查看: 10668|回复: 3
请问用arduino和grbl做的激光雕刻如何控制激光通断呢
发表于 2014-3-26 17:13:56 | 显示全部楼层 |阅读模式
如题  根据网站上的教程 我的雕刻机基本可以运行了 现在就是如何控制激光通断呢 因为不控制通断的话 画出来的总是多好多线 谢谢了
发表于 2014-3-28 17:00:48 | 显示全部楼层
看源代码参数,控制电机对应的是哪根pin
 楼主| 发表于 2014-3-30 20:49:51 | 显示全部楼层
因为只是用了两个轴 用哪个端口控制激光的都没好到呢
这是配置文件
  // Serial port pins
  #define SERIAL_RX USART_RX_vect
  #define SERIAL_UDRE USART_UDRE_vect
  // NOTE: All step bit and direction pins must be on the same port.
  #define STEPPING_DDR       DDRD
  #define STEPPING_PORT      PORTD
  #define X_STEP_BIT         2  // Uno Digital Pin 2
  #define Y_STEP_BIT         3  // Uno Digital Pin 3
  #define Z_STEP_BIT         4  // Uno Digital Pin 4
  #define X_DIRECTION_BIT    5  // Uno Digital Pin 5
  #define Y_DIRECTION_BIT    6  // Uno Digital Pin 6
  #define Z_DIRECTION_BIT    7  // Uno Digital Pin 7
  #define STEP_MASK ((1<<X_STEP_BIT)|(1<<Y_STEP_BIT)|(1<<Z_STEP_BIT)) // All step bits
  #define DIRECTION_MASK ((1<<X_DIRECTION_BIT)|(1<<Y_DIRECTION_BIT)|(1<<Z_DIRECTION_BIT)) // All direction bits
  #define STEPPING_MASK (STEP_MASK | DIRECTION_MASK) // All stepping-related bits (step/direction)
  #define STEPPERS_DISABLE_DDR    DDRB
  #define STEPPERS_DISABLE_PORT   PORTB
  #define STEPPERS_DISABLE_BIT    0  // Uno Digital Pin 8
  #define STEPPERS_DISABLE_MASK (1<<STEPPERS_DISABLE_BIT)
  // NOTE: All limit bit pins must be on the same port
  #define LIMIT_DDR       DDRB
  #define LIMIT_PIN       PINB
  #define LIMIT_PORT      PORTB
  #define X_LIMIT_BIT     1  // Uno Digital Pin 9
  #define Y_LIMIT_BIT     2  // Uno Digital Pin 10
  #define Z_LIMIT_BIT     3  // Uno Digital Pin 11
  #define LIMIT_INT       PCIE0  // Pin change interrupt enable pin
  #define LIMIT_INT_vect  PCINT0_vect
  #define LIMIT_PCMSK     PCMSK0 // Pin change interrupt register
  #define LIMIT_MASK ((1<<X_LIMIT_BIT)|(1<<Y_LIMIT_BIT)|(1<<Z_LIMIT_BIT)) // All limit bits
  #define SPINDLE_ENABLE_DDR   DDRB
  #define SPINDLE_ENABLE_PORT  PORTB
  #define SPINDLE_ENABLE_BIT   4  // Uno Digital Pin 12
  #define SPINDLE_DIRECTION_DDR   DDRB
  #define SPINDLE_DIRECTION_PORT  PORTB
  #define SPINDLE_DIRECTION_BIT   5  // Uno Digital Pin 13 (NOTE: D13 can't be pulled-high input due to LED.)
  #define COOLANT_FLOOD_DDR   DDRC
  #define COOLANT_FLOOD_PORT  PORTC
  #define COOLANT_FLOOD_BIT   3  // Uno Analog Pin 3
  // NOTE: Uno analog pins 4 and 5 are reserved for an i2c interface, and may be installed at
  // a later date if flash and memory space allows.
  // #define ENABLE_M7  // Mist coolant disabled by default. Uncomment to enable.
  #ifdef ENABLE_M7
    #define COOLANT_MIST_DDR   DDRC
    #define COOLANT_MIST_PORT  PORTC
    #define COOLANT_MIST_BIT   4 // Uno Analog Pin 4
  #endif
  // NOTE: All pinouts pins must be on the same port
  #define PINOUT_DDR       DDRC
  #define PINOUT_PIN       PINC
  #define PINOUT_PORT      PORTC
  #define PIN_RESET        0  // Uno Analog Pin 0
  #define PIN_FEED_HOLD    1  // Uno Analog Pin 1
  #define PIN_CYCLE_START  2  // Uno Analog Pin 2
  #define PINOUT_INT       PCIE1  // Pin change interrupt enable pin
  #define PINOUT_INT_vect  PCINT1_vect
  #define PINOUT_PCMSK     PCMSK1 // Pin change interrupt register
  #define PINOUT_MASK ((1<<PIN_RESET)|(1<<PIN_FEED_HOLD)|(1<<PIN_CYCLE_START))
 楼主| 发表于 2014-3-31 17:20:33 | 显示全部楼层
找到了
GMT+8, 2024-5-4 09:50 , Processed in 0.039849 second(s), 19 queries .
