本来嘛,DS18B20是可以通过寄存器R0、R1调节精度的~~~
可哥们那c语言简直是0基础,一看到MOV啥的,那就1一个头2个大~~~
于是乎直接放弃,可750ms的时间真心伤不起啊~~~肿么办?
丧心病狂修改DallasTemperature.cpp
但凡涉及bit数字,的一律改为9,额差不多就这个样子:
- // This library is free software; you can redistribute it and/or
- // modify it under the terms of the GNU Lesser General Public
- // License as published by the Free Software Foundation; either
- // version 2.1 of the License, or (at your option) any later version.
- // Version 3.7.2 modified on Dec 6, 2011 to support Arduino 1.0
- // See Includes...
- // Modified by Jordan Hochenbaum
- #include "DallasTemperature.h"
- #if ARDUINO >= 100
- #include "Arduino.h"
- #else
- extern "C" {
- #include "WConstants.h"
- #endif
- DallasTemperature::DallasTemperature(OneWire* _oneWire)
- #if REQUIRESALARMS
- : _AlarmHandler(&defaultAlarmHandler)
- #endif
- _wire = _oneWire;
- devices = 0;
- parasite = false;
- bitResolution = 9;
- waitForConversion = true;
- checkForConversion = true;
- // initialise the bus
- void DallasTemperature::begin(void)
- DeviceAddress deviceAddress;
- _wire->reset_search();
- devices = 0; // Reset the number of devices when we enumerate wire devices
- while (_wire->search(deviceAddress))
- if (validAddress(deviceAddress))
- if (!parasite && readPowerSupply(deviceAddress)) parasite = true;
- ScratchPad scratchPad;
- readScratchPad(deviceAddress, scratchPad);
- bitResolution = max(bitResolution, getResolution(deviceAddress));
- devices++;
- // returns the number of devices found on the bus
- uint8_t DallasTemperature::getDeviceCount(void)
- return devices;
- // returns true if address is valid
- bool DallasTemperature::validAddress(const uint8_t* deviceAddress)
- return (_wire->crc8(deviceAddress, 7) == deviceAddress[7]);
- // finds an address at a given index on the bus
- // returns true if the device was found
- bool DallasTemperature::getAddress(uint8_t* deviceAddress, uint8_t index)
- uint8_t depth = 0;
- while (depth <= index && _wire->search(deviceAddress))
- if (depth == index && validAddress(deviceAddress)) return true;
- depth++;
- return false;
- // attempt to determine if the device at the given address is connected to the bus
- bool DallasTemperature::isConnected(const uint8_t* deviceAddress)
- return isConnected(deviceAddress, scratchPad);
- // also allows for updating the read scratchpad
- bool DallasTemperature::isConnected(const uint8_t* deviceAddress, uint8_t* scratchPad)
- return (_wire->crc8(scratchPad, 8) == scratchPad[SCRATCHPAD_CRC]);
- // read device's scratch pad
- void DallasTemperature::readScratchPad(const uint8_t* deviceAddress, uint8_t* scratchPad)
- // send the command
- _wire->reset();
- _wire->select(deviceAddress);
- _wire->write(READSCRATCH);
- // TODO => collect all comments & use simple loop
- // byte 0: temperature LSB
- // byte 1: temperature MSB
- // byte 2: high alarm temp
- // byte 3: low alarm temp
- // byte 4: DS18S20: store for crc
- // DS18B20 & DS1822: configuration register
- // byte 5: internal use & crc
- // byte 6: DS18S20: COUNT_REMAIN
- // DS18B20 & DS1822: store for crc
- // byte 7: DS18S20: COUNT_PER_C
- // byte 8: SCRATCHPAD_CRC
- // for(int i=0; i<9; i++)
- // scratchPad[i] = _wire->read();
- // read the response
- scratchPad[TEMP_LSB] = _wire->read();
- scratchPad[TEMP_MSB] = _wire->read();
- scratchPad[HIGH_ALARM_TEMP] = _wire->read();
- scratchPad[LOW_ALARM_TEMP] = _wire->read();
- // byte 4:
- // DS18S20: store for crc
- scratchPad[CONFIGURATION] = _wire->read();
- // byte 5:
- // internal use & crc
- scratchPad[INTERNAL_BYTE] = _wire->read();
- // byte 6:
- // DS18S20: COUNT_REMAIN
- scratchPad[COUNT_REMAIN] = _wire->read();
- // byte 7:
- // DS18S20: COUNT_PER_C
- scratchPad[COUNT_PER_C] = _wire->read();
- // byte 8:
- // SCTRACHPAD_CRC
- scratchPad[SCRATCHPAD_CRC] = _wire->read();
