查看: 20762|回复: 0
使用DS107做的数字时钟时间不同步,大神们帮忙看看
发表于 2019-5-30 20:15:11 | 显示全部楼层 |阅读模式
#include <Wire.h>
#include <RTClib.h>
void printDateTime(DateTime dateTime);
//创建实例
RTC_DS1307 RTC;
int clk = 3;
int cs = 4;
int din = 5;
unsigned char disp3[60][8] = {
{0x0, 0x0, 0xEE, 0xAB, 0xAA, 0xAB, 0xEE, 0x0}, //0
{0x0, 0x0, 0xE4, 0xAD, 0xA4, 0xA5, 0xEE, 0x0}, //1
{0x0, 0x0, 0xEE, 0xA3, 0xAE, 0xA9, 0xEE, 0x0}, //2
{0x0, 0x0, 0xEE, 0xA3, 0xAE, 0xA3, 0xEE, 0x0}, //3
{0x0, 0x0, 0xEA, 0xAB, 0xAE, 0xA3, 0xE2, 0x0}, //4
{0x0, 0x0, 0xEE, 0xA9, 0xAE, 0xA3, 0xEE, 0x0}, //5
{0x0, 0x0, 0xEE, 0xA9, 0xAE, 0xAB, 0xEE, 0x0}, //6
{0x0, 0x0, 0xEE, 0xA3, 0xA2, 0xA3, 0xE2, 0x0}, //7
{0x0, 0x0, 0xEE, 0xAB, 0xAE, 0xAB, 0xEE, 0x0}, //8
{0x0, 0x0, 0xEE, 0xAB, 0xAE, 0xA3, 0xEE, 0x0}, //9
{0x0, 0x0, 0x4E, 0xCB, 0x4A, 0x4B, 0xEE, 0x0}, //10
{0x0, 0x0, 0x44, 0xCD, 0x44, 0x45, 0xEE, 0x0}, //11
{0x0, 0x0, 0x4E, 0xC3, 0x4E, 0x49, 0xEE, 0x0}, //12
{0x0, 0x0, 0x4E, 0xC3, 0x4E, 0x43, 0xEE, 0x0}, //13
{0x0, 0x0, 0x4A, 0xCB, 0x4E, 0x43, 0xE2, 0x0}, //14
{0x0, 0x0, 0x4E, 0xC9, 0x4E, 0x43, 0xEE, 0x0}, //15
{0x0, 0x0, 0x4E, 0xC9, 0x4E, 0x4B, 0xEE, 0x0}, //16
{0x0, 0x0, 0x4E, 0xC3, 0x42, 0x43, 0xE2, 0x0}, //17
{0x0, 0x0, 0x4E, 0xCB, 0x4E, 0x4B, 0xEE, 0x0}, //18
{0x0, 0x0, 0x4E, 0xCB, 0x4E, 0x43, 0xEE, 0x0}, //19
{0x0, 0x0, 0xEE, 0x2B, 0xEA, 0x8B, 0xEE, 0x0}, //20
{0x0, 0x0, 0xE4, 0x2D, 0xE4, 0x85, 0xEE, 0x0}, //21
{0x0, 0x0, 0xEE, 0x23, 0xEE, 0x89, 0xEE, 0x0}, //22
{0x0, 0x0, 0xEE, 0x23, 0xEE, 0x83, 0xEE, 0x0}, //23
{0x0, 0x0, 0xEA, 0x2B, 0xEE, 0x83, 0xE2, 0x0}, //24
{0x0, 0x0, 0xEE, 0x29, 0xEE, 0x83, 0xEE, 0x0}, //25
{0x0, 0x0, 0xEE, 0x29, 0xEE, 0x8B, 0xEE, 0x0}, //26
{0x0, 0x0, 0xEE, 0x23, 0xE2, 0x83, 0xE2, 0x0}, //27
{0x0, 0x0, 0xEE, 0x2B, 0xEE, 0x8B, 0xEE, 0x0}, //28
{0x0, 0x0, 0xEE, 0x2B, 0xEE, 0x83, 0xEE, 0x0}, //29
{0x0, 0x0, 0xEE, 0x2B, 0xEA, 0x2B, 0xEE, 0x0}, //30
{0x0, 0x0, 0xE4, 0x2D, 0xE4, 0x25, 0xEE, 0x0}, //31
{0x0, 0x0, 0xEE, 0x23, 0xEE, 0x29, 0xEE, 0x0}, //32
{0x0, 0x0, 0xEE, 0x23, 0xEE, 0x23, 0xEE, 0x0}, //33
{0x0, 0x0, 0xEA, 0x2B, 0xEE, 0x23, 0xE2, 0x0}, //34
{0x0, 0x0, 0xEE, 0x29, 0xEE, 0x23, 0xEE, 0x0}, //35
{0x0, 0x0, 0xEE, 0x29, 0xEE, 0x2B, 0xEE, 0x0}, //36
{0x0, 0x0, 0xEE, 0x23, 0xE2, 0x23, 0xE2, 0x0}, //37
{0x0, 0x0, 0xEE, 0x2B, 0xEE, 0x2B, 0xEE, 0x0}, //38
{0x0, 0x0, 0xEE, 0x2B, 0xEE, 0x23, 0xEE, 0x0}, //39
{0x0, 0x0, 0xAE, 0xAB, 0xEA, 0x2B, 0x2E, 0x0}, //40
{0x0, 0x0, 0xA4, 0xAD, 0xE4, 0x25, 0x2E, 0x0}, //41
{0x0, 0x0, 0xAE, 0xA3, 0xEE, 0x29, 0x2E, 0x0}, //42
{0x0, 0x0, 0xAE, 0xA3, 0xEE, 0x23, 0x2E, 0x0}, //43
{0x0, 0x0, 0xAA, 0xAB, 0xEE, 0x23, 0x22, 0x0}, //44
{0x0, 0x0, 0xAE, 0xA9, 0xEE, 0x23, 0x2E, 0x0}, //45
{0x0, 0x0, 0xAE, 0xA9, 0xEE, 0x2B, 0x2E, 0x0}, //46
{0x0, 0x0, 0xAE, 0xA3, 0xE2, 0x23, 0x22, 0x0}, //47
{0x0, 0x0, 0xAE, 0xAB, 0xEE, 0x2B, 0x2E, 0x0}, //48
{0x0, 0x0, 0xAE, 0xAB, 0xEE, 0x23, 0x2E, 0x0}, //49
{0x0, 0x0, 0xEE, 0x8B, 0xEA, 0x2B, 0xEE, 0x0}, //50
