查看: 10586|回复: 1
怎么用一个按键控制4位数码管时钟的从00:00开始?而我这个程序我用按键控制,它不...
发表于 2017-4-6 15:49:42 | 显示全部楼层 |阅读模式
怎么用一个按键控制4位数码管时钟的从00:00开始?而我这个程序我用按键控制,它不受控制的?
[kenrobot_code]#include <TimerOne.h>
#include "TM1637.h"
char ON='1';
char OFF="0";
int8_t TimeDisp[] ={0,1,2,3};
unsigned char ClockPoint = 1;
unsigned char Update;
unsigned char halfsecond = 0;
unsigned char second = 0;
unsigned char minute = 0;
char CLK=A1;//pins definitions for TM1637 and can be changed to other ports
char DIO=A0;
TM1637 tm1637(CLK,DIO);
{pinMode(14,OUTPUT);
digitalWrite(14,HIGH);
  tm1637.set();
  tm1637.init();
  Timer1.initialize(500000);//timing for 500ms
  Timer1.attachInterrupt(TimingISR);//declare the interrupt serve routine:TimingISR
   if(Update == ON)
    TimeUpdate();
    tm1637.display(TimeDisp);
  if(minute == 1)
  {Update = OFF;
  digitalWrite(14,LOW);
void TimingISR()
  halfsecond++;
  Update = ON;
  if(halfsecond == 2){
    second ++;
    if(second == 60)
      minute++;
      if(minute == 1)
      second = 0;
    halfsecond = 0;
// Serial.println(second)
ClockPoint = (~ClockPoint) & 0x01;
void TimeUpdate(void)
  if(ClockPoint)tm1637.point(POINT_ON);
  else tm1637.point(POINT_OFF);
  TimeDisp[0] = minute / 10;
  TimeDisp[1] = minute % 10;
  TimeDisp[2] = second / 10;
  TimeDisp[3] = second % 10;
  Update = OFF;
}[/kenrobot_code]
GMT+8, 2024-5-7 20:22 , Processed in 0.041877 second(s), 17 queries .
