查看: 2704|回复: 0
如何实现视觉识别形状
发表于 2023-4-14 09:51:43 | 显示全部楼层 |阅读模式
1. 功能说明
       通过摄像头识别圆形及矩形两种形状。
2. 电子硬件
      本实验中采用了以下硬件:
主控板
Basra主控板(兼容Arduino Uno)
扩展板
Bigfish2.1扩展板
电池7.4V锂电池
通信2510通信转接板
WiFi路由器
其它
摄像头
配置OpenCV的Visual Studio 2015.net环境的计算机一台
3. 功能实现
    工作原理:
          ① 导入一张图片或者通过WiFi传递摄像信息给PC;
          ② 在PC端使用OpenCV对图像转化为灰度图像;
          ③ 检测圆形和矩形。
    检测圆形使用霍夫变换:
  1. vector<Vec3f> circles;
  2. HoughCircles(image, circles, HOUGH_GRADIENT, 2.0,
  3. image.rows/8, // change this value to detect circles with different distances to each other
  4. 200, 85, 0, 0 // change the last two parameters
  5.   // (min_radius & max_radius) to detect larger circles
  6. );
    检测矩形:
  1. //多边形检测,通过约束条件寻找矩形
  2. static void findSquares(const Mat& image, vector<vector<Point> >& squares)
  3. {
  4. squares.clear();
  5. Mat pyr, timg, gray0(image.size(), CV_8U), gray;
  6. // down-scale and upscale the image to filter out the noise
  7. pyrDown(image, pyr, Size(image.cols / 2, image.rows / 2));
  8. pyrUp(pyr, timg, image.size());
  9. vector<vector<Point> > contours;
  10. // find squares in every color plane of the image
  11. for (int c = 0; c < 3; c++)
  12. {
  13. int ch[] = { c, 0 };
  14. mixChannels(&timg, 1, &gray0, 1, ch, 1);
  15. // try several threshold levels
  16. for (int l = 0; l < N; l++)
  17. {
  18. // hack: use Canny instead of zero threshold level.
  19. // Canny helps to catch squares with gradient shading
  20. if (l == 0)
  21. {
  22. // apply Canny. Take the upper threshold from slider
  23. // and set the lower to 0 (which forces edges merging)
  24. Canny(gray0, gray, 0, thresh, 5);
  25. // dilate canny output to remove potential
  26. // holes between edge segments
  27. dilate(gray, gray, Mat(), Point(-1, -1));
  28. }
  29. else
  30. {
  31. // apply threshold if l!=0:
  32. //     tgray(x,y) = gray(x,y) < (l+1)*255/N ? 255 : 0
  33. gray = gray0 >= (l + 1) * 255 / N;
  34. }
  35. // find contours and store them all as a list
  36. findContours(gray, contours, RETR_LIST, CHAIN_APPROX_SIMPLE);
  37. vector<Point> approx;
  38. // test each contour
  39. for (size_t i = 0; i < contours.size(); i++)
  40. {
  41. // approximate contour with accuracy proportional
  42. // to the contour perimeter
  43. approxPolyDP(Mat(contours[i]), approx, arcLength(Mat(contours[i]), true)*0.02, true);
  44. // square contours should have 4 vertices after approximation
  45. // relatively large area (to filter out noisy contours)
  46. // and be convex.