- _wire->reset();
- // writes device's scratch pad
- void DallasTemperature::writeScratchPad(const uint8_t* deviceAddress, const uint8_t* scratchPad)
- _wire->reset();
- _wire->write(WRITESCRATCH);
- _wire->write(scratchPad[HIGH_ALARM_TEMP]); // high alarm temp
- _wire->write(scratchPad[LOW_ALARM_TEMP]); // low alarm temp
- // DS1820 and DS18S20 have no configuration register
- if (deviceAddress[0] != DS18S20MODEL) _wire->write(scratchPad[CONFIGURATION]); // configuration
- _wire->reset();
- _wire->select(deviceAddress); //<--this line was missing
- // save the newly written values to eeprom
- _wire->write(COPYSCRATCH, parasite);
- if (parasite) delay(10); // 10ms delay
- _wire->reset();
- // reads the device's power requirements
- bool DallasTemperature::readPowerSupply(const uint8_t* deviceAddress)
- bool ret = false;
- _wire->reset();
- _wire->write(READPOWERSUPPLY);
- if (_wire->read_bit() == 0) ret = true;
- _wire->reset();
- return ret;
- // set resolution of all devices to 9, 10, 11, or 12 bits
- // if new resolution is out of range, it is constrained.
- void DallasTemperature::setResolution(uint8_t newResolution)
- bitResolution = constrain(newResolution, 9, 12);
- for (int i=0; i<devices; i++)
- getAddress(deviceAddress, i);
- setResolution(deviceAddress, bitResolution);
- // set resolution of a device to 9, 10, 11, or 12 bits
- // if new resolution is out of range, 9 bits is used.
- bool DallasTemperature::setResolution(const uint8_t* deviceAddress, uint8_t newResolution)
- if (isConnected(deviceAddress, scratchPad))
- // DS1820 and DS18S20 have no resolution configuration register
- switch (newResolution)
- case 12:
- scratchPad[CONFIGURATION] = TEMP_9_BIT;
- break;
- case 11:
- break;
- case 10:
- break;
- case 9:
- default:
- break;
- writeScratchPad(deviceAddress, scratchPad);
- return true; // new value set
- return false;
- // returns the global resolution
- uint8_t DallasTemperature::getResolution()
- return bitResolution;
- // returns the current resolution of the device, 9-12
- // returns 0 if device not found
- uint8_t DallasTemperature::getResolution(const uint8_t* deviceAddress)
- if (deviceAddress[0] == DS18S20MODEL) return 9;
- switch (scratchPad[CONFIGURATION])
- case TEMP_12_BIT:
- return 9;
- case TEMP_11_BIT:
- return 9;
- case TEMP_10_BIT:
- return 9;
- case TEMP_9_BIT:
- return 9;
- return 0;
- // sets the value of the waitForConversion flag
- // TRUE : function requestTemperature() etc returns when conversion is ready
- // FALSE: function requestTemperature() etc returns immediately (USE WITH CARE!!)
- // (1) programmer has to check if the needed delay has passed
- // (2) but the application can do meaningful things in that time
- void DallasTemperature::setWaitForConversion(bool flag)
- waitForConversion = flag;
- // gets the value of the waitForConversion flag
- bool DallasTemperature::getWaitForConversion()
- return waitForConversion;
- // sets the value of the checkForConversion flag
- // TRUE : function requestTemperature() etc will 'listen' to an IC to determine whether a conversion is complete
- // FALSE: function requestTemperature() etc will wait a set time (worst case scenario) for a conversion to complete
- void DallasTemperature::setCheckForConversion(bool flag)
- checkForConversion = flag;
- bool DallasTemperature::getCheckForConversion()
- return checkForConversion;
- bool DallasTemperature::isConversionAvailable(const uint8_t* deviceAddress)
- // Check if the clock has been raised indicating the conversion is complete
- return scratchPad[0];
- // sends command for all devices on the bus to perform a temperature conversion
- void DallasTemperature::requestTemperatures()
- _wire->reset();
- _wire->skip();
- _wire->write(STARTCONVO, parasite);
- // ASYNC mode?
