查看: 48529|回复: 4
求大神 Arduino程序上传不成功 显示系统找不到指定文件
发表于 2014-7-15 20:28:10 | 显示全部楼层 |阅读模式
就是直接打开软件里有的也显示错误
错误信息显示是
avrdude: ser_open(): can't open device "\\.\COM1": 系统找不到指定的文件。
程序
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the Uno and
  Leonardo, it is attached to digital pin 13. If you're unsure what
  pin the on-board LED is connected to on your Arduino model, check
  the documentation at http://arduino.cc
  This example code is in the public domain.
  modified 8 May 2014
  by Scott Fitzgerald
// the setup function runs once when you press reset or power the board
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
错误信息显示是
发表于 2014-7-16 23:45:35 | 显示全部楼层
是还没选对串口。在菜单栏的工具-端口,选别的COM口
回复 支持 1 反对 0
发表于 2015-9-8 15:17:07 | 显示全部楼层
应该是串口被占用了,
可能是其他外部软件,例如Repetier-Host等等;
也可能是内部程序或者其他扩展板,例如蓝牙等等。
发表于 2015-12-1 23:41:39 | 显示全部楼层
你用的应该是win7以上的系统,右击arduino图标,选择“用管理员身份运行”,就可以了。
发表于 2015-12-1 23:49:30 | 显示全部楼层
USB 接口, 正常應該不會是 COM1 的, 樓主是否沒有選 port?
arduino IDE 應該自動隱藏了 COM1 吧, 樓主怎麼會是 COM1 的?
GMT+8, 2026-7-24 13:44 , Processed in 0.041192 second(s), 23 queries .
