查看: 11459|回复: 0
为什么表示不懂有没有懂的为啥不能控制步进电机正反转
发表于 2014-9-21 19:23:02 | 显示全部楼层 |阅读模式
int Pin0 = 8;
int Pin1 = 9;
int Pin2 = 10;
int Pin3 = 11;
int _step = 0;
boolean dir = false;//正反转
int stepperSpeed = 3;//电机转速,1ms一步
  pinMode(Pin0, OUTPUT);
  pinMode(Pin1, OUTPUT);
  pinMode(Pin2, OUTPUT);
  pinMode(Pin3, OUTPUT);
  int M =analogRead(A0);
  Serial.println(M);
    if (M <500 )
  boolean dir = true;
    boolean dir =false;
  switch(_step){
    case 0:
      digitalWrite(Pin0, LOW);
      digitalWrite(Pin1, LOW);
      digitalWrite(Pin2, LOW);
      digitalWrite(Pin3, HIGH);
    case 1:
      digitalWrite(Pin2, HIGH);
    case 2:
      digitalWrite(Pin3, LOW);
    case 3:
      digitalWrite(Pin1, HIGH);
    case 4:
    case 5:
      digitalWrite(Pin0, HIGH);
      case 6:
    case 7:
    default:
  if(dir){
    _step++;
  }else{
    _step--;
  if(_step>7){
    _step=0;
  if(_step<0){
    _step=7;
  delay(stepperSpeed);
传感器我用的是土壤湿度传感器
GMT+8, 2026-6-15 17:25 , Processed in 0.063174 second(s), 18 queries .