- if (!waitForConversion) return;
- blockTillConversionComplete(bitResolution, NULL);
- // sends command for one device to perform a temperature by address
- // returns FALSE if device is disconnected
- // returns TRUE otherwise
- bool DallasTemperature::requestTemperaturesByAddress(const uint8_t* deviceAddress)
- _wire->reset();
- // check device
- if (!isConnected(deviceAddress, scratchPad)) return false;
- // ASYNC mode?
- if (!waitForConversion) return true;
- blockTillConversionComplete(getResolution(deviceAddress), deviceAddress);
- return true;
- // returns number of milliseconds to wait till conversion is complete (based on IC datasheet)
- int16_t DallasTemperature::millisToWaitForConversion(uint8_t bitResolution)
- switch (bitResolution)
- case 9:
- return 94;
- case 10:
- return 188;
- case 11:
- return 375;
- default:
- return 750;
- // Continue to check if the IC has responded with a temperature
- void DallasTemperature::blockTillConversionComplete(uint8_t bitResolution, const uint8_t* deviceAddress)
- int delms = millisToWaitForConversion(bitResolution);
- if (deviceAddress != NULL && checkForConversion && !parasite)
- unsigned long timend = millis() + delms;
- while(!isConversionAvailable(deviceAddress) && (millis() < timend));
- else
- delay(delms);
- // sends command for one device to perform a temp conversion by index
- bool DallasTemperature::requestTemperaturesByIndex(uint8_t deviceIndex)
- getAddress(deviceAddress, deviceIndex);
- return requestTemperaturesByAddress(deviceAddress);
- // Fetch temperature for device index
- float DallasTemperature::getTempCByIndex(uint8_t deviceIndex)
- if (!getAddress(deviceAddress, deviceIndex))
- return DEVICE_DISCONNECTED_C;
- return getTempC((uint8_t*)deviceAddress);
- float DallasTemperature::getTempFByIndex(uint8_t deviceIndex)
- return DEVICE_DISCONNECTED_F;
- return getTempF((uint8_t*)deviceAddress);
- // reads scratchpad and returns fixed-point temperature, scaling factor 2^-7
- int16_t DallasTemperature::calculateTemperature(const uint8_t* deviceAddress, uint8_t* scratchPad)
- int16_t fpTemperature =
- (((int16_t) scratchPad[TEMP_MSB]) << 11) |
- (((int16_t) scratchPad[TEMP_LSB]) << 3);
- DS1820 and DS18S20 have a 9-bit temperature register.
- Resolutions greater than 9-bit can be calculated using the data from
- the temperature, and COUNT REMAIN and COUNT PER °C registers in the
- scratchpad. The resolution of the calculation depends on the model.
- While the COUNT PER °C register is hard-wired to 16 (10h) in a
- DS18S20, it changes with temperature in DS1820.
- After reading the scratchpad, the TEMP_READ value is obtained by
- truncating the 0.5°C bit (bit 0) from the temperature data. The
- extended resolution temperature can then be calculated using the
- following equation:
- COUNT_PER_C - COUNT_REMAIN
- TEMPERATURE = TEMP_READ - 0.25 + --------------------------
- COUNT_PER_C
- Hagai Shatz simplified this to integer arithmetic for a 12 bits
- value for a DS18S20, and James Cameron added legacy DS1820 support.
- See - [url]http://myarduinotoy.blogspot.co.uk/2013/02/12bit-result-from-ds18s20.html[/url]
- fpTemperature = ((fpTemperature & 0xfff0) << 3) - 16 +
- ((scratchPad[COUNT_PER_C] - scratchPad[COUNT_REMAIN]) << 7) /
- return fpTemperature;
- // returns temperature in 1/128 degrees C or DEVICE_DISCONNECTED_RAW if the
- // device's scratch pad cannot be read successfully.
