查看: 9718|回复: 0
三轴加速度曲线
发表于 2013-9-5 16:08:59 | 显示全部楼层 |阅读模式
我在processing中,通过串口读数据,画图,得出来的结果是这样。这是为什么么?
代码是:
RawX[RawX.length-1] = Sensor_X;
  RawY[RawY.length-1] = Sensor_Y;   // place the new raw datapoint at the end of the array
  RawZ[RawZ.length-1] = Sensor_Z;
  zoom = scaleBar.getPos();                      // get current waveform scale value
  offset = map(zoom,0.5,1,300,0);                // calculate the offset needed at this scale
  for (int i = 0; i < RawX.length-1; i++) {      // move the pulse waveform by
    RawX[i] = RawX[i+1];                         // shifting all raw datapoints one pixel left
    float dummy = RawX[i] * zoom + offset;       // adjust the raw data to the selected scale
    ScaledX[i] = constrain(int(dummy),44,556);   // transfer the raw data array to the scaled array
       for (int i = 0; i < RawY.length-1; i++) {      // move the pulse waveform by
    RawY[i] = RawY[i+1];                         // shifting all raw datapoints one pixel left
    float dummy = RawY[i] * zoom + offset;       // adjust the raw data to the selected scale
    ScaledY[i] = constrain(int(dummy),44,556);   // transfer the raw data array to the scaled array
    for (int i = 0; i < RawZ.length-1; i++) {      // move the pulse waveform by
    RawZ[i] = RawZ[i+1];                         // shifting all raw datapoints one pixel left
    float dummy = RawZ[i] * zoom + offset;       // adjust the raw data to the selected scale
    ScaledZ[i] = constrain(int(dummy),44,556);   // transfer the raw data array to the scaled array
  //stroke(250,0,0);                               // red is a good color for the pulse waveform
  noFill();
  beginShape();                                  // using beginShape() renders fast
  for (int x = 1; x < RawX.length-1;x++) {
    stroke(255,0,0);
    vertex(x+10, ScaledX[x]);
  endShape();
  for (int x = 1; x < RawY.length-1;x++) {
    stroke(0,255,0);
    vertex(x+10, ScaledY[x]);
  endShape();
  for (int x = 1; x < RawZ.length-1;x++) {
    stroke(0,0,255);
    vertex(x+10, ScaledZ[x]);
  endShape();
GMT+8, 2024-4-28 14:03 , Processed in 0.040113 second(s), 18 queries .
