查看: 19078|回复: 0
stm32f103c8t6使用数码管显示
发表于 2019-4-6 18:48:45 | 显示全部楼层 |阅读模式
买的74hc595四位数码管模块送的arduino程序不对,现修改如下:
接线:
模块                       stm32f103c8t6开发板
GND -----------------GND
VCC----------------------5V
SCLK -------------------PB9;
RCLK -------------------PB8;
DAT ---------------------PB7;
重要的一点是,先串行输入地址,然后串行输入显示的数据,完整程序如下,复制便可以运行:
unsigned char LED_0F[] =
    {// 0         1          2           3        4         5          6           7        8         9          A           b        C    d          E    F    -
            0xc0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8e,0xbf
    unsigned char LED[4];        //用于LED的4位显示缓存
    int SCLK = PB9;
    int RCLK = PB8;
    int DIO = PB7; //这里定义了那三个脚
    void setup ()
      pinMode(SCLK,OUTPUT);
      pinMode(RCLK,OUTPUT);
      pinMode(DIO,OUTPUT); //让三个脚都是输出状态
       LED[0]=9;
            LED[1]=6;
            LED[2]=7;
            LED[3]=8;
           LED4_Display ();
    void LED4_Display (void)
      unsigned char *led_table;          // 查表指针
            unsigned char i;
            //显示第1位
            led_table = LED_0F + LED[0];
            i = *led_table;
            LED_OUT(0x01);
            LED_OUT(i);
        digitalWrite(RCLK,LOW);
        digitalWrite(RCLK,HIGH);
            //显示第2位
            led_table = LED_0F + LED[1];
            i = *led_table;
    LED_OUT(0x02);
            LED_OUT(i);
            //显示第3位
            led_table = LED_0F + LED[2];
            i = *led_table;
    LED_OUT(0x04);
            LED_OUT(i);
            //显示第4位
            led_table = LED_0F + LED[3];
            i = *led_table;
    LED_OUT(0x08);
            LED_OUT(i);
    void LED_OUT(unsigned char X)
            unsigned char i;
            for(i=8;i>=1;i--)
                    if (X&0x80)
                  digitalWrite(DIO,HIGH);
                  digitalWrite(DIO,LOW);
                    X<<=1;
                digitalWrite(SCLK,LOW);
                digitalWrite(SCLK,HIGH);
GMT+8, 2024-5-5 18:01 , Processed in 0.046388 second(s), 18 queries .