{0x0, 0x0, 0xE4, 0x8D, 0xE4, 0x25, 0xEE, 0x0}, //51
{0x0, 0x0, 0xEE, 0x83, 0xEE, 0x29, 0xEE, 0x0}, //52
{0x0, 0x0, 0xEE, 0x83, 0xEE, 0x23, 0xEE, 0x0}, //53
{0x0, 0x0, 0xEA, 0x8B, 0xEE, 0x23, 0xE2, 0x0}, //54
{0x0, 0x0, 0xEE, 0x89, 0xEE, 0x23, 0xEE, 0x0}, //55
{0x0, 0x0, 0xEE, 0x89, 0xEE, 0x2B, 0xEE, 0x0}, //56
{0x0, 0x0, 0xEE, 0x83, 0xE2, 0x23, 0xE2, 0x0}, //57
{0x0, 0x0, 0xEE, 0x8B, 0xEE, 0x2B, 0xEE, 0x0}, //58
{0x0, 0x0, 0xEE, 0x8B, 0xEE, 0x23, 0xEE, 0x0} //59
long timer = 0;
int temp[3] = {0, 0, 0};
//初始化总线
Wire.begin();
//初始化实时时钟
RTC.begin();
pinMode(cs, OUTPUT);
pinMode(clk, OUTPUT);
pinMode(din, OUTPUT);
//初始点阵屏
Init_MAX7219();
if (millis() - timer > 999) {
//获取当前日期和时间
DateTime now = RTC.now();
//通过串口传送当前的日期和时间
printDateTime(now);
//把取当前时间放置temp[]变量
Date_Time(now);
//初始计时变量
timer = millis();
for (int i = 1; i < 9; i++) {
Write_Max7219_1(i, disp3[temp[0]][i - 1]);//点阵显示时
Write_Max7219_2(i, disp3[temp[1]][i - 1]);//点阵显示分
Write_Max7219_3(i, disp3[temp[2]][i - 1]);//点阵显示秒
void Date_Time(DateTime dateTime) {
temp[0] = dateTime.hour();
temp[1] = dateTime.minute();
temp[2] = dateTime.second();
void printDateTime(DateTime dateTime) {
//传送年份
Serial.print(dateTime.year(), DEC);
Serial.print(’/’);
//传送月份
Serial.print(dateTime.month(), DEC);
Serial.print(’/’);
//传送月份中的第几天
Serial.print(dateTime.day(), DEC);
Serial.print(’ ‘);
//传送小时
Serial.print(dateTime.hour(), DEC);
Serial.print(’:’);
//传送分钟
Serial.print(dateTime.minute(), DEC);
Serial.print(’:’);
//传送秒
Serial.print(dateTime.second(), DEC);
Serial.println();
void Write_Max7219_byte(char DATA)
char i;
digitalWrite(cs, 0);
for (i = 8; i >= 1; i–)
digitalWrite(clk, 0);
if ((DATA & 0x80) > 0) {
digitalWrite(din, 1);
else {
digitalWrite(din, 0);
//提取最高位给DIN端口
DATA = DATA << 1; //左移一位
digitalWrite(clk, 1);
void Write_Max7219_1(char address1, char dat1)
Write_Max7219_byte(address1); //写入地址,即数码管编号
Write_Max7219_byte(dat1); //写入数据,即数码管显示数字
digitalWrite(cs, 1);
void Write_Max7219_2(char address2, char dat2)
Write_Max7219_byte(address2); //写入地址,即数码管编号
Write_Max7219_byte(dat2);//写入数据,即数码管显示数字
Write_Max7219_byte(0x00);
void Write_Max7219_3(char address3, char dat3)
Write_Max7219_byte(address3); //写入地址,即数码管编号
Write_Max7219_byte(dat3);//写入数据,即数码管显示数字
void Init_MAX7219(void)
Write_Max7219_1(0x09, 0x00);//译码方式:BCD码
Write_Max7219_1(0x0a, 0x01);//亮度
Write_Max7219_1(0x0b, 0x07); //扫描界限;8个数码管显示
Write_Max7219_1(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219_1(0x0f, 0x00);
Write_Max7219_2(0x09, 0x00);//译码方式:BCD码
Write_Max7219_2(0x0a, 0x01);//亮度
Write_Max7219_2(0x0b, 0x07); //扫描界限;8个数码管显示
Write_Max7219_2(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219_2(0x0f, 0x00);
Write_Max7219_3(0x09, 0x00);//译码方式:BCD码
Write_Max7219_3(0x0a, 0x01);//亮度
Write_Max7219_3(0x0b, 0x07); //扫描界限;8个数码管显示
Write_Max7219_3(0x0c, 0x01); //掉电模式:0,普通模式:1
Write_Max7219_3(0x0f, 0x00);
delay(500);
我用的是点阵模块
GMT+8, 2024-5-3 01:50 , Processed in 0.039902 second(s), 18 queries .
