代码求优化,第一次搞的单片机程序,Ctrl+C 百分之八十,自己弄了剩下的,分割线一下是自己弄的,现在舵机倒是可以按照陀螺仪的参数运行了,就是不怎么灵敏,而且到角度极限时居然会反转,晕。。。。。。。请前辈门指点指点,在下谢谢了,这个代码只要是想弄个自稳的云台的。
- #include <Servo.h>
- #include <I2Cdev.h>
- #include <MPU6050.h>
- #include "Wire.h"
- MPU6050 accelgyro;
- Servo Servol;
- Servo Servol2;
- int16_t ax, ay, az;
- int16_t gx, gy, gz;
- #define Gry_offset_X 45//陀螺仪X轴的静态飘移。
- #define Gry_offset_Y 271
- #define Gyr_Gain -0.00763//由陀螺仪X轴读数转换为角速度值,=1/131,向前方向与X轴为反方向,故乘以-112.
- #define ACC_Gain 0.000061//由读数转换为加速度值,=1/16384
- #define pi 3.1415926
- #define K_x 0.715//一阶互补滤波权重取值,不知由来,可更改。
- #define k_Y 1.3
- unsigned long preTime = 0;
- float angle_X = 0;
- float angle_Y = 0;
- float Temp=0,Temp_o=0;
- void setup()
- Wire.begin();
- Serial.begin(38400);
- accelgyro.initialize();
- Servol.attach(2);
- Servol.write(90);
- Servol2.attach(3);
- Servol2.write(90);
- }//MPU6050初始化。
- void loop() {
- unsigned long now = millis();//当前时间(ms)
- float dt = (now - preTime) / 500.0;//微分时间(s)
- preTime = now;//上一次采样时间(ms)
- accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);//读取六轴数值
- float Y_Accelerometer = ay * ACC_Gain;//转换为向前的加速度(g),为负值
- float Z_Accelerometer = az * ACC_Gain;//转换为向下的加速度(g)
- float X_Accelerometer = ax * ACC_Gain;
- float angleA_X= atan(Y_Accelerometer/ Z_Accelerometer)* (-180)/ pi;//加速度仪,反正切获得弧度值,乘以180度/pi43.
- //获得角度值,乘以-1得正
- float angleA_Y= atan(X_Accelerometer/Z_Accelerometer)*(-180)/pi;
- float gx_revised = gx + Gry_offset_X;//陀螺仪x轴静态时修正后的角速度读数,向前为负值
- float gy_revised = gy + Gry_offset_Y;
- float omega_X= Gyr_Gain* gx_revised;//陀螺仪,转换为向前的角速度(o/s),Gyr_Gain取负,故负负得正
- float omega_Y= Gyr_Gain* gy_revised;
- float angle_dt_X = omega_X * dt;//角度的单次积分值
- float angle_dt_Y = omega_Y * dt;
- angle_X+= (Gyr_Gain * (gx + Gry_offset_X)) * dt;
- angle_Y+= (Gyr_Gain * (gy + Gry_offset_Y)) * dt;
- float A_X= K_x/ (K_x+ dt); //陀螺仪的权值
- float A_Y= k_Y/(k_Y+dt);
- angle_X= A_X* (angle_X+ omega_X* dt)+ (1-A_X)* angleA_X;//一阶互补滤波后的输出角度(o)
- angle_Y= A_Y*(angle_Y+omega_Y*dt)+(1-A_Y)*angleA_Y;
- //---------------------------------------------------------------------------------------------舵机开始
- Temp=90;
- if (angle_X>0){
- if ((Temp+angle_X)<170){
- Servol.write(angle_X+Temp) ;
- delay(5);
- else {
- if ((angle_X+Temp)>1){
- Servol.write(angle_X+Temp);
- delay(5);
- if (angle_Y>0){
- if ((Temp+angle_Y)<170){
- Servol2.write(angle_Y+Temp) ;
- delay(5);
- else {
- if ((angle_Y+Temp)>1){
- Servol2.write(angle_Y+Temp);
- delay(5);
- Serial.print(angle_X);
- Serial.print(",");
- Serial.print(angle_Y);
- Serial.print("\n");
复制代码 |
