楼主 |
发表于 2014-3-22 10:07:00
显示全部楼层
oldbeginner 发表于 2014-3-22 08:30
protocol.c 中
protocol.c 下1
#define EXEC_STATUS_REPORT bit(0) // bitmask 00000001
#define EXEC_CYCLE_START bit(1) // bitmask 00000010
#define EXEC_CYCLE_STOP bit(2) // bitmask 00000100
#define EXEC_FEED_HOLD bit(3) // bitmask 00001000
#define EXEC_RESET bit(4) // bitmask 00010000
#define EXEC_ALARM bit(5) // bitmask 00100000
#define EXEC_CRIT_EVENT bit(6) // bitmask 01000000
Define system executor bit map. Used internally by runtime protocol as runtime command flags, which notifies the main program to execute the specified runtime command asynchronously.
NOTE: The system executor uses an unsigned 8-bit volatile variable (8 flag limit.)
The default flags are always false, so the runtime protocol only needs to check for a non-zero value to know when there is a runtime command to execute.
内容7 ();
Executes run-time commands, when required.
This is called from various check points in the main program, primarily where there may be a while loop waiting for a buffer to clear space or any point where the execution time from the last check point may be more than a fraction of a second.
This is a way to execute runtime commands asynchronously (aka multitasking) with grbl's g-code parsing and planning functions. This function also serves as an interface for the interrupts to set the system runtime flags, where only the main program handles them, removing the need to define more computationally-expensive volatile variables. This also provides a controlled way to execute certain tasks without having two or more instances of the same task, such as the planner recalculating the buffer upon a feedhold or override.
NOTE: The sys.execute variable flags are set by any process, step or serial interrupts, pinouts, limit switches, or the main program.
void protocol_execute_runtime()
if (sys.execute) { // Enter only if any bit flag is true
uint8_t rt_exec = sys.execute; // Avoid calling volatile multiple times
内容7A();
System alarm. Everything has shutdown by something that has gone severely wrong.
Report the source of the error to the user. If critical, Grbl disables by entering an infinite loop until system reset/abort.
内容7A();
内容7B();
内容7C();
内容7D();
内容7E();
内容7F();
内容7G();
内容7B();
Critical event. Only hard limit qualifies. Update this as new critical events surface.
if (rt_exec & (EXEC_ALARM | EXEC_CRIT_EVENT)) {
sys.state = STATE_ALARM; // Set system alarm state
if (rt_exec & EXEC_CRIT_EVENT) {
report_alarm_message(ALARM_HARD_LIMIT);
report_feedback_message(MESSAGE_CRITICAL_EVENT);
bit_false(sys.execute,EXEC_RESET); // Disable any existing reset
} else {
report_alarm_message(ALARM_ABORT_CYCLE);
bit_false(sys.execute,(EXEC_ALARM | EXEC_CRIT_EVENT));
内容7C();
Execute system abort.
if (rt_exec & EXEC_RESET) {
sys.abort = true; // Only place this is set true.
return; // Nothing else to do but exit.
内容7D();
Execute and serial print status
if (rt_exec & EXEC_STATUS_REPORT) {
report_realtime_status();
bit_false(sys.execute,EXEC_STATUS_REPORT);
内容7E();
Initiate stepper feed hold
if (rt_exec & EXEC_FEED_HOLD) {
st_feed_hold(); // Initiate feed hold.
bit_false(sys.execute,EXEC_FEED_HOLD);
内容7F();
Reinitializes the stepper module running state and, if a feed hold, re-plans the buffer.
NOTE: EXEC_CYCLE_STOP is set by the stepper subsystem when a cycle or feed hold completes.
if (rt_exec & EXEC_CYCLE_STOP) {
st_cycle_reinitialize();
bit_false(sys.execute,EXEC_CYCLE_STOP);
内容7G();
if (rt_exec & EXEC_CYCLE_START) {
st_cycle_start(); // Issue cycle start command to stepper subsystem
if (bit_istrue(settings.flags,BITFLAG_AUTO_START)) {
sys.auto_start = true; // Re-enable auto start after feed hold.
bit_false(sys.execute,EXEC_CYCLE_START);
信息量太大,先整理,以后慢慢看。
内容8
Directs and executes one line of formatted input from protocol_process.
While mostly incoming streaming g-code blocks, this also executes Grbl internal commands, such as settings, initiating the homing cycle, and toggling switch states.
