- #include <DHT.h>
- #include <SPI.h> // needed for Arduino versions later than 0018
- #include <Ethernet.h>
- #include <EthernetUdp.h> // UDP library from: [email][email protected][/email] 12/30/2008
- #include <SoftwareSerial.h>
- #define DHTPIN 2 // what pin we're connected to
- #define DHTTYPE DHT11 // DHT 11
- // Enter a MAC address and IP address for your controller below.
- // The IP address will be dependent on your local network:
- byte mac[] = {
- 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
- IPAddress ip(192, 168, 2, 177);
- unsigned int localPort = 8000; // local port to listen on
- // buffers for receiving and sending data
- char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
- char ReplyBuffer[UDP_TX_PACKET_MAX_SIZE]; // a string to send back
- char tempBuf[UDP_TX_PACKET_MAX_SIZE];
- // An EthernetUDP instance to let us send and receive packets over UDP
- EthernetUDP Udp;
- DHT dht(DHTPIN, DHTTYPE);
- //Infrared communation infomation
- byte InfrInitStart[]={0xAA,0xAA,0x08,0x08,0x00};
- byte InfrInitEnd[]={0xCC,0xCC,0x08,0x08,0x00};
- byte AirConVerion[]={0x02,0x00,0x2C,0x08,0x26};
- //fit the air condition type code 0x2C is 044 (meidi KFR-72LW)
- //if you want to control another air condition , you should change 0x2c
- byte AirConTrunOn[]={0x04,0xff,0x08,0x08,0xfb};
- byte AirConTurnOff[]={0x04,0x00,0x08,0x08,0x04};
- //use pin 6 as receivepin and use pin as transmitpin
- SoftwareSerial serial(6,7);
- void setup() {
- // start the Ethernet and UDP:
- Ethernet.begin(mac,ip);
- Udp.begin(localPort);
- dht.begin();
- Serial.begin(9600);
- serial.begin(9600);
- delay(1000);
- //Initialize the infrared mode start
- serial.write(InfrInitStart,5);
- if(checkRespondeCode())
- //Initialize the infread mode end
- serial.write(InfrInitEnd,5);
- else
- exit(0);
- //set the air condition mode version
- serial.write(AirConVerion,5);
- else
- exit(1);
- if(checkRespondeCode()==false)
- exit(2);
- boolean checkRespondeCode()
- byte RXData;
- delay(1000);
- //Serial.println("check response code");
- if(serial.available())
- delay(200);
- RXData=serial.read();
- //Serial.println(RXData,HEX);
- if(RXData==0x89)
- //serial.println();
- Serial.println("xiang ying 89");
- return true;
- else
- Serial.println(RXData,HEX);
- Serial.println("no xiang ying");
- return false;
- float getnum(char* strcmd)
- int i=0;
- char temp[100];
- for(i=3;i<strlen(strcmd);i++)
- temp[i-3]=strcmd[i];
- temp[i-3]='\0';
- return atof(temp);
- float getHumidity()
- float h = dht.readHumidity();
- if(isnan(h))
- return 0;
- return h;
- float getTemperature()
- float t = dht.readTemperature();
- if(isnan(t))
- return 0;
- return t;
- void loop() {
- float h=0.0,t=0.0;
- //float h = dht.readHumidity();
- //float t = dht.readTemperature();
- /* if (isnan(t) || isnan(h))
- Serial.println("Failed to read from DHT");
- else
- Serial.print("Humidity: ");
- Serial.print(h);
- Serial.print(" %\t");
- Serial.print("Temperature: ");
- Serial.print(t);
- Serial.println(" *C");
- // if there's data available, read a packet
- int packetSize = Udp.parsePacket();
- if(packetSize)
- Serial.print("Received packet of size ");
- Serial.println(packetSize);
- Serial.print("From ");
- IPAddress remote = Udp.remoteIP();
- for (int i =0; i < 4; i++)
- Serial.print(remote[i], DEC);
- if (i < 3)
- Serial.print(".");
- Serial.print(", port ");
- Serial.println(Udp.remotePort());
- // read the packet into packetBufffer
- Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
- switch(packetBuffer[0])
- case '0': //control
- switch(packetBuffer[1])
- case '0': //temperature and humility
- break;
- case '2': //air controler
- switch(packetBuffer[2])
- case '0':
- if(getnum(packetBuffer)==0.0)
- Serial.println("turn on the air condition");
- sprintf(ReplyBuffer,"turn on the air condition");
- serial.write(AirConTrunOn,5);
- Serial.println("0x04,0xff,0x08,0x08,0xfb");
- else if(getnum(packetBuffer)==1.0)
- Serial.println("turn off the air condition");
- sprintf(ReplyBuffer,"turn off the air condition");
- serial.write(AirConTurnOff,5);
- Serial.println("0x04,0x00,0x08,0x08,0x04");
- break;
- case '1':
- break;
- default:
- break;
- break;
- default:
- break;
- break;
- case '1': //informaiton
- case '1':
- h=getHumidity();
- dtostrf(h,10,2,tempBuf);
- sprintf(ReplyBuffer,"100humidity:%s",tempBuf);
- break;
- t=getTemperature();
- dtostrf(t,10,2,tempBuf);
- sprintf(ReplyBuffer,"100Temperature:%s",tempBuf);
- break;
- /*case : //humility
- float h=getHumidity();
- sprintf(ReplyBuffer,"101Humidity:%f\n",h);
- break;*/
- break;
- break;
- break;
- default:
- Serial.println("Error");
- Serial.println("Contents:");
- Serial.println(packetBuffer);
- memset(packetBuffer,'\0',UDP_TX_PACKET_MAX_SIZE);
- // send a reply, to the IP address and port that sent us the packet we received
- Serial.println(ReplyBuffer);
- Udp.beginPacket(Udp.remoteIP(),Udp.remotePort());
- Udp.write(ReplyBuffer);
- Udp.endPacket();
- delay(10);
[pre lang="python" line="1"]from socket import *
HOST="192.168.2.177"
PORT=8000
BUFSIZE=1024
ADDR=(HOST,PORT)
udpCliSock=socket(AF_INET,SOCK_DGRAM)
while True:
data=raw_input(">")
if not data:
break
udpCliSock.sendto(data,ADDR)
data,ADDR=udpCliSock.recvfrom(BUFSIZE)
if not data:
break
print data,ADDR
udpCliSock.close()
[/code]
说明:
输入100获取温度信息
输入101获取湿度信息
输入0200 打开空调
输入0201 关闭空调 |
