查看: 29833|回复: 8
【求助】Arduino软串口出现乱码
发表于 2014-7-10 15:33:57 | 显示全部楼层 |阅读模式
刚刚接触软串口,用的IDE里面自带的例程文件做的测试。代码如下
  Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  // Open serial communications and wait for port to open:
  Serial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(4800);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
但是软串口反馈的一直是乱码,硬串口正常
发表于 2014-7-10 17:03:15 来自手机 | 显示全部楼层
焊接有问题?
发表于 2014-7-10 17:20:49 | 显示全部楼层
用 serial port 接到 pin 10, 11 嗎?
baud rate 不相同.......
 楼主| 发表于 2014-7-11 09:23:12 | 显示全部楼层
57600是对于硬串口的,4800是对于软串口的。这样调节baud rate时候可以接收到不同串口的数据
发表于 2014-7-11 09:23:46 | 显示全部楼层
有好好的硬件串口为啥还要弄软件串口哦~~~~
需要多串口可以选择1280或者2560多好。
 楼主| 发表于 2014-7-11 10:41:33 | 显示全部楼层
板子太大了
发表于 2014-7-11 11:22:09 | 显示全部楼层
因為不太清楚你的設定, 所以我先問了你是否把 serial (即 port 0,1) 接 port 10,11 測試.
那你是用兩塊板測試嗎?  還是一塊板 port 10 接 port 11?
发表于 2015-5-7 19:34:01 | 显示全部楼层
我么遇到同样问题,难道是板子焊的有问题?
发表于 2015-5-8 15:48:29 | 显示全部楼层
俩串口都用9600
GMT+8, 2026-6-17 07:38 , Processed in 0.050359 second(s), 22 queries .