This differs from the runtime command module by being susceptible to when Grbl is ready to execute the next line during a cycle, so for switches like block delete, the switch only effects the lines that are processed afterward, not necessarily real-time during a cycle, since there are motions already stored in the buffer.
However, this 'lag' should not be an issue, since these commands are not typically used during a cycle.
uint8_t protocol_execute_line(char *line)
// Grbl internal command and parameter lines are of the form '$4=374.3' or '$' for help
if(line[0] == '$') {
uint8_t char_counter = 1;
uint8_t helper_var = 0; // Helper variable
float parameter, value;
switch( line[char_counter] ) {
内容8A();
return(STATUS_OK); // If '$' command makes it to here, then everything's ok.
} else {
return(gc_execute_line(line)); // Everything else is gcode
内容8A();
case 0 : 内容8B();
case '$': 内容8C();
case '#' : 内容8D();
case 'G' : 内容8E();
case 'C' : 内容8F();
case 'X' : 内容8G();
case 'H' : 内容8H();
case 'N' : 内容8I();
default : 内容8J();
内容8B();
report_grbl_help(); break;
内容8C();
Prints Grbl settings $
if ( line[++char_counter] != 0 )
{ return(STATUS_UNSUPPORTED_STATEMENT); }
{ report_grbl_settings(); }
内容8D();
Print gcode parameters #
{ report_gcode_parameters(); }
内容8E();
Prints gcode parser state G
{ report_gcode_modes(); }
内容8F();
Set check g-code mode C
if ( sys.state == STATE_CHECK_MODE ) {
mc_reset();
report_feedback_message(MESSAGE_DISABLED);
} else {
if (sys.state)
{ return(STATUS_IDLE_ERROR); }
sys.state = STATE_CHECK_MODE;
report_feedback_message(MESSAGE_ENABLED);
Perform reset when toggling off. Check g-code mode should only work if Grbl is idle and ready, regardless of alarm locks.
This is mainly to keep things simple and consistent.
内容8G();
Disable alarm lock X
if (sys.state == STATE_ALARM) {
report_feedback_message(MESSAGE_ALARM_UNLOCK);
sys.state = STATE_IDLE;
// Don't run startup script. Prevents stored moves in startup from causing accidents.
内容8H();
Perform homing cycle H
if (bit_istrue(settings.flags,BITFLAG_HOMING_ENABLE)) {
// Only perform homing if Grbl is idle or lost.
if ( sys.state==STATE_IDLE || sys.state==STATE_ALARM ) {
mc_go_home();
if (!sys.abort)
{ protocol_execute_startup(); } // Execute startup scripts after successful homing.
} else
} else
{ return(STATUS_SETTING_DISABLED); }
内容8I();
Startup lines. N
if ( line[++char_counter] == 0 ) { // Print startup lines
for (helper_var=0; helper_var < N_STARTUP_LINE; helper_var++) {
if (!(settings_read_startup_line(helper_var, line))) {
report_status_message(STATUS_SETTING_READ_FAIL);
} else {
report_startup_line(helper_var,line);
} else { // Store startup line
helper_var = true; // Set helper_var to flag storing method.
// No break. Continues into default: to read remaining command characters.
内容8J();
Storing setting methods
if(!read_float(line, &char_counter, ¶meter))
{ return(STATUS_BAD_NUMBER_FORMAT); }
if(line[char_counter++] != '=')
if (helper_var) { // Store startup line
// Prepare sending gcode block to gcode parser by shifting all characters
helper_var = char_counter; // Set helper variable as counter to start of gcode block
do {
line[char_counter-helper_var] = line[char_counter];
} while (line[char_counter++] != 0);
// Execute gcode block to ensure block is valid.
helper_var = gc_execute_line(line); // Set helper_var to returned status code.
if (helper_var) { return(helper_var); }
else {
helper_var = trunc(parameter); // Set helper_var to int value of parameter
settings_store_startup_line(helper_var,line);
} else { // Store global setting.
if(!read_float(line, &char_counter, &value))
if(line[char_counter] != 0)
return(settings_store_global_setting(parameter, value));
上面的代码解释了下面的命令
https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.8
Grbl Internal Commands:
Technically, the remaining Grbl commands are not configuration commands, but we're going to explain them here for no good reason, other than for completeness.
The three current state commands: $G, $#, ?
