这里只能拍一张 代码就中止了 循环不起来
希望正常循环起来 每次拍一张 照片文件名编号递增...不熟悉c 自己改了半天 都不对:
// LinkSprite.com
// Note:
// 1. SD must be formated to FAT16
// 2. As the buffer of softserial has 64 bytes, so the code read 32 bytes each time
// 3. Please add the libaray to the lib path
// * SD card attached to SPI bus as follows:
// ** MOSI - pin 11
// ** MISO - pin 12
// ** CLK - pin 13
// ** CS - pin 4
#include <SoftwareSerial.h>
#include <SD.h>
byte ZERO=0x00;
byte incomingbyte;
SoftwareSerial mySerial(5,6); // Set Arduino pin 5 and 6 as softserial
long int a=0x0000,i=0,j=0,k=0,count=0;
uint8_t MH,ML;
boolean EndFlag=0;
File myFile;
void SendResetCmd();
void SetBaudRateCmd();
void SetImageSizeCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
Serial.begin(38400);
/*wait for serial port to connect. Needed for Leonardo only
while (!Serial)
mySerial.begin(38400);
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(4))
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
byte a[32];
int ii;
SendResetCmd();
delay(4000); //Wait 2-3 second to send take picture command
SendTakePhotoCmd();
while(mySerial.available()>0)
incomingbyte=mySerial.read();
myFile = SD.open("pic.jpg", FILE_WRITE); //The file name should not be too long
while(!EndFlag)
j=0;
k=0;
count=0;
SendReadDataCmd();
delay(20); //for regular
k++;
if((k>5)&&(j<32)&&(!EndFlag))
a[j]=incomingbyte;
if((a[j-1]==0xFF)&&(a[j]==0xD9)) //tell if the picture is finished
EndFlag=1;
j++;
count++;
for(j=0;j<count;j++)
if(a[j]<0x10)
Serial.print("0");
Serial.print(a[j],HEX); // observe the image through serial port
Serial.print(" ");
for(ii=0; ii<count; ii++)
myFile.write(a[ii]);
Serial.println();
i++;
myFile.close();
Serial.print("Finished writing data to file");
while(1);
void SendResetCmd()
mySerial.write(0x56);
mySerial.write(ZERO);
mySerial.write(0x26);
mySerial.write(0x31);
mySerial.write(0x05);
mySerial.write(0x04);
mySerial.write(0x01);
mySerial.write(0x19);
mySerial.write(0x11);
mySerial.write(0x24);
mySerial.write(0x03);
mySerial.write(0x2A);
mySerial.write(0xC8);
mySerial.write(0x36);
MH=a/0x100;
ML=a%0x100;
mySerial.write(0x32);
mySerial.write(0x0c);
mySerial.write(0x0a);
mySerial.write(MH);
mySerial.write(ML);
mySerial.write(0x20);
a+=0x20;
