查看: 548|回复: 1
求助,关于arduino SD卡,能帮我看看程序吗,谢谢!
发表于 2024-3-31 20:11:30 | 显示全部楼层 |阅读模式
想做一个从SD卡里的文件用拼音查询汉字的程序,但是File file=SD.open("1.txt",FILE_READ); 这一句只能写到递归函数里,写到初始化里在递归函数里就不能操作文件了,是什么情况?怎么改进呢?
以下是全部代码:
  1. #include<SD.h>
  2. #include<SPI.h>
  3. #include<String.h>
  4. unsigned long fileLength=0;//文件长度
  5. unsigned long poipos=0;//文件指针位置
  6. File file;
  7. String matchPinyin(String);
  8. String search(String,unsigned long,unsigned long);
  9. void setup() {
  10.   // put your setup code here, to run once:
  11.   Serial.begin(115200);
  12.   Serial.println(SD.begin(SPI_HALF_SPEED, 4));
  13.   File file=SD.open("1.txt",FILE_READ);
  14.   fileLength=file.available();
  15.   file.close();
  16.   Serial.println("汉字");
  17.   Serial.println(matchPinyin("a "));
  18.   Serial.println(matchPinyin("zuo "));
  19.   Serial.println(matchPinyin("hao "));
  20.   Serial.println("done");
  21. }
  22. String matchPinyin(String val)
  23. {
  24.   return search(val,0,fileLength);
  25. }
  26. String search(String val,unsigned long a,unsigned long b)//传递原值,首位,末位,识别位数
  27. {
  28.   char word=0;//缓存所取
  29.   int sub=0;//比较下标
  30.   File file=SD.open("1.txt",FILE_READ);
  31.   unsigned long mid=a/2+b/2;
  32.   Serial.print(a);
  33.   Serial.print(",");
  34.   Serial.print(b);
  35.   Serial.print(":");
  36.   Serial.println(mid);
  37.   if((b-a)<2)
  38.   {
  39.     return "";
  40.   }
  41.   //Serial.println("front find");
  42.   file.seek(mid);
  43.   while(file.peek()!=10/*不是换行*/)//连续向上查询
  44.   {
  45.     /*Serial.print("    ");
  46.     Serial.print(mid);
  47.     Serial.print(" ");
  48.     Serial.println(file.peek());*/
  49.     mid--;
  50.     file.seek(mid);
  51.   }
  52.   //Serial.println("back find");
  53.   poipos=mid;
  54.   while(file.peek()!=9/*不是空格*/)//连续向下查询
  55.   {
  56.     /*Serial.print("    ");
  57.     Serial.print(file.peek());
  58.     Serial.print(" ");
  59.     Serial.println(char(file.peek()));*/
  60.     file.seek(++poipos);
  61.   }
  62.   while(file.seek(++poipos),(word=file.peek())!='\r'/*不是回车*/)//依次比较
  63.   {
  64.     /*Serial.print("   ");
  65.     Serial.print(char(val[sub]));
  66.     Serial.print("==");
  67.     Serial.print(char(word));*/
  68.     if(val[sub]==word)
  69.     {
  70.       sub++;
  71.     }
  72.     else if(word>val[sub])//从前寻找
  73.     {
  74.       Serial.println("front");
  75.       yield();
  76.       file.close();
  77.       return(search(val,a,(a+b)/2));
  78.     }
  79.     else if(word<val[sub])//从后寻找
  80.     {
  81.       Serial.println("back");
  82.       yield();
  83.       file.close();
  84.       return(search(val,(a+b)/2,b));
  85.     }
  86.   }
  87.   //此次选择正确
  88.   String ret="";
  89.   file.seek(++mid);
  90.   while(file.peek()!=9)
  91.   {
  92.     ret+=char(file.read());
  93.   }
  94.   file.close();
  95.   return ret;
  96. }
  97. void loop() {
  98.   // put your main code here, to run repeatedly:
  99.
  100. }
以下是代码高亮的图片,和需要打开的文件:
 楼主| 发表于 2024-3-31 20:13:46 | 显示全部楼层
GMT+8, 2024-5-1 04:38 , Processed in 0.044723 second(s), 18 queries .