Grbl provides three commands to report its current state and where it is. Of the three, one of them is real-time, responding with current position. The other two are not, but respond with how incoming blocks are going to be processed depending on the states set by g-code, settings, or switches. The reason they are not realtime is that Grbl has an internal buffer that stores and plans the buffered motions. The incoming gcode blocks just tack on a new motion at the end of the buffer when it has room. The buffer basically ensures Grbl motion move at the fastest and safest rates possible, constantly re-calculating it real-time as motions finish and new ones come in.
$G - View gcode parser state
This command prints all of the active gcode modes that the parser will interpret any incoming command. These modes include G20/G21 inches/mm mode, G54-G59 active work coordinate system, G0/G1/G2/G3 active motion mode, G17/G18/G19 active plane selection, G90/G91 absolute mode, G93/G94 inverse feed rate mode, M0/M1/M2 program flow, M3/M4/M5 spindle state, M8/M9 coolant state, T tool number, and F active feed rate. It will also list any active $Sx Grbl switches, like $S1 block delete. When called, Grbl will return a line like this:
[G0 G54 G17 G21 G90 G94 M0 M5 M9 T0 F500.000]
$# - View gcode parameters
G-code parameters generally store the G54-G59 work coordinate offsets and G28/G30 home positions (must not be confused with homing and machine zero. These home positions can be set anywhere in the machine space by the G28.1/G30.1 commands). Most of these parameters are directly written to EEPROM anytime they are changed and are persistent. Meaning that they will remain the same, regardless of power-down, until they are explicitly changed.
G54-G59 work coordinates can be changed via the G10 L2 Px or G10 L20 Px command defined by the NIST gcode standard and the EMC2 (linuxcnc.org) standard. G28/G30 home positions can be changed via the G28.1 and the G30.1 commands, respectively. Please note that G92 is not persistent or held in EEPROM per g-code standards, and will reset to zero when Grbl is reset. Please read these g-code standard to understand how they are used.
When $# is called, Grbl will respond with the stored offsets from machine coordinates for each system as follows.
[G54:4.000,0.000,0.000]
[G55:4.000,6.000,7.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:1.000,2.000,0.000]
[G30:4.000,6.000,0.000]
[G92:0.000,0.000,0.000]
For the most part, these offset are not particularly useful unless you have homing enabled. If you do have homing enabled, these are wonderfully awesome, because once you home, you can always move back to same stored position by using the work coordinate systems within the accuracy of your machine. Or if you are making multiple parts and have a tool path for just one part, all you have to do is setup your work coordinate systems to the location where the next part is going to be made and re-run that same code.
? - Current status
The ? command immediately returns Grbl's active state and the real-time current position, both in machine coordinates and work coordinates. This may be sent at any time and works asynchronously with all other processes that Grbl is doing. The $13 Grbl setting determines whether it reports millimeters or inches. When ? is pressed, Grbl will immediately reply with something like the following:
<Idle,MPos:5.529,0.560,7.000,WPos:1.529,-5.440,-0.000>
The active states Grbl can be in are: Idle, Queue, Run, Hold, Home, Alarm, Check
Idle: All systems are go and it's ready for anything.
Queue: Motion(s) are queued in the planner buffer waiting for a cycle start command to be issued. Certain processes like check g-code mode can't run while something is queued. Reset to clear the queue.
Run: Indicates a cycle is running.
Hold: A feed hold is in process of executing, or slowing down to a stop. After the hold is complete, Grbl will enter a Queue state, waiting for a cycle start to resume the program.
Home: In the middle of a homing cycle. NOTE: Positions are not updated live during the homing cycle, but they'll be set to [0,0,0] once done.
Alarm: This indicates something has gone wrong or Grbl doesn't know its position. This state locks out all g-code commands, but allows you to interact with Grbl's settings if you need to. '$X' kill alarm lock releases this state and puts Grbl in the Idle state, which will let you move things again. As said before, be cautious of what you are doing after an alarm.
Check: Grbl is in check g-code mode. It will process and respond to all g-code commands, but not motion or turn on anything. Once toggled off with another '$C' command, Grbl will reset itself.
Other Commands $C $X $H ~ ! Ctrl-X
$C - Check gcode mode
This toggles the Grbl's gcode parser to take all incoming blocks process them completely, as it would in normal operation, but it does not move any of the axes, ignores dwells, and powers off the spindle and coolant. This is intended as a way to provide the user a way to check how their new g-code program fares with Grbl's parser and monitor for any errors. (And eventually this will also check for soft limit violations.)