  47. // Note: absolute value of an area is used because
  48. // area may be positive or negative - in accordance with the
  49. // contour orientation
  50. if (approx.size() == 4 &&
  51. fabs(contourArea(Mat(approx))) > 1000 &&
  52. isContourConvex(Mat(approx)))
  53. {
  54. double maxCosine = 0;
  55. for (int j = 2; j < 5; j++)
  56. {
  57. // find the maximum cosine of the angle between joint edges
  58. double cosine = fabs(angle(approx[j % 4], approx[j - 2], approx[j - 1]));
  59. maxCosine = MAX(maxCosine, cosine);
  60. }
  61. // if cosines of all angles are small
  62. // (all angles are ~90 degree) then write quandrange
  63. // vertices to resultant sequence
  64. if (maxCosine < 0.3)
  65. squares.push_back(approx);
  66. }
  67. }
  68. }
  69. }
  70. }
3.1硬件连接
     将摄像头与路由器连接,启动路由器,将PC连接到路由器的WIFI网络。
接线说明:
       ① 将2510通信转接板连接到扩展板的扩展坞上面;
       ② 用3根母对母杜邦线将2510通信转接板与WiFi路由器连接起来,GND-GND、RX-RX、TX-TX;
       ③ 找到1根USB线,一端连接到2510通信转接板接口上,另一端连接到WiFi路由器USB接口上;
       ④ 将摄像头线连接到WiFi路由器接口上。
3.2示例程序
     下面提供一个可以进行识别圆形和矩形的参考例程(ShapeDetect\ShapeDetect\MainWindow.xaml.cs):
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Threading.Tasks;
  6. using System.Windows;
  7. using System.Windows.Controls;
  8. using System.Windows.Data;
  9. using System.Windows.Documents;
  10. using System.Windows.Input;
  11. using System.Windows.Media;
  12. using System.Windows.Media.Imaging;
  13. using System.Windows.Navigation;
  14. using System.Windows.Shapes;
  15. using System.Windows.Forms;
  16. using System.Runtime.InteropServices;
  17. using System.Threading;
  18. namespace ShapeDetect
  19. {
  20.     /// <summary>
  21.     /// 形状识别
  22.     /// </summary>
  23.     public partial class MainWindow : Window
  24.     {
  25.         //定义检测模式
  26.         int IMAGE_MODE = 1, VIDEO_MODE = 2;
  27.         private AutoResetEvent exitEvent;
  28.         private Thread m_thread;
  29.         //导入动态链接库
  30.         [DllImport("HoughCircles_DLL.dll")]
  31.         //检测圆
  32.         public static extern System.UIntPtr HoughCircles([MarshalAs(UnmanagedType.LPStr)]string address, int detect_mode);
  33.         [DllImport("SquareDetect_DLL.dll")]
  34.         //检测矩形
  35.         public static extern void SquareDetector([MarshalAs(UnmanagedType.LPStr)]string address, int detect_mode);
  36.         public MainWindow()
  37.         {
  38.             InitializeComponent();
  39.         }
  40.         private void Window_Loaded(object sender, RoutedEventArgs e)
  41.         {
  42.             GetIni();
  43.             imgCheckBtn.IsChecked = true;
  44.             circleCheckBtn.IsChecked = true;
  45.         }
  46.         //获取ini配置文件信息
  47.         private void GetIni()
  48.         {
  49.             ini_RW.FileName = System.Windows.Forms.Application.StartupPath + "\\Config.ini";
  50.             this.videoAddress.Text = ini_RW.ReadIni("VideoUrl", "videourl", "");
  51.             this.ipAddress.Text = ini_RW.ReadIni("ControlUrl", "controlUrl", "");
  52.             this.portBox.Text = ini_RW.ReadIni("ControlPort", "controlPort", "");
  53.         }
  54.         //修改配置
  55.         private void setBtn_Click(object sender, RoutedEventArgs e)
  56.         {
  57.             ini_RW.WriteIni("VideoUrl", "videourl", this.videoAddress.Text);
  58.             ini_RW.WriteIni("ControlUrl", "controlUrl", this.ipAddress.Text);
  59.             ini_RW.WriteIni("ControlPort", "controlPort", this.portBox.Text);
  60.             System.Windows.MessageBox.Show("配置成功!请重启程序以使配置生效。", "配置信息", MessageBoxButton.OK, MessageBoxImage.Information);
  61.             //this.Close();
  62.         }
  63.         //计数清零
  64.         private void BoxClean()
  65.         {
  66.             circleTextBox.Text = "0";
  67.             recTextBox.Text = "0";
  68.         }
  69.         //打开图片地址
