查看: 17688|回复: 2
分享一个RFID-RC522的程序
发表于 2019-7-22 22:02:13 | 显示全部楼层 |阅读模式
研究了好几天,网上一只没有找到可以使用的程序,终于自己改出了一套,分享给大家
* Typical pin layout used:
*             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
*             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
* Signal      Pin          Pin           Pin       Pin        Pin              Pin
* RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
* SPI SS      SDA(SS)      10            53        D10        10               10
* SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
* SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
* SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
String read_rfid;
String rfid1 = "FFFFFFFF";//设备1uid
String rfid2 = "00000000";//设备2uid
String rfid3 = "XXXXXXXX";//设备3uid
int lock = 2;
int bee = 3;
int ledr = 4;
int ledg = 5;
int ledb = 6;
  Serial.begin(9600);   // Initiate a serial communication
  while (!Serial);
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  Serial.println("Approximate your card to the reader...");
  //Serial.println();
pinMode(lock,OUTPUT);
digitalWrite(lock,LOW);
pinMode(bee,OUTPUT);
digitalWrite(bee,LOW);
pinMode(ledr,OUTPUT);
digitalWrite(ledr,HIGH);
pinMode(ledg,OUTPUT);
digitalWrite(ledg,HIGH);
pinMode(ledb,OUTPUT);
digitalWrite(ledb,HIGH);
void dump_byte_array(byte *buffer,byte bufferSize)
  read_rfid="";
  for(byte i = 0;i < bufferSize;i++)
    read_rfid = read_rfid + String(buffer,HEX);
void open_lock()
  bb();
void bb()
  digitalWrite(ledg,LOW);
   for (int x = 0;x < 100;x++)
    digitalWrite(bee,HIGH);
    delay(1);
    delay(1);
  for (int x = 0;x < 200;x++)
    delayMicroseconds(300);
  digitalWrite(ledb,LOW);
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
   dump_byte_array(mfrc522.uid.uidByte,mfrc522.uid.size);
   Serial.println(read_rfid);
   if(read_rfid == rfid1 or read_rfid == rfid2 or read_rfid == rfid3)
    Serial.println("Pass");
    open_lock();
    digitalWrite(ledr,LOW);
    delay(1);
    delay(1);
  delay(80);
    delay(1);
    delay(1);
// 使放置在读卡区的IC卡进入休眠状态,不再重复读卡
  mfrc522.PICC_HaltA();
  // 停止读卡模块编码
  mfrc522.PCD_StopCrypto1();
发表于 2019-10-11 22:27:50 | 显示全部楼层
MFRC522.h呢?
GMT+8, 2024-5-7 17:31 , Processed in 0.040509 second(s), 18 queries .
