我的是arduino uno + L293D + 传感器扩展板 连接了HC-05蓝牙模块
当arduino连接USB的时候 通过笔记本串口工具发送“1”, 程序能正常亮灯。
但是当USB拔掉后, L293D独立供电,通过笔记本BlueSoleil千月软件 连接配对蓝牙蓝牙模块后,生成一个串口COM8,我在笔记本上用串口工具打开COM8,发送“1”, arduino程序未能执行。。 应该是串口没收到信息。。
请教各位,怎么弄
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
int val;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
val=Serial.read();
if(val == '1')
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
