架子撘起来了,但是手头只有2个舵机,没办法看到全貌。很是郁闷。分开测试,到是运行的挺流畅。
来个全家福
这个小孔改造的非常棒,和舵机可以实现无螺丝固定,而且配合很完美。
但愿舵机的轴都是这样。
组装很简单
摆拍一个。。那是马克笔,不是白板笔,如果写上了,就再也擦不掉了
少一个舵机,真是挠头
挥舞起来吧
用手持方式写了一个
猜了半天,才看明白,它写的是 00:02,那个零好圆哦
机架结构似乎还是不太合理,还有修改的余地。过几天弄个完美版的,淘宝开个店卖卖20¥一套预定送螺丝哦!
程序奉上,需要时间模块一个,我是用的DS3231,如果是其他时间模块,。H文件需要改一下。字模文件都是程序里写好的路径,如果感觉它的字实在太难看了,可以自己修改。呵呵
- #define CALIBRATION // enable calibration mode
- //#define REALTIMECLOCK // enable real time clock
- // When in calibration mode, adjust the following factor until the servos move exactly 90 degrees
- #define SERVOFAKTORLEFT 650
- #define SERVOFAKTORRIGHT 650
- // Zero-position of left and right servo
- // When in calibration mode, adjust the NULL-values so that the servo arms are at all times parallel
- // either to the X or Y axis
- #define SERVOLEFTNULL 2250
- #define SERVORIGHTNULL 920
- #define SERVOPINLIFT 2
- #define SERVOPINLEFT 3
- #define SERVOPINRIGHT 4
- // lift positions of lifting servo
- #define LIFT0 1080 // on drawing surface
- #define LIFT1 925 // between numbers
- #define LIFT2 725 // going towards sweeper
- // speed of liftimg arm, higher is slower
- #define LIFTSPEED 1500
- // length of arms
- #define L1 35
- #define L2 55.1
- #define L3 13.2
- // origin points of left and right servo
- #define O1X 22
- #define O1Y -25
- #define O2X 47
- #define O2Y -25
- #include <Time.h>
- #include <Servo.h>
- #include <Wire.h>
- #include <DS3231.h>
- int servoLift = 1500;
- Servo servo1; //
- Servo servo2; //
- Servo servo3; //
- volatile double lastX = 75;
- volatile double lastY = 47.5;
- int last_min = 0;
- void setup()
- Serial.begin(9600);
- Wire.begin();
- drawTo(75.2, 47);
- lift(0);
- servo1.attach(SERVOPINLIFT); // lifting servo
- servo2.attach(SERVOPINLEFT); // left servo
- servo3.attach(SERVOPINRIGHT); // right servo
- delay(1000);
- void loop()
- int i = 0;
- if (last_min != minute()) {
- if (!servo1.attached()) servo1.attach(SERVOPINLIFT);
- if (!servo2.attached()) servo2.attach(SERVOPINLEFT);
- if (!servo3.attached()) servo3.attach(SERVOPINRIGHT);
- lift(0);
- hour();
- while ((i+1)*10 <= hour())
- i++;
- number(3, 3, 111, 1);
- number(5, 25, i, 0.9);
- number(19, 25, (hour()-i*10), 0.9);
- number(28, 25, 11, 0.9);
- i=0;
- while ((i+1)*10 <= minute())
- i++;
- number(34, 25, i, 0.9);
- number(48, 25, (minute()-i*10), 0.9);
- lift(2);
- drawTo(74.2, 47.5);
- lift(1);
- last_min = minute();
- servo1.detach();
- servo2.detach();
- servo3.detach();
- // Writing numeral with bx by being the bottom left originpoint. Scale 1 equals a 20 mm high font.
- // The structure follows this principle: move to first startpoint of the numeral, lift down, draw numeral, lift up
- void number(float bx, float by, int num, float scale) {
- switch (num) {
- case 0:
- drawTo(bx + 12 * scale, by + 6 * scale);
- lift(0);
- bogenGZS(bx + 7 * scale, by + 10 * scale, 10 * scale, -0.8, 6.7, 0.5);
- lift(1);
- break;
- case 1:
- drawTo(bx + 3 * scale, by + 15 * scale);
- lift(0);
- drawTo(bx + 10 * scale, by + 20 * scale);
- drawTo(bx + 10 * scale, by + 0 * scale);
- lift(1);
- break;
- case 2:
- drawTo(bx + 2 * scale, by + 12 * scale);
- lift(0);
- bogenUZS(bx + 8 * scale, by + 14 * scale, 6 * scale, 3, -0.8, 1);
- drawTo(bx + 1 * scale, by + 0 * scale);
- drawTo(bx + 12 * scale, by + 0 * scale);
- lift(1);
- break;
- case 3:
- drawTo(bx + 2 * scale, by + 17 * scale);
- lift(0);
- bogenUZS(bx + 5 * scale, by + 15 * scale, 5 * scale, 3, -2, 1);
- bogenUZS(bx + 5 * scale, by + 5 * scale, 5 * scale, 1.57, -3, 1);
- lift(1);
- break;
- case 4:
- lift(0);
- drawTo(bx + 2 * scale, by + 6 * scale);
- lift(1);
- break;
- case 5:
- drawTo(bx + 2 * scale, by + 5 * scale);
- lift(0);
- bogenGZS(bx + 5 * scale, by + 6 * scale, 6 * scale, -2.5, 2, 1);
- drawTo(bx + 5 * scale, by + 20 * scale);
- drawTo(bx + 12 * scale, by + 20 * scale);
- lift(1);
