查看: 25362|回复: 2
LGT8F328P 看门狗中断无法启用问题。
发表于 2020-2-18 12:27:46 | 显示全部楼层 |阅读模式
网上类似问题:https://forum.arduino.cc/index.php?topic=599892.msg4075726
附件的例子nano下可以正常运行,但是LGT8F328P就会不停复位,根据手册也没找到语法问题。
难道有某些的寄存器导致单片机周期和nano不一致了?
WDTCSR  =(1<<WDIE)|(1<<WDP2)|(1<<WDP1)|(1<<WDP0);  这个是8秒一次溢出产生中断。
发表于 2020-3-17 10:10:01 | 显示全部楼层
用专门的库
  1.   #include <PMU.h>
和 nano 不一样
写SD卡貌似也得用专门的库
 楼主| 发表于 2020-6-6 17:47:51 | 显示全部楼层
  1. #include "PMU.h"
  2. volatile int kan_mengou=0;
  3. void setup() {
  4.   pinMode(13, OUTPUT);   digitalWrite(13, LOW);
  5. Serial.begin(9600);Serial.println("Start");
  6. delay(3333);
  7. ADCSRA = 0;
  8.
  9.   PMU.sleep(PM_POFFS1,SLEEP_8S);
  10. }
  11. String _10_to_2_string(byte a){
  12.    byte   e=B10000000;String A;
  13.     for (int j=0;j<=7;j++)
  14.                 { if(e&a  ) A=A+"1";
  15.                         else A=A+"0";e=e>>1;
  16.
  17.                   }
  18.      String         s= A; s= s.substring(0,4)+" "+s.substring(4,8);
  19.      int aa=8-s.length();
  20.      for (int jj=0;jj<=aa;jj++) s="0"+s;
  21.
  22.       return (s);
  23. }
  24.           //设定为 溢出中断 及 8s的狗
  25. //                                   //看门狗预分频选择列表:
  26. //WDP3 WDP2 WDP1 WDP0   看门狗定时器溢出周期数     32KHz时钟   2MHz时钟
  27. //0 0 0 0                                  2K cycles 64ms 1ms
  28. //0 0 0 1                                   4K cycles 128ms 2ms
  29. //0 0 1 0                                   8K cycles 256ms 4ms
  30. //0 0 1 1                                    16K cycles 512ms 8ms
  31. //0 1 0 0                                      32K cycles 1s 16ms
  32. //0 1 0 1                                     64K cycles 2s 32ms
  33. //0 1 1 0                                     128K cycles 4s 64ms
  34. //0 1 1 1                                     256K cycles 8s 128ms
  35. //1 0 0 0                                      512K cycles 16s 256ms
  36. //1 0 0 1                                      1024K cycles 32s 512ms
  37.
  38.
  39.
  40. void loop()
  41. { kan_mengou=kan_mengou+1;
  42.
  43.    if(kan_mengou>=2){
  44.   Serial.begin(9600);Serial.println( "   WDIF    WDIE  WDP3  WDCE            WDE   WDP2   WDP1    WDP0 ");
  45.    Serial.print ( _10_to_2_string ( WDTCSR));
  46.    Serial.println("    I have sleep in :"+String(kan_mengou )+"*8");
  47.       pinMode(13, OUTPUT); digitalWrite(13, 1);
  48.      delay(5333);
  49.      pinMode(13, OUTPUT); digitalWrite(13, 0);
  50.      kan_mengou=0;
  51.   PMU.sleep(PM_POFFS1,SLEEP_8S);
  52.    }
  53. else
  54. PMU.sleep(PM_POFFS1, SLEEP_8S);  //SLEEP_32S SLEEP_8S
  55. }
GMT+8, 2024-5-2 16:47 , Processed in 0.041974 second(s), 19 queries .
