//We connect CS to 3.3V to tell the sensor we will be using it as an I2C device, and not an SPI device.
IDE环境:Arduino1.0.5
- #include <Wire.h>
- #define ADXLAddress (0x53) //ADXL345的I2C地址(ADDR接地)
- int xAcc, yAcc, zAcc; // 存放加速度值
- int buff[6]; //存放寄存器高低位值,X、Y、Z轴共6个
- // 加速度传感器误差修正的偏移量
- int a_offx = 0;
- int a_offy = 0;
- int a_offz = 0;
- void writeRegister(int deviceAddress, byte address, byte val)
- Wire.beginTransmission(deviceAddress);
- Wire.write(address);
- Wire.write(val);
- Wire.endTransmission();
- void readRegister(int deviceAddress, byte address)
- Wire.requestFrom(deviceAddress, 6);
- int i = 0;
- while(Wire.available())
- { buff[i++] = Wire.read(); }
- void initAcc()
- //配置ADXL345,ADXL345采用默认的+-2g量程,10位分辨率
- writeRegister (ADXLAddress, 0x2C, 0x09);//设置输出数据速率50Hz,带宽25Hz。
- //默认值为0x0A,对应输出数据速率100Hz,带宽50Hz
- writeRegister (ADXLAddress, 0x2D, 0x08); //设置ADXL345为测量模式。
- void getAccData()
- readRegister(ADXLAddress, 0x32);
- xAcc = ((buff[1] << 8) | buff[0] )+ a_offx;
- yAcc = ((buff[3] << 8) | buff[2] )+ a_offy;
- zAcc = ((buff[5] << 8) | buff[4]) + a_offz;
- void setup()
- Serial.begin(9600);
- Wire.begin();
- initAcc();
- delay(50);
- void loop()
- getAccData();
- Serial.print("xAcc=");
- Serial.print(xAcc);
- Serial.print(" yAcc=");
- Serial.print(yAcc);
- Serial.print(" zAcc=");
- Serial.println(zAcc);
- delay(200);
其它相关帖子:
加速度计和陀螺仪指南
I2C通信之Arduino与陀螺仪传感器ITG3205 |
