上次附件传错了,这里道下歉哈~已经更新
最近淘宝上出了一些mini版的12864,使用SPI连接方式,外形非常小巧,价格十分低廉,刷新速度比一般的大号LCD12864快很多,而且支持作图。
由于到手后苦于无法用arduino驱动,通过搜索发现Ladyade做过ST7565的arduino驱动库,遂直接挖过来,结果屏幕左右颠倒,从中间分成两半,无法正常显示,于是经过一晚上的摸索,终于修正了参数,成功使用,下面我就共享一下库及其程序。
PS:如果要显示图片,可以直接使用弘毅的BMP转十六进制的字模软件,但是设置要改成纵向生成8位。
库:
实例程序:- // Zzz
- #include "ST7565.h"
- int ledPin = 13;
- #define BACKLIGHT_LED 10
- ST7565 glcd(9, 8, 7, 6, 5);
- #define LOGO16_GLCD_HEIGHT 16
- #define LOGO16_GLCD_WIDTH 16
- static unsigned char __attribute__ ((progmem)) logo16_glcd_bmp[]={
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0xF0,0xF0,0x30,
- 0x30,0xF0,0xE0,0xC0,0x10,0xF0,0xF0,0x10,0xF0,0xF0,0x90,0xC0,0xF0,0x70,0x10,0x00,
- 0x00,0x00,0xFE,0xFE,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFE,0xE0,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xE0,0xE0,0xF0,0xF0,0xF0,0xF0,0xF0,0xE0,
- 0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xE0,0xF0,0xF8,0xF8,0xF8,0x78,
- 0x38,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
- 0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x3E,0x3F,0x33,0x30,
- 0x38,0x1F,0x2F,0x30,0x3F,0x3F,0x31,0x00,0x30,0x3F,0x3F,0x23,0x00,0x00,0x00,0x00,
- 0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFE,0x80,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x80,0xF0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xF8,0xFC,0xFC,0xFC,0xF8,
- 0xF8,0xF8,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x00,0xC0,0xE0,0xF8,0xFC,0xFE,0xFF,0x7F,0x1F,0x0F,0x07,0x03,0x00,0x00,
- 0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0x0F,0x0F,0x0F,0x0F,0x1F,0x1F,0x1F,
- 0x1F,0x0F,0x00,0xF8,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,
- 0xFC,0xFC,0xF8,0xF8,0xF0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x01,0x0F,0xFF,0xFF,0xFF,0xFF,0xFC,0x80,
- 0x00,0x00,0x00,0x80,0xF0,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0x07,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xFE,0xFF,0xFF,0x7F,0x0F,0x0F,0x7F,
- 0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFC,0xFF,0x7F,0x3F,0x1F,0x3F,0xFF,0xFF,0xFC,0xF0,0xF0,0xE0,0x80,0x00,0x00,0x00,
- 0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x80,0x80,0x80,0x80,0x80,
- 0x80,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x07,0x7F,0xFF,0xFF,0xFF,
- 0xFC,0xE0,0xF0,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFE,0x00,0x00,0x00,0x00,0x80,0xF8,0xFF,0xFF,0xFF,0xFF,0xF0,0xF0,0xF0,0xF0,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x80,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0x03,0x01,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,
- 0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
- 0x7F,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x0F,0x0F,0x1F,0x3F,0xFF,0xFF,0xFF,
- 0xFF,0xE7,0x87,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x7F,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0x00,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x01,0x01,0x01,0x01,
- 0x01,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0xC0,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0xC0,
- 0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x01,0x07,0x3F,
- 0xFF,0xFF,0xFF,0xFE,0xF0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0F,0x0F,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
- 0x07,0x07,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x03,0x03,
- 0x03,0x03,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x07,0x01,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x03,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x1F,0x3F,0x3F,0x3F,0x3F,0x3F,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x07,0x0F,0x1F,0x3F,0x3F,0x3F,0x3F,0x1F,
- 0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
- 0xF0,0xF0,0xF0,0xE7,0xE7,0xE7,0xE7,0xE7,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x03,0x07,0x07,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x01,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
- 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- void setup() {
- Serial.begin(9600);
- pinMode(BACKLIGHT_LED, OUTPUT);
- digitalWrite(BACKLIGHT_LED, LOW);
- glcd.st7565_init();
- glcd.st7565_command(CMD_DISPLAY_ON);
- glcd.st7565_command(CMD_SET_ALLPTS_NORMAL);
- glcd.st7565_set_brightness(0x00);
- glcd.clear();
- glcd.drawbitmap(0, 0, logo16_glcd_bmp,128, 64, BLACK);
- glcd.display();
- delay(50000);
- glcd.clear();
- glcd.drawstring(0,0, "LCD12864 Testing");
- glcd.drawstring(0,3, "Control IC ST7565LCD");
- glcd.drawstring(0,6, "library Re-Design Zzz");
- glcd.display();
- delay(7000);
- glcd.clear();
- void loop()