- break;
- case 6:
- drawTo(bx + 2 * scale, by + 10 * scale);
- lift(0);
- bogenUZS(bx + 7 * scale, by + 6 * scale, 6 * scale, 2, -4.4, 1);
- drawTo(bx + 11 * scale, by + 20 * scale);
- lift(1);
- break;
- case 7:
- drawTo(bx + 2 * scale, by + 20 * scale);
- lift(0);
- drawTo(bx + 2 * scale, by + 0);
- lift(1);
- break;
- case 8:
- drawTo(bx + 5 * scale, by + 10 * scale);
- lift(0);
- bogenUZS(bx + 5 * scale, by + 15 * scale, 5 * scale, 4.7, -1.6, 1);
- bogenGZS(bx + 5 * scale, by + 5 * scale, 5 * scale, -4.7, 2, 1);
- lift(1);
- break;
- case 9:
- drawTo(bx + 9 * scale, by + 11 * scale);
- lift(0);
- bogenUZS(bx + 7 * scale, by + 15 * scale, 5 * scale, 4, -0.5, 1);
- drawTo(bx + 5 * scale, by + 0);
- lift(1);
- break;
- case 111:
- lift(0);
- drawTo(70, 46);
- drawTo(65, 43);
- drawTo(65, 49);
- drawTo(5, 49);
- drawTo(5, 45);
- drawTo(65, 45);
- drawTo(65, 40);
- drawTo(5, 40);
- drawTo(5, 35);
- drawTo(65, 35);
- drawTo(65, 30);
- drawTo(5, 30);
- drawTo(5, 25);
- drawTo(65, 25);
- drawTo(65, 20);
- drawTo(5, 20);
- drawTo(60, 44);
- drawTo(75.2, 47);
- lift(2);
- break;
- case 11:
- drawTo(bx + 5 * scale, by + 15 * scale);
- lift(0);
- bogenGZS(bx + 5 * scale, by + 15 * scale, 0.1 * scale, 1, -1, 1);
- lift(1);
- drawTo(bx + 5 * scale, by + 5 * scale);
- lift(0);
- bogenGZS(bx + 5 * scale, by + 5 * scale, 0.1 * scale, 1, -1, 1);
- lift(1);
- break;
- void lift(char lift) {
- switch (lift) {
- // room to optimize !
- case 0: //850
- if (servoLift >= LIFT0) {
- while (servoLift >= LIFT0)
- servoLift--;
- servo1.writeMicroseconds(servoLift);
- delayMicroseconds(LIFTSPEED);
- else {
- while (servoLift <= LIFT0) {
- servoLift++;
- break;
- case 1: //150
- if (servoLift >= LIFT1) {
- while (servoLift >= LIFT1) {
- servoLift--;
- else {
- while (servoLift <= LIFT1) {
- servoLift++;
- break;
- case 2:
- if (servoLift >= LIFT2) {
- while (servoLift >= LIFT2) {
- servoLift--;
- else {
- while (servoLift <= LIFT2) {
- servoLift++;
- break;
- void bogenUZS(float bx, float by, float radius, int start, int ende, float sqee) {
- float inkr = -0.05;
- float count = 0;
- do {
- drawTo(sqee * radius * cos(start + count) + bx,
- radius * sin(start + count) + by);
- count += inkr;
- while ((start + count) > ende);
- void bogenGZS(float bx, float by, float radius, int start, int ende, float sqee) {
- float inkr = 0.05;
- float count = 0;
- do {
- count += inkr;
- while ((start + count) <= ende);
- void drawTo(double pX, double pY) {
- double dx, dy, c;
- int i;
- // dx dy of new point
- dx = pX - lastX;
- dy = pY - lastY;
- //path lenght in mm, times 4 equals 4 steps per mm
- c = floor(4 * sqrt(dx * dx + dy * dy));
- if (c < 1) c = 1;
- for (i = 0; i <= c; i++) {
- // draw line point by point
- set_XY(lastX + (i * dx / c), lastY + (i * dy / c));
- lastX = pX;
- lastY = pY;
- double return_angle(double a, double b, double c) {
- // cosine rule for angle between c and a
- return acos((a * a + c * c - b * b) / (2 * a * c));
- void set_XY(double Tx, double Ty)
- delay(1);
- double dx, dy, c, a1, a2, Hx, Hy;
- // calculate triangle between pen, servoLeft and arm joint
- // cartesian dx/dy
- dx = Tx - O1X;
- dy = Ty - O1Y;
- // polar lemgth (c) and angle (a1)
- c = sqrt(dx * dx + dy * dy); //
- a1 = atan2(dy, dx); //
- a2 = return_angle(L1, L2, c);
- servo2.writeMicroseconds(floor(((a2 + a1 - M_PI) * SERVOFAKTORLEFT) + SERVOLEFTNULL));
- // calculate joinr arm point for triangle of the right servo arm
- a2 = return_angle(L2, L1, c);
- Hx = Tx + L3 * cos((a1 - a2 + 0.621) + M_PI); //36,5°
- Hy = Ty + L3 * sin((a1 - a2 + 0.621) + M_PI);
- // calculate triangle between pen joint, servoRight and arm joint
- dx = Hx - O2X;
- dy = Hy - O2Y;
- a2 = return_angle(L1, (L2 - L3), c);
- servo3.writeMicroseconds(floor(((a1 - a2) * SERVOFAKTORRIGHT) + SERVORIGHTNULL));
复制代码 |
