闲来没事,发现以往买了带时钟两点的4位数码管,于是用Microduino RTC做了个时钟显示,感觉挺好的,正符合Microduino小巧的特点。上个图:
这里就不详细介绍四位数码管,因为数码管引脚不确定,每个厂家生产的都不一样。只需测出其引脚,通过更改程序就行。讲讲如何测量:
1.确定四位数码管的位码(哪个引脚点亮哪位数码管);
2.确定数码管的段码(a,b,c,d,e,f,g,dp);
程序:
如果需要调试时间需要把代码 vosettime()取消注释(把//去掉),再在初始化设置时间函数void vosettime()里改时间参数后下载就行;如果要掉电后继续运行,必须把vosettime()注释掉,加上//。如果不注释,掉电后重启,时间是设置的初始值。
- #include <Wire.h>
- #include <Rtc_Pcf8563.h>
- Rtc_Pcf8563 rtc;//初始化实时时钟
- #define Duan1 0
- #define Duan2 3
- #define Duan3 4
- #define Duan4 8
- #define Colon1 6
- #define Colon2 7
- int timehourg,timehours,timeming,timemins;
- int timeyear1,timeyear2;
- int timemouth1,timemouth2;
- int timeday1,timeday2;
- long data[10]=
- 0xfc,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xF6
- void setup()
- // Serial.begin(115200);
- for(int x=0;x<14;x++)
- pinMode(x,OUTPUT);//设置输出引脚
- //vosettime();
- void loop()
- rtc.formatDate();
- rtc.formatTime();
- timehours=rtc.getHour()/10;
- timehourg=rtc.getHour()%10;
- timemins=rtc.getMinute()/10;
- timeming=rtc.getMinute()%10;
- timeyear1=rtc.getYear()/10;
- timeyear2=rtc.getYear()%10;
- timemouth1=rtc.getMonth()/10;
- timemouth2=rtc.getMonth()%10;
- timeday1=rtc.getDay()/10;
- timeday2=rtc.getDay()%10;
- daytime();
- for(int i=0;i<500;i++)
- datetime();
- datatime();
- Serial.print("TIME:");
- Serial.print("20");
- Serial.print(rtc.getYear());
- Serial.print("/");
- Serial.print(rtc.getMonth());
- Serial.println(rtc.getDay());
- Serial.print(rtc.getHour());
- Serial.print(":");
- Serial.print(rtc.getMinute());
- Serial.println(rtc.getSecond());
- delay(1000);
- //显示时间
- void daytime()
- duanma(1);
- leddisplay(data[timehours]);
- delay(3);
- duanma(2);
- leddisplay(data[timehourg]);
- delay(3);
- duanma(3);
- leddisplay(data[timemins]);
- delay(3);
- duanma(4);
- leddisplay(data[timeming]);
- delay(3);
- if(rtc.getSecond()%2==0)
- digitalWrite(Colon1, LOW);
- digitalWrite(Colon2, HIGH);
- else
- digitalWrite(Colon1, HIGH);
- digitalWrite(Colon2, LOW);
- //显示月、日
- void datatime()
- duanma(1);
- leddisplay(data[timemouth1]);
- delay(3);
- duanma(2);
- leddisplay(data[timemouth2]);
- delay(3);
- duanma(3);
- leddisplay(data[timeday1]);
- delay(3);
- duanma(4);
- leddisplay(data[timeday2]);
- delay(3);
- //显示年
- void datetime()
- duanma(1);
- leddisplay(data[2]);
- delay(3);
- duanma(2);
- leddisplay(data[0]);
- delay(3);
- duanma(3);
- leddisplay(data[timeyear1]);
- delay(3);
- duanma(4);
- leddisplay(data[timeyear2]);
- delay(3);
- //=======================初始化设置时间函数===========================//
- void vosettime()
- rtc.initClock();
- //day, weekday, month, century(1=1900, 0=2000), year(0-99)
- rtc.setDate(21, 6, 12, 0, 13);
- //hr, min, sec
- rtc.setTime(20, 44, 50);
- void leddisplay(int num) // 数组数据移位输出
- 先将16进制数向右移x位(num>>x),x代表了microduinoI/O口对应16进制的某位,
- 0是最低位,7是最高位。再将移的数据与0x01按位与,就可以得到16进制数某位的
- 数据(0或1),再将其值赋值给microduino的I/O就行。
- digitalWrite(11, ((num>>0)&0x01));
- digitalWrite(9, ((num>>1)&0x01));
- digitalWrite(2, ((num>>2)&0x01));
- digitalWrite(13, ((num>>3)&0x01));
- digitalWrite(12, ((num>>4)&0x01));
- digitalWrite(10, ((num>>5)&0x01));
- digitalWrite(5, ((num>>6)&0x01));
- digitalWrite(1,((num>>7)&0x01));
- void duanma(int x)
- switch(x)
- case 1:
- digitalWrite(Duan1, LOW);
- digitalWrite(Duan2, HIGH);
- digitalWrite(Duan3, HIGH);
- digitalWrite(Duan4, HIGH);
- break;
- case 2:
- digitalWrite(Duan1, HIGH);
- digitalWrite(Duan2, LOW);
- break;
- case 3:
- digitalWrite(Duan3, LOW);
- break;
- case 4:
- digitalWrite(Duan4, LOW);
- break;
复制代码 |
