查看: 26562|回复: 1
用arduino NANO 做的485通讯控制小灯的点亮
发表于 2020-5-13 13:12:45 | 显示全部楼层 |阅读模式
但10引脚不能正常控制小灯的点亮,求大神们指导下!!
int c=0;
int var=0;
int a=0;
uint8_t buffer[2]="a1";
String comdata="";
String str;
String tcaspass;
String tcasfail;
String topant;
String botant;
String hdg;
String ralog;
String tadisp;
String radisp;
String radalt;
String xpdrbus;
String att;
int testPin = 13; // 按键的管脚定义
  Serial.begin(9600,SERIAL_8O1);
  pinMode(testPin, INPUT_PULLUP); //设置按键管脚上拉输入模式
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
void Recive485()
    while (Serial.available() > 0)
      comdata += char(Serial.read());
        delay(2);
   if (comdata.length() > 0)
  // Serial.println(comdata);
       str=comdata;
       comdata = "";
void Send()
  if(digitalRead(testPin) == HIGH)
  buffer[1]=0x41;
  buffer[1]=0x31;
  Serial.write(buffer,2);
  Serial.println(" ");
  delay(100);
  digitalWrite(10,LOW);
void choose()
  if (digitalRead(testPin) == HIGH)        //有按键按下
    delay(20);                        //延时去抖动
         digitalWrite(2,HIGH);
         digitalWrite(3,HIGH);
         digitalWrite(4,HIGH);
         digitalWrite(5,HIGH);
         digitalWrite(6,HIGH);
         digitalWrite(7,HIGH);
         digitalWrite(8,HIGH);
         digitalWrite(9,HIGH);
         digitalWrite(10,HIGH);
         digitalWrite(11,HIGH);
         digitalWrite(12,HIGH);
         delay(3000);
         digitalWrite(2,LOW);
         digitalWrite(3,LOW);
         digitalWrite(4,LOW);
         digitalWrite(5,LOW);
         digitalWrite(6,LOW);
         digitalWrite(7,LOW);
         digitalWrite(8,LOW);
         digitalWrite(9,LOW);
         digitalWrite(11,LOW);
         digitalWrite(12,LOW);
          if(str.length()==47)
     tcaspass=str.substring(0,2);
     if(tcaspass=="A1"){digitalWrite(2,LOW);}
     if(tcaspass=="A2"){digitalWrite(2,HIGH);}
     tcasfail=str.substring(2,4);
     if(tcasfail=="B1"){digitalWrite(4,LOW);}
     if(tcasfail=="B2"){digitalWrite(4,HIGH);}
     topant=str.substring(4,6);
     if(topant=="C1"){digitalWrite(6,LOW);}
     if(topant=="C2"){digitalWrite(6,HIGH);}
     botant=str.substring(6,8);
     if(botant=="D1"){digitalWrite(8,LOW);}
     if(botant=="D2"){digitalWrite(8,HIGH);}
     hdg=str.substring(8,10);
     if(hdg=="E1"){digitalWrite(10,LOW);}
     if(hdg=="E2"){digitalWrite(10,HIGH);}
     ralog=str.substring(10,12);
     if(ralog=="F1"){digitalWrite(12,LOW);}
     if(ralog=="F2"){digitalWrite(12,HIGH);}
     tadisp=str.substring(12,14);
     if(tadisp=="G1"){digitalWrite(3,LOW);}
     if(tadisp=="G2"){digitalWrite(3,HIGH);}
     radisp=str.substring(14,16);
     if(radisp=="H1"){digitalWrite(5,LOW);}
     if(radisp=="H2"){digitalWrite(5,HIGH);}
     radalt=str.substring(16,18);
     if(radalt=="I1"){digitalWrite(7,LOW);}
     if(radalt=="I2"){digitalWrite(7,HIGH);}
     xpdrbus=str.substring(18,20);
     if(xpdrbus=="J1"){digitalWrite(9,LOW);}
     if(xpdrbus=="J2"){digitalWrite(9,HIGH);}
     att=str.substring(20,22);
     if(att=="K1"){digitalWrite(11,LOW);}
     if(att=="K2"){digitalWrite(11,HIGH);}
   Recive485();
   Send();
   choose();
GMT+8, 2024-5-2 14:14 , Processed in 0.058379 second(s), 18 queries .