  70.         private void imgBtn_Click(object sender, RoutedEventArgs e)
  71.         {
  72.             try
  73.             {
  74.                 BoxClean();
  75.                 //WPF中,OpenFileDialog位于Microsoft.Win32名称空间
  76.                 Microsoft.Win32.OpenFileDialog dialog = new Microsoft.Win32.OpenFileDialog();
  77.                 dialog.Filter = "All files (*.*)|*.*|jpg files (*.jpg)|*.jpg|png files(*.png)|*.png";
  78.                 if (dialog.ShowDialog() == true)
  79.                 {
  80.                     string path = dialog.FileName;
  81.                     imgAddressBox.Text = path;
  82.                 }
  83.             }
  84.             catch { };
  85.         }
  86.         //检测形状判断
  87.         private void ShapeDetect(string address, int mode)
  88.         {
  89.             if (circleCheckBtn.IsChecked == true)
  90.             {
  91.                 //System.Windows.MessageBox.Show("检测圆形");
  92.                 circleTextBox.Text = HoughCircles(address, mode).ToString();
  93.             }
  94.             else if (recCheckBtn.IsChecked == true)
  95.             {
  96.                 //System.Windows.MessageBox.Show("检测矩形");
  97.                 SquareDetector(address, mode);
  98.             }
  99.         }
  100.         //图片检测
  101.         private void imgDetect()
  102.         {
  103.             if (imgAddressBox.Text == string.Empty)
  104.             {
  105.                 System.Windows.MessageBox.Show(
  106.                     "图片地址为空,请选择一张图片", "警告",
  107.                     MessageBoxButton.OK,
  108.                     MessageBoxImage.Information
  109.                     );
  110.                 return;
  111.             }
  112.             else
  113.             {
  114.                 ShapeDetect(imgAddressBox.Text, IMAGE_MODE);
  115.             }
  116.         }
  117.         //视频检测
  118.         private void videoDetect()
  119.         {
  120.             try
  121.             {
  122.                 while (true)
  123.                 {
  124.                     this.Dispatcher.Invoke(
  125.                         new Action(
  126.                             delegate
  127.                             {
  128.                                 string ip = this.videoAddress.Text;
  129.                                 ShapeDetect(ip, VIDEO_MODE);
  130.                             }
  131.                             ));
  132.                 }
  133.             }
  134.             catch { };
  135.         }
  136.         //判断检测为图片还是视频,开启形状检测
  137.         private void detectBtn_Click(object sender, RoutedEventArgs e)
  138.         {
  139.             BoxClean();
  140.             if (imgCheckBtn.IsChecked == true)
  141.             {
  142.                 imgDetect();
  143.             }
  144.             else if (videoCheckBtn.IsChecked == true)
  145.             {
  146.                 try
  147.                 {
  148.                     m_thread = new Thread(new ThreadStart(videoDetect));
  149.                     m_thread.Start();
  150.                 }
  151.                 catch { };
  152.             }
  153.         }
  154.         //按esc键退出视频检测,结束线程
  155.         private void Window_KeyDown(object sender, System.Windows.Input.KeyEventArgs e)
  156.         {
  157.             if (e.Key == Key.Escape)
  158.             {
  159.                 exitEvent.Set();
  160.                 m_thread.Join();
  161.             }
  162.         }
  163.     }
  164. }
      程序识别圆形及矩形两种形状,包括对图像以及视频中的物体的形状检测,可参考上面的演示视频进行操作。图片中物体的形状识别,文末资料下载中提供一张测试图片,然后选择图片按钮,选择要检测的圆形或者矩形,点击形状检测。
视频中的形状识别,选择视频按钮,选择要检测的圆形或者矩形,点击形状检测,可以使用球体或者矩形状物体进行检测。
4. 资料下载
资料内容:
​①识别形状-例程源代码
资料下载地址:https://www.robotway.com/h-col-200.html
GMT+8, 2024-5-3 10:01 , Processed in 0.041129 second(s), 17 queries .
