查看: 20245|回复: 1
arduino驱动57步进电机问题
发表于 2019-10-12 10:28:57 | 显示全部楼层 |阅读模式
就是我想通过串口收到的字符来控制电机的正反转和停止,请大神们看看程序该怎么改,哪里错了,收到1和2都可以转,但是只转动几秒就停了,发送3的时候也没有打印停止到串口,我想让它一直转,收到1就一直正转,收到2 就一直反转,收到3就停止
int PUL_1=7;
int DIR_1=6;
int val;
    Serial.begin(9600);//设置波特率为9600
    pinMode(DIR_1,OUTPUT);
    pinMode(PUL_1,OUTPUT);
  val=Serial.read();//读取串口收到的数据
  if (val>'0'&& val<'3')
    if(val== '1')
           digitalWrite(DIR_1,HIGH); //电机正转
           Serial.println("正转");
           for(int a=0;a<1000;a++)
           digitalWrite(PUL_1,HIGH);
           delayMicroseconds(400);
           digitalWrite(PUL_1,LOW);
    else if(val=='2')
          digitalWrite(DIR_1,LOW);     //电机反转
           Serial.println("反转");
     else if(val== '3')
           Serial.println("停止");
发表于 2019-10-12 14:53:18 | 显示全部楼层
  1. int PUL_1=7;
  2. int DIR_1=6;
  3. int inByte;
  4. // Variables will change:
  5. int ledState = LOW;
  6. unsigned long previousMillis = 0;
  7. // constants won't change:
  8. const long interval = 400;
  9. void setup() {
  10.     Serial.begin(9600);
  11.     pinMode(DIR_1,OUTPUT);
  12.     pinMode(PUL_1,OUTPUT);
  13. }
  14. void loop() {
  15.   unsigned long currentMillis = millis();
  16.
  17.   if(Serial.available())
  18.   {
  19.       inByte = Serial.read();
  20.       Serial.println(inByte);
  21.   }
  22.
  23.
  24.   if (currentMillis - previousMillis >= interval) {
  25.     previousMillis = currentMillis;
  26.     if(inByte != '3'){
  27.       if (ledState == LOW)
  28.         ledState = HIGH;
  29.       else
  30.         ledState = LOW;
  31.     }
  32.   }
  33.   if(inByte == '1')
  34.     digitalWrite(DIR_1,HIGH);
  35.   else if(inByte == '2')
  36.     digitalWrite(DIR_1,LOW);
  37.   digitalWrite(PUL_1, ledState);
  38. }
GMT+8, 2024-5-5 12:26 , Processed in 0.041218 second(s), 18 queries .