When toggled off, Grbl will perform an automatic soft-reset (^X). This is for two purposes. It simplifies the code management a bit. But, it also prevents users from starting a job when their g-code modes are not what they think they are. A system reset always gives the user a fresh, consistent start.
NOTE: Eventually, the check gcode mode could be re-factored to allow for a "program resume" feature in Grbl. This means that Grbl could start a g-code program anywhere. It would internally go through all of the g-code program up to the desired mid-program resume point to set all of the parser states and locations, move to that start point, and begin executing/moving from that point on. For example, say you had to E-stop in the middle of a program because you forgot something or you have the wrong tool in the spindle. Your part is fine and need to restart the program. Right now, you'll have to start the program from the beginning and let it physically move and run up to the point where you e-stopped. If you have a long program, this could take a while. Instead, a "program resume" will just go through the beginning of the program internally, without moving anything, and only begin moving from the resume point on.
$X - Kill alarm lock
Grbl's alarm mode is a state when something has gone critically wrong, like a hard limit or an abort during a cycle, or if Grbl doesn't know its position. By default, if you have homing enabled and power-up the Arduino, Grbl enters the alarm state, because it does not know its position. The alarm mode will lock all g-code blocks until the '$H' homing cycle has been performed. Or if a user needs to override the alarm lock to move their axes off their limit switches, for example, '$X' kill alarm lock will override the locks and allow g-code functions to work again.
But, tread carefully!! This should only be used in emergency situations. The position has likely been lost, and Grbl may not be where you think it is. So, it's advised to use G91 incremental mode to make short moves. Then, perform a homing cycle or reset immediately afterwards.
$H - Run homing cycle
This command is the only way to perform the homing cycle in Grbl. Previously, G28 and G30 would automatically start the homing cycle, but this is incorrect according to the g-code standards. Homing is a completely separate command handled by the controller. G28 and G30 only move to a 'home'/pre-defined position that is stored in the g-code parameters, which can be located anywhere in the machine.
TIP: After running a homing cycle, rather jogging manually all the time to a position in the middle of your workspace volume. You can set a G28 or G30 pre-defined position to be your post-homing position, closer to where you'll be machining. To set these, you'll first need to jog your machine to where you would want it to move to after homing. Type G28.1 (or G30.1) to have Grbl store that position. So then after '$H' homing, you could just enter 'G28' (or 'G30') and it'll move there auto-magically. In general, I would just move the XY axis to the center and leave the Z-axis up. This ensures that there isn't a chance the tool in the spindle doesn't catch on anything.
~ - Cycle start
This is the cycle start or resume command that can be issued at any time, as it is a real-time command. When Grbl has motions queued in its buffer and is ready to go, the ~ cycle start command will start executing the buffer and Grbl will begin moving the axes. However, by default, auto-cycle start is enabled, so new users will not need this command unless a feed hold is performed. When a feed hold is executed, cycle start will resume the program. Cycle start will only be effective when there are motions in the buffer ready to go and will not work with any other process like homing.
! - Feed hold
The feed hold command will bring the active cycle to a stop via a controlled deceleration, so not to lose position. It is also real-time and may be activated at any time. Once finished or paused, Grbl will wait until a cycle start command is issued to resume to program. Feed hold can only pause a cycle and will not affect homing or any other process.
If you need to stop a cycle mid-program and can't afford losing position, perform a feed hold to have Grbl bring everything to a controlled stop. Once finished, you can then issue a reset. Always try to execute a feed hold whenever the machine is running before hitting reset, except of course if there is some emergency situation.
Ctrl-x - Reset Grbl
This is Grbl's soft reset command. It's real-time and can be sent at any time. As the name implies, it resets Grbl, but in a controlled way, retains your machine position, and all done without powering down your Arduino. The only times a soft-reset could lose position is when problems like if the steppers were killed while they were moving. If so, it will report if Grbl's tracking of the machine position has been lost. This is because an uncontrolled deceleration can lead to lost steps, and Grbl has no feedback to how much it lost (this is the problem with steppers in general). Otherwise, Grbl will just re-initialize, run the startup lines, and continue on its merry way.
Please note that it's recommended to do a soft-reset before starting a job. This guarantees that there aren't any g-code modes active that should be from playing around or setting up your machine. So, your machine will always starts fresh and consistently, and your machine does what you expect it to.
