查看: 11088|回复: 0
nRF24L01模块不能完成收发
发表于 2014-7-23 11:01:12 | 显示全部楼层 |阅读模式
最近在准备做一套远程采集的东西,使用了nRF24L01模块,在测试的时候,使用了RF24Network类库的例子,helloworld_rx和,接线按照SPI接口(D11,D12,D13),CE为D9,片选CSN为D10。 发送端始终发送失败 显示 Sending...failed,接受端无反应。请问大家知道问题在哪里吗。还有个问题,如果只启动发送端,不启动接受端,发送正常的话会显示 Sending...ok吗
[pre lang="arduino" line="1" file="helloworld_tx"]
Copyright (C) 2012 James Coliz, Jr. <[email protected]>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
* Simplest possible example of using RF24Network
* TRANSMITTER NODE
* Every 2 seconds, send a payload to the receiver node.
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
// nRF24L01(+) radio attached using Getting Started board
RF24 radio(9,10);
// Network uses that radio
RF24Network network(radio);
// Address of our node
const uint16_t this_node = 1;
// Address of the other node
const uint16_t other_node = 0;
// How often to send 'hello world to the other unit
const unsigned long interval = 2000; //ms
// When did we last send?
unsigned long last_sent;
// How many have we sent already
unsigned long packets_sent;
// Structure of our payload
struct payload_t
  unsigned long ms;
  unsigned long counter;
void setup(void)
  Serial.begin(57600);
  Serial.println("RF24Network/examples/helloworld_tx/");
  SPI.begin();
  radio.begin();
  network.begin(/*channel*/ 90, /*node address*/ this_node);
void loop(void)
  // Pump the network regularly
  network.update();
  // If it's time to send a message, send it!
  unsigned long now = millis();
  if ( now - last_sent >= interval  )
    last_sent = now;
    Serial.print("Sending...");
    payload_t payload = { millis(), packets_sent++ };
    RF24NetworkHeader header(/*to node*/ other_node);
    bool ok = network.write(header,&payload,sizeof(payload));
    if (ok)
      Serial.println("ok.");
      Serial.println("failed.");
// vim:ai:cin:sts=2 sw=2 ft=cpp[/code]
GMT+8, 2026-7-27 16:18 , Processed in 0.050309 second(s), 17 queries .
