查看: 5712|回复: 1
arduino+ILI9225显示旋转的立方体
发表于 2019-9-22 15:31:31 | 显示全部楼层 |阅读模式
论坛原贴https://www.geek-workshop.com/thread-26090-1-1.html是使用OLED12864作为显示,手上只有ILI9225,所以简单修改了一下就可以使用。
#include <memorysaver.h>
#include <UTFT.h>
UTFT myGLCD(ILI9225,A2,A1,A5,A4,A3);
typedef struct Vertex{
  int8_t location[3];
}MyVertex;
typedef struct Edge{
  int8_t connection[2];
}MyEdge;
typedef struct Object{
  int numv;
  int nume;
  MyVertex* v;
  MyEdge* e;
  float quat[4];
  float offset[3];
}MyObject;
static MyVertex mp[] ={{ -16, -16,-16}, \
                      {16, -16, -16}, \
                      {16, 16, -16}, \
                      {-16, 16, -16}, \
                      {-16, -16,16}, \
                      {16, -16, 16}, \
                      {16, 16, 16}, \
                      {-16, 16, 16}
static MyEdge me[] ={{0, 1}, \
                    {1, 2}, \
                    {2, 3}, \
                    {3, 0}, \
                    {4, 5}, \
                    {5, 6}, \
                    {6, 7}, \
                    {7, 4}, \
                    {0, 4}, \
                    {1, 5}, \
                    {2, 6}, \
                    {3, 7}
MyObject  obj={0, 0, mp, me,{1,0,0,0},{0,0,0}};
void setup()   {
  //correct vertex num and edge num
  obj.numv=sizeof(mp)/sizeof(MyVertex);
  obj.nume=sizeof(me)/sizeof(MyEdge);
myGLCD.InitLCD();
myGLCD.InitLCD();
myGLCD.clrScr();
  delay(1000);
  moveObject(obj,0,0,70);
  renderObject(obj);
static float qdelta[4]={0.999847695f,0,0.0174524f,0};
static float qview[4]={0.25881904510252076234889883762405f,0.9659258262890682867497431997289f,0,0};
static float qtemp[4];
#define near 1.0
#define far 100.0
#define right 1.8
#define top 1.8
static float proj[8]={
    near/right,    0,         0,                    0, \
    0,         near/top,      0,                    0
//    0,             0,   -(far+near)/(far-near), -2*far*near/(far-near),
//    0,             0,         -1,                   0
  rotateObject(obj,qdelta);
  //myGLCD.clrScr();   // clears the screen and buffer
//myGLCD.fillScr(VGA_BLACK);
  renderObject(obj);
delay(100);
  clcObject(obj);
   delay(100);
void moveObject(MyObject &mo, float x, float y, float z) {
  mo.offset[0]=x;
  mo.offset[1]=y;
  mo.offset[2]=z;
void rotateObject(MyObject &mo, float* q) {
  qproduct(q,obj.quat,qtemp);
  mo.quat[0]=qtemp[0];
  mo.quat[1]=qtemp[1];
  mo.quat[2]=qtemp[2];
  mo.quat[3]=qtemp[3];
  qnormalized(qtemp);
void renderObject(MyObject &mo) {
  MyVertex* mv=new MyVertex[mo.numv];
  qproduct(qview,mo.quat,qtemp);
  for (int i = 0; i < mo.numv; i++) {
    float vtemp[3];
    iqRot(qtemp,mo.v.location,vtemp);
    vtemp[0] += mo.offset[0];
    vtemp[1] += mo.offset[1];
    vtemp[2] += mo.offset[2];
    MatMulVect(proj, vtemp, mv.location);
  for (int i = 0; i < mo.nume; i++) {
    int8_t p1 = mo.e.connection[0];
    int8_t p2 = mo.e.connection[1];
    myGLCD.setColor(VGA_WHITE);
    myGLCD.drawLine(mv[p1].location[0]+100, mv[p1].location[1]+100, mv[p2].location[0]+100, mv[p2].location[1]+100);
  delete mv;
void clcObject(MyObject &mo) {
    float vtemp[3];
    myGLCD.setColor(VGA_BLACK);
  delete mv;
float iqRot(float q[],int8_t v[],float result[]){
  float prod[4];
  prod[0] =  - q[1] * v[0] - q[2] * v[1] - q[3] * v[2];
  prod[1] = q[0] * v[0] + q[2] * v[2] - q[3] * v[1];
  prod[2] = q[0] * v[1] - q[1] * v[2] + q[3] * v[0];
  prod[3] = q[0] * v[2] + q[1] * v[1] - q[2] * v[0];
  result[0] = -prod[0] * q[1] + prod[1] * q[0] - prod[2] * q[3] + prod[3] * q[2];
  result[1] = -prod[0] * q[2] + prod[1] * q[3] + prod[2] * q[0] - prod[3] * q[1];
  result[2] = -prod[0] * q[3] - prod[1] * q[2] + prod[2] * q[1] + prod[3] * q[0];
void qproduct(const float* p, const float* q, float* qr) {
  qr[0] = p[0] * q[0] - p[1] * q[1] - p[2] * q[2] - p[3] * q[3];
  qr[1] = p[0] * q[1] + p[1] * q[0] + p[2] * q[3] - p[3] * q[2];
  qr[2] = p[0] * q[2] - p[1] * q[3] + p[2] * q[0] + p[3] * q[1];
  qr[3] = p[0] * q[3] + p[1] * q[2] - p[2] * q[1] + p[3] * q[0];
void qnormalized(float* q) {
  float invnorm;
  invnorm = fastinvsqrt(q[0] * q[0] + q[1] * q[1] + q[2] * q[2] + q[3] * q[3]);
  if (invnorm < 100000000) {
    q[0] *= invnorm;
    q[1] *= invnorm;
    q[2] *= invnorm;
    q[3] *= invnorm;
  } else {
    q[0] = 1;
    q[1] = 0;
    q[2] = 0;
    q[3] = 0;
float fastinvsqrt(float x) {
  float halfx = 0.5f * x;
  float y = x;
  long i = *(long*)&y;
  i = 0x5f3759df - (i>>1);
  y = *(float*)&i;
  y = y * (1.5f - (halfx * y * y));
  return y;
float MatMulVect(float M[], float V[], int8_t result[]){
  for(uint8_t i=0; i<2; i++){
     result = (M[i*4]*V[0]+M[i*4+1]*V[1]+M[i*4+2]*V[2]+M[i*4+3])/-V[2]*128;
[/code]
GMT+8, 2024-5-7 14:15 , Processed in 0.045961 second(s), 18 queries .
