楼主 |
发表于 2014-2-5 00:08:53
显示全部楼层
davidce 发表于 2014-2-4 23:42
无代码,无接线图
我自己也有用官方的liquidcrystal库的测试程序。
代码如下(RW口直接接地,所以代码里没有设计,pin12接RS引脚,pin11接使能端,pin6到pin9对应D4到D7)
#include <LiquidCrystal.h>
// Initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 10, 6, 7, 8, 9); // Create an lcd object and assign the pins
lcd.begin(16, 2); // Set the display to 16 columns and 2 rows
// Run the seven demo routines
basicPrintDemo();
displayOnOffDemo();
setCursorDemo();
scrollLeftDemo();
scrollRightDemo();
cursorDemo();
createGlyphDemo();
void basicPrintDemo() {
lcd.clear(); // Clear the display
lcd.print("Basic Print"); // Print some text
delay(2000);
void displayOnOffDemo() {
lcd.print("Display On/Off"); // Print some text
for(int x=0; x < 3; x++) { // Loop 3 times
lcd.noDisplay(); // Turn display off
delay(1000);
lcd.display(); // Turn it back on again
delay(1000);
void setCursorDemo() {
lcd.print("SetCursor Demo"); // Print some text
delay(1000);
lcd.setCursor(5,0); // Cursor at column 5 row 0
lcd.print("5,0");
delay(2000);
lcd.setCursor(10,1); // Cursor at column 10 row 1
lcd.print("10,1");
delay(2000);
lcd.setCursor(3,1); // Cursor at column 3 row 1
lcd.print("3,1");
delay(2000);
void scrollLeftDemo() {
lcd.print("Scroll Left Demo");
delay(1000);
lcd.setCursor(7,0);
lcd.print("Beginning");
lcd.setCursor(9,1);
lcd.print("Arduino");
delay(1000);
for(int x=0; x<16; x++) {
lcd.scrollDisplayLeft(); // Scroll display left 16 times
delay(250);
void scrollRightDemo() {
lcd.print("Scroll Right");
lcd.setCursor(0,1);
lcd.print("Demo");
delay(1000);
lcd.setCursor(0,1);
delay(1000);
lcd.scrollDisplayRight(); // Scroll display right 16 times
delay(250);
void cursorDemo() {
lcd.cursor(); // Enable cursor visible
lcd.print("Cursor On");
delay(3000);
lcd.noCursor(); // Cursor invisible
lcd.print("Cursor Off");
delay(3000);
lcd.cursor(); // Cursor visible
lcd.blink(); // Cursor blinking
lcd.print("Cursor Blink On");
delay(3000);
lcd.noBlink(); // Blink off
void createGlyphDemo() {
lcd.clear();
byte happy[8] = { // Create byte array with happy face
B00000,
B00000,
B10001,
B00000,
B10001,
B01110,
B00000,
B00000};
byte sad[8] = { // Create byte array with sad face
B00000,
B00000,
B10001,
B00000,
B01110,
B10001,
B00000,
B00000};
lcd.createChar(0, happy); // Create custom character 0
lcd.createChar(1, sad); // Create custom character 1
for(int x=0; x<5; x++) { // Loop animation 5 times
lcd.setCursor(8,0);
lcd.write(0); // Write custom char 0
delay(1000);
lcd.setCursor(8,0);
lcd.write(1); // Write custom char 1
delay(1000);
