查看: 11895|回复: 9
求助 mpu6050 dmp
发表于 2014-10-29 14:43:39 | 显示全部楼层 |阅读模式
[url=陀螺仪加速度计 MPU6050 启用DMP运算角度代码 http://www.geek-workshop.com/thread-6126-1-1.html]
我用上面这个程序为什么编译不过1.0.6版本{:soso_e103:}
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include "Wire.h"
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
MPU6050 mpu(0x68);
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
// ===               INTERRUPT DETECTION ROUTINE                ===
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
  mpuInterrupt = true;
// ===                      INITIAL SETUP                       ===
void mpu_setup() {
  //Serial.begin(115200);        // opens serial port, sets data rate to 9600 bps
  // join I2C bus (I2Cdev library doesn't do this automatically)
  Wire.begin();
  // initialize device
  Serial.println("Initializing I2C devices...");
  mpu.initialize();
  // verify connection
  Serial.println(mpu.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
  delay(2);
  // load and configure the DMP
  Serial.println("Initializing DMP...");
  devStatus = mpu.dmpInitialize();
  // make sure it worked (returns 0 if so)
  if (devStatus == 0) {
    // turn on the DMP, now that it's ready
    Serial.println("Enabling DMP...");
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
    Serial.println("Enabling interrupt detection (Arduino external interrupt 0)...");
    attachInterrupt(0, dmpDataReady, RISING);
    mpuIntStatus = mpu.getIntStatus();
    // set our DMP Ready flag so the main loop() function knows it's okay to use it
    Serial.println("DMP ready! Waiting for first interrupt...");
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
  else {
    // ERROR!
    // 1 = initial memory load failed
    // 2 = DMP configuration updates failed
    // (if it's going to break, usually the code will be 1)
    Serial.print("DMP Initialization failed (code ");
    Serial.print(devStatus);
    Serial.println(")");
void mpu_loop()
  float alpha,omiga;
  // if programming failed, don't try to do anything
  if (!dmpReady)
    return;
  // wait for MPU interrupt or extra packet(s) available
  if (!mpuInterrupt && fifoCount < packetSize)
    return;
  // reset interrupt flag and get INT_STATUS byte
  // get current FIFO count
  fifoCount = mpu.getFIFOCount();
  // check for overflow (this should never happen unless our code is too inefficient)
  if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
    // reset so we can continue cleanly
    mpu.resetFIFO();
    Serial.println("FIFO overflow!");
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
  else if (mpuIntStatus & 0x02) {
    // wait for correct available data length, should be a VERY short wait
    while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
    // read a packet from FIFO
    mpu.getFIFOBytes(fifoBuffer, packetSize);
    // track FIFO count here in case there is > 1 packet available
    // (this lets us immediately read more without waiting for an interrupt)
    fifoCount -= packetSize;
    mpu.dmpGetQuaternion(&q, fifoBuffer);
    mpu.dmpGetGravity(&gravity, &q);
    mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);  //从DMP中取出Yaw、Pitch、Roll三个轴的角度,放入数组ypr。单位:弧度
    alpha=-ypr[2] * 180/M_PI;
    omiga=mpu.getRotationX()/16.4;        //配置是16位表示正负2000°/s, 65536/4000
    Serial.print("Alpha ");
    Serial.print(alpha);//x轴平行偏移角度
    Serial.print("\tOmiga ");
    Serial.println(omiga);//对应加速度力道
错误为Arduino: 1.0.6 (Windows 7), Board: "Arduino Nano w/ ATmega328"
D:\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -ID:\Arduino\hardware\arduino\cores\arduino -ID:\Arduino\hardware\arduino\variants\eightanaloginputs -ID:\Arduino\libraries\Wire -ID:\Arduino\libraries\I2Cdev -ID:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h C:\Users\ADMINI~1\AppData\Local\Temp\build5691815205658356843.tmp\sketch_oct29a.cpp -o C:\Users\ADMINI~1\AppData\Local\Temp\build5691815205658356843.tmp\sketch_oct29a.cpp.o
In file included from sketch_oct29a.ino:9:
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:37:27: error: helper_3dmath.h: No such file or directory
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:42:21: error: MPU6050.h: No such file or directory
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:89: warning: only initialized variables can be placed into program memory area
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:229: warning: only initialized variables can be placed into program memory area
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:271: warning: only initialized variables can be placed into program memory area
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:281: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h: In function 'uint8_t dmpInitialize()':
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:284: error: 'reset' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:295: error: 'setSleepEnabled' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:299: error: 'setMemoryBank' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:301: error: 'setMemoryStartAddress' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:303: error: 'readMemoryByte' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:311: error: 'getOTPBankValid' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:317: error: 'getXGyroOffset' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:318: error: 'getYGyroOffset' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:319: error: 'getZGyroOffset' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:329: error: 'setSlaveAddress' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:331: error: 'setI2CMasterModeEnabled' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:335: error: 'resetI2CMaster' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:342: error: 'writeProgMemoryBlock' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:349: error: 'writeProgDMPConfigurationSet' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:353: error: 'MPU6050_CLOCK_PLL_ZGYRO' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:353: error: 'setClockSource' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:356: error: 'setIntEnabled' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:359: error: 'setRate' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:362: error: 'MPU6050_EXT_SYNC_TEMP_OUT_L' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:362: error: 'setExternalFrameSync' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:365: error: 