查看: 8714|回复: 0
求助!请高手帮我看段程序 问题出在哪?如何解决?
发表于 2014-6-20 10:45:09 | 显示全部楼层 |阅读模式
#include <EEPROM.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include "DHT.h"
#define DHTPIN 9
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
#include <Adafruit_BMP085.h>
Adafruit_BMP085 bmp;
#include <math.h>
int BH1750address = 0x23;//BH1750 I2C地址
byte buff[2];
#include "DS1307.h"
DS1307 clock;
int flag = 0;
int tem_h = 50;
int tem_l = 20;
int hum_h = 40;
int hum_l = 15;
int lux_h = 30;
int lux_l = 10;
{  pinMode(2,INPUT);
   pinMode(3,INPUT);
   pinMode(5,INPUT);
   pinMode(7,INPUT);
   clock.setTime();
   lcd.init();
   bmp.begin();
   dht.begin();
   Wire.begin();
{ float temp = bmp.readTemperature();             //读取温度数据 (BMP085)
  long  pa = bmp.readPressure();   //读取气压数据 (BMP085)
  float hpa = pa /100.0 ;           //将Pa换算成hPa
  int hum = dht.readHumidity();                 //读取湿度(DHT11)
  float lux=BH1750();
  int soil = analogRead(MOISTURE_SENSOR);
       lcd.clear();
        clock.getTime();
        lcd.setCursor(0,0);
        lcd.print(clock.hour, DEC);
        lcd.print(":");
        lcd.print(clock.minute, DEC);
        lcd.print(" ");
        lcd.print(clock.month, DEC);
        lcd.print("/");
        lcd.print(clock.dayOfMonth, DEC);
        lcd.print("/");
        lcd.print(clock.year+2000, DEC);
        lcd.print(" ");
        switch (clock.dayOfWeek)
                case MON:
                  lcd.print("MON");
                case TUE:
                  lcd.print("TUE");
                case WED:
                  lcd.print("WED");
                case THU:
                  lcd.print("THU");
                case FRI:
                  lcd.print("FRI");
                case SAT:
                  lcd.print("SAT");
                case SUN:
                  lcd.print("SUN");
        lcd.print(" ");
     lcd.backlight();
     lcd.setCursor(0,1);
     lcd.print("Hum:");
     lcd.print((int)hum);
     lcd.setCursor(0,2);
     lcd.print("Tem:");
     lcd.print((float)temp,2);
     lcd.setCursor(0,3);
     lcd.print("Pre:");
     lcd.print((float)hpa,0);
     lcd.setCursor(11,1);
     lcd.print("Lux:");
     lcd.print((float)lux,2);
  if((flag==0)&&(digitalRead(2)))
     flag = 1;
     byte temByte_h = (int)(tem_h);
     EEPROM.write(0,temByte_h);
     byte temByte_l = (int)(tem_l);
   EEPROM.write(1,temByte_l);
   byte humByte_h = (int)(hum_h);
   EEPROM.write(2,humByte_h);
   byte humByte_l = (int)(hum_l);
   EEPROM.write(3,humByte_l);
   byte luxByte_h = (int)(lux_h);
   EEPROM.write(4,luxByte_h);
   byte luxByte_l = (int)(lux_l);
   EEPROM.write(5,luxByte_l);
     if(digitalRead(3))
        {  tem_h++;
          delay(100);
       if(digitalRead(5))
        { tem_h--;
         delay(100);
     lcd.clear();
     lcd.backlight();
     lcd.setCursor(0,0);
     lcd.print("Pr0");
     lcd.setCursor(4,0);
     lcd.print("H");
     lcd.setCursor(7,0);
     lcd.print("L");
     lcd.setCursor(11,0);
     lcd.print("pre");
     lcd.setCursor(15,0);
     lcd.print("H");
     lcd.setCursor(18,0);
     lcd.print("L");
     lcd.setCursor(0,1);
     lcd.print("Tem");
     lcd.setCursor(4,1);
     lcd.print(EEPROM.read(0));
     lcd.setCursor(7,1);
     lcd.print(EEPROM.read(1));
     lcd.setCursor(0,2);
     lcd.print("Hum");
     lcd.setCursor(4,2);
     lcd.print(EEPROM.read(2));
     lcd.setCursor(7,2);
     lcd.print(EEPROM.read(3));
     lcd.setCursor(0,3);
     lcd.print("Lux");
     lcd.setCursor(4,3);
     lcd.print(EEPROM.read(4));
     lcd.setCursor(7,3);
     lcd.print(EEPROM.read(5));
if((flag==1)&&(!digitalRead(2)))
    {flag = 2;}
if((flag==2)&&(digitalRead(2)))
    {flag=0;}
   delay(5000);
double BH1750()
  int i=0;
  double  val=0;
  Wire.beginTransmission(BH1750address);
  Wire.write(0x10);//1lx reolution 120ms
  Wire.endTransmission();
  delay(200);
  Wire.requestFrom(BH1750address, 2);
  while(Wire.available()) //
    buff[i] = Wire.read();  // receive one byte
    i++;
  if(2==i)
   val=((buff[0]<<8)|buff[1])/1.2;
  return val;
当我按下2号键切换到温湿度上下限调整时?主程序还在循环运行就切回到原来的温湿度显示上了,如何才能保持在参数调整的界面上,等我参数设置完了,按2号键再切回到主界面。不胜感激!另外我的这个想法用上面的程序合理吗?有没有其他更好的方法。小弟先谢谢了
GMT+8, 2026-6-14 02:24 , Processed in 0.072050 second(s), 17 queries .
