsFlt' was not declared in this scope
  32. LabVIEWInterface:490: error: 'iterations' was not declared in this scope
  33. LabVIEWInterface:495: error: 'delayTime' was not declared in this scope
  34. LabVIEWInterface:505: error: 'FIRMWARE_MAJOR' was not declared in this scope
  35. LabVIEWInterface:506: error: 'FIRMWARE_MINOR' was not declared in this scope
  36. LabVIEWInterface:510: error: 'finiteAcquisition' was not declared in this scope
  37. LabVIEWInterface:564: error: 'irsend' was not declared in this scope
  38. LabVIEWInterface.ino: In function 'void syncLV()':
  39. LabVIEWInterface:752: error: 'DEFAULTBAUDRATE' was not declared in this scope
  40. LabVIEWInterface.ino: In function 'unsigned char checksum_Compute(unsigned char*)':
  41. LabVIEWInterface:763: error: 'COMMANDLENGTH' was not declared in this scope
  42. LabVIEWInterface.ino: In function 'int checksum_Test(unsigned char*)':
  43. LabVIEWInterface:774: error: 'COMMANDLENGTH' was not declared in this scope
  44. LabVIEWInterface.ino: In function 'void sampleContinously()':
  45. LabVIEWInterface:815: error: 'iterations' was not declared in this scope
  46. LabVIEWInterface:817: error: 'contAcqPin' was not declared in this scope
  47. LabVIEWInterface:818: error: 'contAcqSpeed' was not declared in this scope
  48. LabVIEWInterface:821: error: 'delayTime' was not declared in this scope
  49. LabVIEWInterface:827: error: 'delayTime' was not declared in this scope
  50. LabVIEWInterface.ino: In function 'void finiteAcquisition(int, float, int)':
  51. LabVIEWInterface:834: error: 'acquisitionPeriod' was not declared in this scope
官方例程,怎么会编译有这么多错误?
发表于 2016-12-22 22:13:16 来自手机 | 显示全部楼层
看看库有没有安装好,你只有ino文件,可是应该有需要引用的c++库
发表于 2016-12-22 22:16:36 | 显示全部楼层
主要原因是因为你装载库文件失败了,你试下更新版本
 楼主| 发表于 2016-12-23 10:40:29 | 显示全部楼层
labview interface for arduino包是最新的,那我就使用arduino最新版本IDE
 楼主| 发表于 2016-12-23 10:41:47 | 显示全部楼层
按照《arduino与labview互动设计》操作,作者也是arduino1.0版本
发表于 2016-12-23 12:23:12 | 显示全部楼层
别用LIFA了,你找一下linx  makehub,用那个比较好
(关键是我也没弄好LIFA,。。。)
 楼主| 发表于 2016-12-23 20:00:50 | 显示全部楼层
(关键是我也没弄好LIFA,。。。)
解决了,刚好也安装了linx,有关于它的实例吗?分享一下
发表于 2016-12-26 11:24:32 | 显示全部楼层
下好了固件后,会有提示,自带有很多例程的。
发表于 2016-12-26 11:27:37 | 显示全部楼层
发表于 2016-12-26 11:29:13 | 显示全部楼层
D:\Program Files (x86)\National Instruments\LabVIEW 2014\vi.lib\MakerHub\LINX\Private\Local IO
 楼主| 发表于 2016-12-26 21:44:52 | 显示全部楼层
谢谢,今天一个作者也建议我学linx,说LIFA好久没更新了
GMT+8, 2024-4-27 01:36 , Processed in 0.048509 second(s), 21 queries .
