楼主 |
发表于 2014-7-24 21:02:48
显示全部楼层
注释怎么挂了- const int TrigPin = 8;
- const int EchoPin = 7;//设置超声波端口
- const int Kleft = 3;
- const int Kright = 2;//设置码盘端口
- const int mlf=10;
- const int mlb=11;
- const int mrf=5;
- const int mrb=6;//设置电机接口
- const int IFleft=19;
- const int IFright=18;
- int count_left;
- int count_right;//定义码盘计数器
- long old_time;
- long time;//定义计时器
- int PID=0;
- int I=0;//PID控制用变量
- float cm; //超声测距结果
- void setup()
- pinMode(TrigPin, OUTPUT);
- pinMode(EchoPin, INPUT);//设置超声波
- pinMode(mlf,OUTPUT);
- pinMode(mlb,OUTPUT);
- pinMode(mrf,OUTPUT);
- pinMode(mrb,OUTPUT);//设定电机
- pinMode(Kleft,INPUT);
- pinMode(Kright,INPUT);//码盘
- attachInterrupt(0, Code_right, FALLING);
- attachInterrupt(1, Code_left, FALLING);//中断设置
- void advance(){
- analogWrite(mlf,120+PID);
- digitalWrite(mlb,LOW);
- analogWrite(mrf,120);
- digitalWrite(mrb,LOW);
- }//定义前进函数
- void back(){
- analogWrite(mlb,120+PID);
- digitalWrite(mlf,LOW);
- analogWrite(mrb,120);
- digitalWrite(mrf,LOW);
- }//定义后退函数
- void left(){
- analogWrite(mlb,120);
- }//定义左转函数
- void right(){
- analogWrite(mlf,120);
- }//定义右转函数
- void Stop(){
- }//定义停止函数
- void loop()
- old_time=millis();
- while(millis()-old_time<500){
- advance();
- }//前进并计数
- detachInterrupt(0); // 关闭外部中断0
- detachInterrupt(1); // 关闭外部中断1
- I+=count_right-count_left;
- PID=(count_right-count_left)*4+I;//PI算法
- if(count_right<10||count_right<10){
- while(millis()-old_time<700){
- back();
- while(millis()-old_time<1100){
- Stop();
- while(millis()-old_time<1600){
- left();
- }//防卡死算法
- count_left=0;
- count_right=0;//码盘计数归零
- //超声测距算法(需改进)
- digitalWrite(TrigPin, LOW); //低高低电平发一个短时间脉冲去TrigPin
- delayMicroseconds(2);
- digitalWrite(TrigPin, HIGH);
- delayMicroseconds(10);
- cm = pulseIn(EchoPin, HIGH) / 58.0; //将回波时间换算成cm
- cm = (int(cm * 100.0)) / 100.0; //保留两位小数
- if(cm<30){
- right();
- }//超声避障算法
- if(analogRead(IFleft)<700){
- right();
- if(analogRead(IFright)<700){
- left();
- }//红外避障算法
- attachInterrupt(0, Code_right,FALLING); // 重新开放外部中断0
- attachInterrupt(1, Code_left,FALLING); // 重新开放外部中断1
- //右侧电机码盘计数中断函数
- void Code_right()
- count_right += 1; //右侧编码器码盘计数加一
- //左侧电机码盘计数中断函数
- void Code_left()
- count_left += 1; // 编码器码盘计数加一
复制代码 |
