查看: 30000|回复: 5
Arduino nano问题
发表于 2018-7-30 11:15:13 | 显示全部楼层 |阅读模式
Arduino nano怎么上传不程序?是什么问题?CH340驱动也装了
Arduino:1.8.5 (Windows 10), 开发板:"Arduino Nano, ATmega328P"
构建选项已变更,全部重新构建
Archiving built core (caching) in: C:\Users\BingWu\AppData\Local\Temp\arduino_cache_291917\core\core_arduino_avr_nano_cpu_atmega328_595241e09e5a5ccb25e5fb7e8a7a1bee.a
项目使用了 6816 字节,占用了 (22%) 程序存储空间。最大为 30720 字节。
全局变量使用了349字节,(17%)的动态内存,余留1699字节局部变量。最大为2048字节。
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1b
上传出错。查看http://www.arduino.cc/en/Guide/Troubleshooting#upload 获取建议。
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
发表于 2018-7-30 13:47:28 | 显示全部楼层
是不是板子没刷bootloader
 楼主| 发表于 2018-7-31 17:13:27 | 显示全部楼层
应该是的,我又淘宝是两块nano就可以用了,那bootloader怎么刷,请教!!!!!
发表于 2018-8-4 13:07:49 | 显示全部楼层
买个usbtinyisp,IDE里面选好烧录器,选好板子,点击烧录bootloader
发表于 2019-6-16 21:49:53 | 显示全部楼层
328p bootloader的问题,1.8版本可尝试:工具->处理器-->选择ATmega328P(Old Bootloader),然后重新上传。
发表于 2019-6-23 19:08:01 | 显示全部楼层
我的同样问题,选择PRO MINI可以下载
GMT+8, 2024-5-3 14:48 , Processed in 0.040850 second(s), 22 queries .
