查看: 9010|回复: 0
Arduino KEYBOARD (适用于莱昂纳多)
发表于 2013-1-2 22:44:18 | 显示全部楼层 |阅读模式
在Arduino网站上看到的,这个更全面。
Description
Sends a keystroke to a connected computer. This is similar to pressing and releasing a key on your keyboard. You can send some ASCII characters or the additional keyboard modifiers and special keys.
Only ASCII characters that are on the keyboard are supported. For example, ASCII 8 (backspace) would work, but ASCII 25 (Substitution) would not. When sending capital letters, Keyboard.write() sends a shift command plus the desired character, just as if typing on a keyboard. If sending a numeric type, it sends it as an ASCII character (ex. Keyboard.write(97) will send 'a').
For a complete list of ASCII characters, see ASCIITable.com.
WARNING: When you use the Keyboard.write() command, the Arduino takes over your keyboard! Make sure you have control before you use the command. A pushbutton to toggle the keyboard control state is effective.
Syntax
Keyboard.write(character)
Parameters
character : a char or int to be sent to the computer. Can be sent in any notation that's acceptable for a char. For example, all of the below are acceptable and send the same value, 65 or ASCII A:
Keyboard.write(65);         // sends ASCII value 65, or A
Keyboard.write('A');            // same thing as a quoted character
Keyboard.write(0x41);       // same thing in hexadecimal
Keyboard.write(0b01000001); // same thing in binary (weird choice, but it works)
[Get Code]
Returns
int : number of bytes sent
Example
  // make pin 2 an input and turn on the
  // pullup resistor so it goes high unless
  // connected to ground:
  pinMode(2, INPUT_PULLUP);
  Keyboard.begin();
  //if the button is pressed
  if(digitalRead(2)==LOW){
    //Send an ASCII 'A',
    Keyboard.write(65);
[Get Code]
See Also
    Keyboard.begin()
    Keyboard.end()
    Keyboard.press()
    Keyboard.print()
    Keyboard.println()
    Keyboard.release()
    Keyboard.releaseAll()
    ASCIITable tutorial
Reference Home
Corrections, suggestions, and new documentation should be posted to the Forum.
The text of the Arduino reference is licensed under a Creative Commons Attribution-ShareAlike 3.0 License. Code samples in the reference are released into the public domain.
网页:http://www.arduino.cc/en/Reference/KeyboardWrite
再贴上图
这样一替换就可以得到许多不同的按键了。
这个方法只适用于莱昂纳多,其他版本的请见我另外一个帖子。
GMT+8, 2024-4-28 15:48 , Processed in 0.056150 second(s), 17 queries .