'MPU6050_DLPF_BW_42' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:365: error: 'setDLPFMode' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:368: error: 'MPU6050_GYRO_FS_2000' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:368: error: 'setFullScaleGyroRange' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:371: error: 'setDMPConfig1' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:372: error: 'setDMPConfig2' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:375: error: 'setOTPBankValid' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:378: error: 'setXGyroOffset' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:379: error: 'setYGyroOffset' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:380: error: 'setZGyroOffset' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:383: error: 'setXGyroOffsetUser' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:384: error: 'setYGyroOffsetUser' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:385: error: 'setZGyroOffsetUser' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:391: error: 'writeMemoryBlock' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:398: error: 'resetFIFO' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:401: error: 'getFIFOCount' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:406: error: 'getFIFOBytes' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:409: error: 'setMotionDetectionThreshold' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:412: error: 'setZeroMotionDetectionThreshold' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:415: error: 'setMotionDetectionDuration' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:418: error: 'setZeroMotionDetectionDuration' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:424: error: 'setFIFOEnabled' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:427: error: 'setDMPEnabled' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:430: error: 'resetDMP' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:453: error: 'getIntStatus' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:460: error: 'readMemoryBlock' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:487: error: 'dmpPacketSize' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:303: warning: unused variable 'hwRevision'
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:311: warning: unused variable 'otpValid'
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h: At global scope:
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:506: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h: In function 'bool dmpPacketAvailable()':
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:507: error: 'getFIFOCount' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:507: error: 'dmpGetFIFOPacketSize' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:533: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h: In function 'uint8_t dmpGetAccel(int32_t*, const uint8_t*)':
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:535: error: 'dmpPacketBuffer' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:536: warning: left shift count >= width of type
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:537: warning: left shift count >= width of type
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:538: warning: left shift count >= width of type
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:541: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h: In function 'uint8_t dmpGetAccel(int16_t*, const uint8_t*)':
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:543: error: 'dmpPacketBuffer' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:549: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:549: error: 'uint8_t dmpGetAccel' redeclared as different kind of symbol
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:541: error: previous declaration of 'uint8_t dmpGetAccel(int16_t*, const uint8_t*)'
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:549: error: 'VectorInt16' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:549: error: 'v' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:549: error: expected primary-expression before 'const'
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:557: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h: In function 'uint8_t dmpGetQuaternion(int32_t*, const uint8_t*)':
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:559: error: 'dmpPacketBuffer' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:560: warning: left shift count >= width of type
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:561: warning: left shift count >= width of type
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:562: warning: left shift count >= width of type
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:563: warning: left shift count >= width of type
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:566: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h: In function 'uint8_t dmpGetQuaternion(int16_t*, const uint8_t*)':
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:568: error: 'dmpPacketBuffer' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:575: error: 'MPU6050' has not been declared
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:575: error: 'uint8_t dmpGetQuaternion' redeclared as different kind of symbol
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:566: error: previous declaration of 'uint8_t dmpGetQuaternion(int16_t*, const uint8_t*)'
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:575: error: 'Quaternion' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:575: error: 'q' was not declared in this scope
D:\Arduino\libraries\MPU6050_6Axis_MotionApps20.h/MPU6050_6Axis_MotionApps20.h:575: error: expected primary-expression before 'const'
求大神解释
发表于 2014-11-4 21:30:25 | 显示全部楼层
换个头文件
发表于 2014-12-3 15:28:21 | 显示全部楼层
遇到同样问题·················
 楼主| 发表于 2014-12-3 20:27:34 | 显示全部楼层
我现在已经改好了
发表于 2015-2-3 13:22:03 | 显示全部楼层
Albert,_Einste 发表于 2014-12-3 20:27
我现在已经改好了
楼主,你好,请问你是怎么用DMP的,我现在也在用6050,能不能指导下,方便加QQ1343662647吗?或者我加您也行
 楼主| 发表于 2015-2-3 18:18:58 | 显示全部楼层
满地落叶 发表于 2015-2-3 13:22
楼主,你好,请问你是怎么用DMP的,我现在也在用6050,能不能指导下,方便加QQ1343662647吗?或者我加您也 ...
我也不怎么会。。。
发表于 2015-2-3 22:31:44 | 显示全部楼层
Albert,_Einste 发表于 2015-2-3 18:18
我也不怎么会。。。
你有经验嘛,交流交流下
发表于 2015-2-4 13:16:03 | 显示全部楼层
我也不怎么会。。。
您QQ多少呢
发表于 2015-5-16 00:02:40 | 显示全部楼层
你们怎么解决的 ?
 楼主| 发表于 2015-5-16 19:58:28 | 显示全部楼层
4261400 发表于 2015-5-16 00:02
你们怎么解决的 ?
更新库文件
GMT+8, 2026-6-17 22:41 , Processed in 0.039798 second(s), 23 queries .
