查看: 12494|回复: 2
有关2相PM电机控制的紧急问题
发表于 2014-11-26 16:48:11 | 显示全部楼层 |阅读模式
arduino库里的steper库可以驱动4相5线混合式步进电机,但是驱动不了2相4线永磁式步进电机,请问是步进电机库不支持吗?但是我看库里面有2线和4线的,这是什么意思。还是永磁式和混合式的控制方式不同。求大神指导!!!
Drives a unipolar or bipolar stepper motor using  2 wires or 4 wires
  When wiring multiple stepper motors to a microcontroller,
  you quickly run out of output pins, with each motor requiring 4 connections.
  By making use of the fact that at any time two of the four motor
  coils are the inverse  of the other two, the number of
  control connections can be reduced from 4 to 2.
  A slightly modified circuit around a Darlington transistor array or an L293 H-bridge
  connects to only 2 microcontroler pins, inverts the signals received,
  and delivers the 4 (2 plus 2 inverted ones) output signals required
  for driving a stepper motor.
  The sequence of control signals for 4 control wires is as follows:
  Step C0 C1 C2 C3
     1  1  0  1  0
     2  0  1  1  0
     3  0  1  0  1
     4  1  0  0  1
  The sequence of controls signals for 2 control wires is as follows
  (columns C1 and C2 from above):
  Step C0 C1
     1  0  1
     2  1  1
     3  1  0
     4  0  0
  The circuits can be found at
http://www.arduino.cc/en/Tutorial/Stepper
#include "Arduino.h"
#include "Stepper.h"
* two-wire constructor.
* Sets which wires should control the motor.
Stepper::Stepper(int number_of_steps, int motor_pin_1, int motor_pin_2)
  this->step_number = 0;      // which step the motor is on
  this->speed = 0;        // the motor speed, in revolutions per minute
  this->direction = 0;      // motor direction
  this->last_step_time = 0;    // time stamp in ms of the last step taken
  this->number_of_steps = number_of_steps;    // total number of steps for this motor
  // Arduino pins for the motor control connection:
  this->motor_pin_1 = motor_pin_1;
  this->motor_pin_2 = motor_pin_2;
  // setup the pins on the microcontroller:
  pinMode(this->motor_pin_1, OUTPUT);
  pinMode(this->motor_pin_2, OUTPUT);
  // When there are only 2 pins, set the other two to 0:
  this->motor_pin_3 = 0;
  this->motor_pin_4 = 0;
  // pin_count is used by the stepMotor() method:
  this->pin_count = 2;
*   constructor for four-pin version
Stepper::Stepper(int number_of_steps, int motor_pin_1, int motor_pin_2, int motor_pin_3, int motor_pin_4)
  this->motor_pin_3 = motor_pin_3;
  this->motor_pin_4 = motor_pin_4;
  pinMode(this->motor_pin_3, OUTPUT);
  pinMode(this->motor_pin_4, OUTPUT);
  this->pin_count = 4;
  Sets the speed in revs per minute
void Stepper::setSpeed(long whatSpeed)
  this->step_delay = 60L * 1000L / this->number_of_steps / whatSpeed;
  Moves the motor steps_to_move steps.  If the number is negative,
   the motor moves in the reverse direction.
void Stepper::step(int steps_to_move)
  int steps_left = abs(steps_to_move);  // how many steps to take
  // determine direction based on whether steps_to_mode is + or -:
  if (steps_to_move > 0) {this->direction = 1;}
  if (steps_to_move < 0) {this->direction = 0;}
  // decrement the number of steps, moving one step each time:
  while(steps_left > 0) {
  // move only if the appropriate delay has passed:
  if (millis() - this->last_step_time >= this->step_delay) {
      // get the timeStamp of when you stepped:
      this->last_step_time = millis();
      // increment or decrement the step number,
      // depending on direction:
      if (this->direction == 1) {
        this->step_number++;
        if (this->step_number == this->number_of_steps) {
      else {
        if (this->step_number == 0) {
          this->step_number = this->number_of_steps;
        this->step_number--;
      // decrement the steps left:
      steps_left--;
      // step the motor to step number 0, 1, 2, or 3:
      stepMotor(this->step_number % 4);
* Moves the motor forward or backwards.
void Stepper::stepMotor(int thisStep)
  if (this->pin_count == 2) {
    switch (thisStep) {
      case 0: /* 01 */
      digitalWrite(motor_pin_1, LOW);
      digitalWrite(motor_pin_2, HIGH);
      case 1: /* 11 */
      digitalWrite(motor_pin_1, HIGH);
      case 2: /* 10 */
      digitalWrite(motor_pin_2, LOW);
      case 3: /* 00 */
  if (this->pin_count == 4) {
    switch (thisStep) {
      case 0:    // 1010
      digitalWrite(motor_pin_3, HIGH);
      digitalWrite(motor_pin_4, LOW);
      case 1:    // 0110
      case 2:    //0101
      digitalWrite(motor_pin_3, LOW);
      digitalWrite(motor_pin_4, HIGH);
      case 3:    //1001
  version() returns the version of the library:
int Stepper::version(void)
  return 4;
发表于 2014-11-26 17:35:40 | 显示全部楼层
你用的两相电机可能和库指的电机不同,我手上的的4相5线电机是8步的,不是库里的4步,你可以自己先测试步进电机的步序
 楼主| 发表于 2014-11-28 13:56:41 | 显示全部楼层
西红柿炒番茄lo 发表于 2014-11-26 17:35
你用的两相电机可能和库指的电机不同,我手上的的4相5线电机是8步的,不是库里的4步,你可以自己先测试步进 ...
2相的只有4步吧,应该只有4相的才有8步。我的电机就算是例程程序也没反应,很郁闷
GMT+8, 2026-7-27 01:29 , Processed in 0.035342 second(s), 19 queries .