- // the numeric value of DEVICE_DISCONNECTED_RAW is defined in
- // DallasTemperature.h. It is a large negative number outside the
- // operating range of the device
- int16_t DallasTemperature::getTemp(const uint8_t* deviceAddress)
- if (isConnected(deviceAddress, scratchPad)) return calculateTemperature(deviceAddress, scratchPad);
- return DEVICE_DISCONNECTED_RAW;
- // returns temperature in degrees C or DEVICE_DISCONNECTED_C if the
- // the numeric value of DEVICE_DISCONNECTED_C is defined in
- float DallasTemperature::getTempC(const uint8_t* deviceAddress)
- return rawToCelsius(getTemp(deviceAddress));
- // returns temperature in degrees F or DEVICE_DISCONNECTED_F if the
- // the numeric value of DEVICE_DISCONNECTED_F is defined in
- float DallasTemperature::getTempF(const uint8_t* deviceAddress)
- return rawToFahrenheit(getTemp(deviceAddress));
- // returns true if the bus requires parasite power
- bool DallasTemperature::isParasitePowerMode(void)
- return parasite;
- ALARMS:
- TH and TL Register Format
- BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0
- S 2^6 2^5 2^4 2^3 2^2 2^1 2^0
- Only bits 11 through 4 of the temperature register are used
- in the TH and TL comparison since TH and TL are 8-bit
- registers. If the measured temperature is lower than or equal
- to TL or higher than or equal to TH, an alarm condition exists
- and an alarm flag is set inside the DS18B20. This flag is
- updated after every temperature measurement; therefore, if the
- alarm condition goes away, the flag will be turned off after
- the next temperature conversion.
- // sets the high alarm temperature for a device in degrees Celsius
- // accepts a float, but the alarm resolution will ignore anything
- // after a decimal point. valid range is -55C - 125C
- void DallasTemperature::setHighAlarmTemp(const uint8_t* deviceAddress, char celsius)
- // make sure the alarm temperature is within the device's range
- if (celsius > 125) celsius = 125;
- else if (celsius < -55) celsius = -55;
- scratchPad[HIGH_ALARM_TEMP] = (uint8_t)celsius;
- // sets the low alarm temperature for a device in degrees Celsius
- void DallasTemperature::setLowAlarmTemp(const uint8_t* deviceAddress, char celsius)
- scratchPad[LOW_ALARM_TEMP] = (uint8_t)celsius;
- // returns a char with the current high alarm temperature or
- // DEVICE_DISCONNECTED for an address
- char DallasTemperature::getHighAlarmTemp(const uint8_t* deviceAddress)
- if (isConnected(deviceAddress, scratchPad)) return (char)scratchPad[HIGH_ALARM_TEMP];
- // returns a char with the current low alarm temperature or
- char DallasTemperature::getLowAlarmTemp(const uint8_t* deviceAddress)
- if (isConnected(deviceAddress, scratchPad)) return (char)scratchPad[LOW_ALARM_TEMP];
- // resets internal variables used for the alarm search
- void DallasTemperature::resetAlarmSearch()
- alarmSearchJunction = -1;
- alarmSearchExhausted = 0;
- for(uint8_t i = 0; i < 7; i++)
- alarmSearchAddress[i] = 0;
- // This is a modified version of the OneWire::search method.
- // Also added the OneWire search fix documented here:
- // [url]http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238032295[/url]
- // Perform an alarm search. If this function returns a '1' then it has
- // enumerated the next device and you may retrieve the ROM from the
- // OneWire::address variable. If there are no devices, no further
- // devices, or something horrible happens in the middle of the
- // enumeration then a 0 is returned. If a new device is found then
- // its address is copied to newAddr. Use
- // DallasTemperature::resetAlarmSearch() to start over.
- bool DallasTemperature::alarmSearch(uint8_t* newAddr)
- uint8_t i;
- char lastJunction = -1;
- uint8_t done = 1;
- if (alarmSearchExhausted) return false;
- if (!_wire->reset()) return false;
- // send the alarm search command
- _wire->write(0xEC, 0);
- for(i = 0; i < 64; i++)
- uint8_t a = _wire->read_bit( );
- uint8_t nota = _wire->read_bit( );
- uint8_t ibyte = i / 8;
- uint8_t ibit = 1 << (i & 7);
- // I don't think this should happen, this means nothing responded, but maybe if
- // something vanishes during the search it will come up.
- if (a && nota) return false;
- if (!a && !nota)
- if (i == alarmSearchJunction)
- // this is our time to decide differently, we went zero last time, go one.
