查看: 27505|回复: 2
CD74HC4067 模块的使用
发表于 2020-5-20 21:46:13 | 显示全部楼层 |阅读模式
  CD74HC4067 作用是选通一路对十六路模拟信号,就像一个单刀多掷开关,根据芯片上 S0-S3 四个不同管脚的组合,让SIG管脚和C0-C15导通(每次只能连接一个),它适用于数字和模拟信号,可以只用5针最多连接16传感器系统,也可以用它来管理多个设备。
//测量换算每个Pin的电压
这个芯片的使用方法非常简单,例如: S0-S3 分别是 0 0 0 0时,SIG就和 C0是导通的。因此,这里我做一个实验,将一些电阻串联起来,分别接在C1 C3 C5 C9 C11 上面,然后测量换算每个Pin的电压.
[kenrobot_code]//Mux control pins
int s0 = 7;
int s1 = 6;
int s2 = 5;
int s3 = 4;
//Mux in "SIG" pin
int SIG_pin = 0;
        pinMode(s0, OUTPUT);
        pinMode(s1, OUTPUT);
        pinMode(s2, OUTPUT);
        pinMode(s3, OUTPUT);
        digitalWrite(s0, LOW);
        digitalWrite(s1, LOW);
        digitalWrite(s2, LOW);
        digitalWrite(s3, LOW);
        int v;
        //Loop through and read all 16 values
        //Reports back Value at channel 6 is: 346
        for(int i = 0; i < 16; i ++)
                Serial.print("Value at channel ");
                Serial.print(i);
                Serial.print(" is : ");
                v = readMux(i);
                Serial.println(v * 5.0 / 1024);
        Serial.println(" ");
        delay(3000);
int readMux(int channel)
        int controlPin[] = {s0, s1, s2, s3};
        int muxChannel[16][4] =
                {0, 0, 0, 0}, //channel 0
                {1, 0, 0, 0}, //channel 1
                {0, 1, 0, 0}, //channel 2
                {1, 1, 0, 0}, //channel 3
                {0, 0, 1, 0}, //channel 4
                {1, 0, 1, 0}, //channel 5
                {0, 1, 1, 0}, //channel 6
                {1, 1, 1, 0}, //channel 7
                {0, 0, 0, 1}, //channel 8
                {1, 0, 0, 1}, //channel 9
                {0, 1, 0, 1}, //channel 10
                {1, 1, 0, 1}, //channel 11
                {0, 0, 1, 1}, //channel 12
                {1, 0, 1, 1}, //channel 13
                {0, 1, 1, 1}, //channel 14
                {1, 1, 1, 1} //channel 15
        //loop through the 4 sig
        for(int i = 0; i < 4; i ++)
                digitalWrite(controlPin, muxChannel[channel]);
        //read the value at the SIG pin
        int val = analogRead(SIG_pin);
        //return the value
        return val;
GMT+8, 2024-5-2 17:01 , Processed in 0.040968 second(s), 18 queries .
