查看: 18756|回复: 9
arduino对TXT文件的二分查找
发表于 2014-8-15 18:47:43 | 显示全部楼层 |阅读模式
身份菜鸟,最近一直在再用arduino做Rfid的门禁控制,过程中我做了一个卡号验证,我把卡号存放到SD卡中的一个CHECK.TXT文件中,当刷卡时,遍历这个文件查找卡号,但是由于这个文件中存放数据过多的话,会造成板子反应很长时间,所以就想对txt的查找进行优化,所以才有了下面的代码。txt中的数据是已经排好序有一定格式的。我把读卡的部分摘了出来,遇到的问题是这样的。
上图中,遍历的时候明明已经遍历到了,而且符合判断,为什么就没有执行下面代码呢
if( index == 0)
        Serial.printf("Seccess low = ld, high = %ld\n", curLocation-12, curLocation );
        return true;
[pre lang="arduino" line="1" file="BtSearch"]
#include<SD.h>
const int chip = 4;
long SIZE = 0;
File myfile;
  if(!SD.begin(chip))
    Serial.println("SD init failed");
    return;
  Serial.println("SD done");
  long mm = 0;
  long pos = 0;
  char kk = '\0';
  String ss = "";
  while(Serial.available()>0)
    ss += char(Serial.read());
  if(ss.length() > 0)
    myfile = SD.open("CHECK4.TXT");
    if(myfile)
      SIZE = myfile.size();
      Serial.printf("size = %ld\n", SIZE);
      Serial.println("SD error");
      return;
    String strCard ="JCDJ000001";
    if(cmpCard(0,SIZE,strCard))
      Serial.println("Seccess!!");
      myfile.close();
      Serial.println("failed!!");
    ss = "";
String GetCard(long pLocation, long& NewLocation)
  String str = "";
  char ch = '\0';
  myfile.seek(pLocation);
  while(myfile.available())
    ch = myfile.read();
    if(ch == '\n')
      str.trim();
      if(str[0] != 'J' || str[1] != 'C' || str[2] != 'D' )
        str = "";
  //    Serial.printf("str[0] = %c, str[1] = %c, str[2] = %c\n",str[0],str[1],str[2]);
      if(!str.equals(""))
        NewLocation = myfile.position();
        str.trim();
        Serial.println(str);
        return str;
      if(ch != ' ' || ch != '  ')
        str += ch;
bool cmpCard(long low, long high, String strCard)
  long mid = 0;
  long curLocation = 0;
  int index = 0;
  String strGet = "";
  if(low < high)
    if(high-low < 40)
      strGet = GetCard(low, curLocation);
/*     index = strGet.compareTo(strCard);
      if( index == 0)
        return true;
        return cmpCard(curLocation, high, strCard);
      mid = (low+high)/2;
      strGet = GetCard(mid, curLocation);
    delay(20);
    index = (int)strGet.compareTo(strCard);
//   index = compare(strGet, strCard);             ------------------------------换成这个判断的话又会出现如下图错误
    Serial.print(strGet);
    Serial.print("-----");
    Serial.print(strCard);
    Serial.println(index);
    if( 0 == index)
      return true;
    else if(index < 0)
      Serial.printf("small low = %ld, high = %ld\n", curLocation, high );
    else if(index > 0)
      Serial.printf("big low = %ld, high = %ld\n",low, curLocation);
      return cmpCard(low, curLocation, strCard);
  return false;
int compare(String str1, String str2)
  int length = 10;
  for(int j=0; j<length; j++)
    if(str1[j] > str2[j]) return 1;
    if(str1[j] < str2[j]) return -1;
  return 0;
[/code]
我开始以为是判断的问题,所以在别处自己写了一个简单的判断,去比较字符串的大小但是会出现如下问题:
代码跟SD卡里的txt都在附件里
这个算法写的还有问题,一些卡号遍历的时候会遍历不到,但是好像不会影响到我问的这些问题。
发表于 2014-8-15 19:23:17 | 显示全部楼层
会不会是因为内存占用太多导致的啊?
另外,还有一个思路是:校验卡号,就是你按照一定算法生成卡号
然后收到卡号之后只要简单的运算就能判断卡号是否合法而不必到txt中去查找,当然这样的方法
缺陷是:灵活度差,不能废除某些卡
发表于 2014-8-15 19:59:51 | 显示全部楼层
这句难道没有语法错误? 但至少应该偏离你的本意了
 楼主| 发表于 2014-8-16 10:09:32 | 显示全部楼层
这句难道没有语法错误 ...
没有错误啊,他只是一个输出格式,而后面的变量是我的每个字符串是10
 楼主| 发表于 2014-8-16 10:12:33 | 显示全部楼层
这句难道没有语法错误 ...
想过,这个原因,但是没有相应的判断使用资源的ide,我也无法肯定
 楼主| 发表于 2014-8-16 10:13:52 | 显示全部楼层
zoologist 发表于 2014-8-15 19:23
会不会是因为内存占用太多导致的啊?
想过,但不敢肯定啊而且这个工具没法调试啊
发表于 2014-8-17 12:28:59 | 显示全部楼层
这个应该没问题,哪怕计算checksum也是一种校验了
另外,你的问题搞定了么?
发表于 2014-8-17 13:03:57 | 显示全部楼层
我意思是少了个%.
Seccess low = ld -> Seccess low = %ld
 楼主| 发表于 2014-8-17 21:46:11 | 显示全部楼层
Lance 发表于 2014-8-17 13:03
我意思是少了个%.
这个程序中肯定改了,关键问题不是这个啊,看主要问题。
 楼主| 发表于 2014-8-17 21:46:28 | 显示全部楼层
另外,你的问题搞定了么?
还没,周末有事
GMT+8, 2026-7-27 14:22 , Processed in 0.036175 second(s), 21 queries .