- a = 1;
- alarmSearchJunction = lastJunction;
- else if (i < alarmSearchJunction)
- // take whatever we took last time, look in address
- if (alarmSearchAddress[ibyte] & ibit) a = 1;
- else
- // Only 0s count as pending junctions, we've already exhausted the 0 side of 1s
- a = 0;
- done = 0;
- lastJunction = i;
- else
- // we are blazing new tree, take the 0
- a = 0;
- alarmSearchJunction = i;
- done = 0;
- // OneWire search fix
- // See: [url]http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238032295[/url]
- if (a) alarmSearchAddress[ibyte] |= ibit;
- else alarmSearchAddress[ibyte] &= ~ibit;
- _wire->write_bit(a);
- if (done) alarmSearchExhausted = 1;
- for (i = 0; i < 8; i++) newAddr[i] = alarmSearchAddress[i];
- return true;
- // returns true if device address might have an alarm condition
- // (only an alarm search can verify this)
- bool DallasTemperature::hasAlarm(const uint8_t* deviceAddress)
- char temp = calculateTemperature(deviceAddress, scratchPad) >> 7;
- // check low alarm
- if (temp <= (char)scratchPad[LOW_ALARM_TEMP]) return true;
- // check high alarm
- if (temp >= (char)scratchPad[HIGH_ALARM_TEMP]) return true;
- // no alarm
- return false;
- // returns true if any device is reporting an alarm condition on the bus
- bool DallasTemperature::hasAlarm(void)
- resetAlarmSearch();
- return alarmSearch(deviceAddress);
- // runs the alarm handler for all devices returned by alarmSearch()
- void DallasTemperature::processAlarms(void)
- DeviceAddress alarmAddr;
- while (alarmSearch(alarmAddr))
- if (validAddress(alarmAddr))
- _AlarmHandler(alarmAddr);
- // sets the alarm handler
- void DallasTemperature::setAlarmHandler(AlarmHandler *handler)
- _AlarmHandler = handler;
- // The default alarm handler
- void DallasTemperature::defaultAlarmHandler(const uint8_t* deviceAddress)
- #endif
- // Convert float Celsius to Fahrenheit
- float DallasTemperature::toFahrenheit(float celsius)
- return (celsius * 1.8) + 32;
- // Convert float Fahrenheit to Celsius
- float DallasTemperature::toCelsius(float fahrenheit)
- return (fahrenheit - 32) * 0.555555556;
- // convert from raw to Celsius
- float DallasTemperature::rawToCelsius(int16_t raw)
- if (raw <= DEVICE_DISCONNECTED_RAW)
- // C = RAW/128
- return (float)raw * 0.0078125;
- // convert from raw to Fahrenheit
- float DallasTemperature::rawToFahrenheit(int16_t raw)
- // C = RAW/128
- // F = (C*1.8)+32 = (RAW/128*1.8)+32 = (RAW*0.0140625)+32
- return ((float)raw * 0.0140625) + 32;
- #if REQUIRESNEW
- // MnetCS - Allocates memory for DallasTemperature. Allows us to instance a new object
- void* DallasTemperature::operator new(unsigned int size) // Implicit NSS obj size
- void * p; // void pointer
- p = malloc(size); // Allocate memory
- memset((DallasTemperature*)p,0,size); // Initialise memory
- //!!! CANT EXPLICITLY CALL CONSTRUCTOR - workaround by using an init() methodR - workaround by using an init() method
- return (DallasTemperature*) p; // Cast blank region to NSS pointer
- // MnetCS 2009 - Free the memory used by this instance
- void DallasTemperature::operator delete(void* p)
- DallasTemperature* pNss = (DallasTemperature*) p; // Cast to NSS pointer
- pNss->~DallasTemperature(); // Destruct the object
- free(p); // Free the memory
- #endif
于是乎,实际效果用代码检测:
- #include <OneWire.h>
- #include <DallasTemperature.h>
- // 数字接口10
- #define ONE_WIRE_BUS 10
- // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
- OneWire oneWire(ONE_WIRE_BUS);
- // Pass our oneWire reference to Dallas Temperature.
- DallasTemperature sensors(&oneWire);
- unsigned long time2;
- void setup(void)
- // start serial port
- Serial.begin(9600);
- Serial.println("Dallas Temperature IC Control Library Demo");
- // Start up the library
- sensors.begin(); // IC Default 9 bit. If you have troubles consider upping it 12. Ups the delay giving the IC more time to process the temperature measurement
- void loop(void)
- time2=millis();
- sensors.requestTemperatures(); // Send the command to get temperatures
- time2=millis()-time2;
- Serial.print("Temperature for Device 1 is: ");
- Serial.println(sensors.getTempCByIndex(0)); // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
- Serial.print("time2 is: ");
- Serial.println(time2); // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
- delay(1000);
