查看: 14362|回复: 0
8F328P-U 與 TM1637 LED數碼管驅動程序
发表于 2018-10-26 17:28:34 | 显示全部楼层 |阅读模式
TM1637 is a multi-segment(8*6) LED driver with 8*2 scan keys.
a)      數據輸入的開始條件是CLK 為高電平時,DIO 由高變低
b)      在輸入時,當CLK 是高電平時,DIO 上的信號必須保持不變;只有CLK 上的時鐘信號為低電平時,DIO 上的信號才能改變
c)      結束條件是CLK 為高時,DIO 由低電平變為高電平
Key
S16
S15
S14
S13
S12
S11
S10
S9
S8
S7
S6
S5
S4
S3
S2
S1
Matrice
SG8
  K1
SG8
  K2
SG4
  K2
SG4
  K1
SG7
  K1
SG7
  K2
SG3
  K2
SG3
  K1
SG6
  K1
SG6
  K2
SG2
  K2
SG2
  K1
SG5
  K1
SG5
  K2
SG1
  K2
SG1
  K1
hex
F0
E8
EC
F4
F1
E9
ED
F5
F2
EA
EE
F6
F3
EB
EF
F7
Command:
Test Mode
0x48
01001000
test mode (internal use)
Normal Mode
0x40
01000000
the byte sent below is a datum towards the  display, with the automatic increase in destination addresses
0x44
01000100
the byte sent below is a datum towards  the display, with the fixed destination addresses
0x42
01000010
read the input situation
Display Control
0x80
10000000
display off
0x88-0x8F
10001000-100001111
display on with brightness control, 7  step
/* Program for Display on TM1637 */
const int clock = 3;
const int data = 2;
/*0*/ /*1*/ /*2*/ /*3*/ /*4*/ /*5*/ /*6*/ /*7*/ /*8*/ /*9*/
uint8_t digits[] = { 0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f };
  Serial.begin(115200);
  pinMode(clock, OUTPUT);
  pinMode(data, OUTPUT);
  start();
  writeValue(0x8c);
  stop();
  // clear display
  write(0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
  unsigned int temp = keyscan();
  Serial.println(temp, HEX);
  write(digits[0], digits[2], digits[3], digits[4], digits[5], digits[6]);
void write(uint8_t first, uint8_t second, uint8_t third, uint8_t fourth, uint8_t fifth, uint8_t sixth)
  start();
  writeValue(0xc0);
  writeValue(first);
  writeValue(second);
  writeValue(third);
  writeValue(fourth);
  writeValue(fifth);
  writeValue(sixth);
  stop();
void start(void)
  digitalWrite(clock, HIGH); //send start signal to TM1637
  digitalWrite(data, HIGH);
  delayMicroseconds(5);
  digitalWrite(data, LOW);
  digitalWrite(clock, LOW);
void stop(void)
bool writeValue(uint8_t value)
  for (uint8_t i = 0; i < 8; i++)
    digitalWrite(data, (value & (1 << i)) >> i);
  // wait for ACK
  pinMode(data, INPUT);
  bool ack = digitalRead(data) == 0;
  return ack;
uint8_t keyscan(void)
  uint8_t rekey;
  start();
  writeValue(0x42);
  delayMicroseconds(2);
    rekey = rekey >> 1;
    if (digitalRead(data))
      rekey = rekey | 0x80;
      rekey = rekey | 0x00;
  // digitalWrite(clock, LOW);
  // wait for ACK
  stop();
  return rekey;
void writeByte(int8_t wr_data)
  uint8_t i, count1;
  for (i = 0; i < 8; i++) //sent 8bit data
    if (wr_data & 0x01)digitalWrite(data, HIGH); //LSB first
    else digitalWrite(data, LOW);
    wr_data >>= 1;
  digitalWrite(clock, LOW); //wait for the ACK
  while (digitalRead(data))
    count1 += 1;
    if (count1 == 200) //
      count1 = 0;
GMT+8, 2024-5-18 04:08 , Processed in 0.065675 second(s), 18 queries .
