查看: 6873|回复: 14
一个最简单的舵机代码,为什么出现这样的错误呢,,急急急
发表于 2014-12-16 08:40:30 | 显示全部楼层 |阅读模式
这是我的代码
这是出现的错误界面
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Error repainting line range {0,17}:
java.lang.ArrayIndexOutOfBoundsException: 69
        at processing.app.syntax.SyntaxUtilities.paintSyntaxLine(SyntaxUtilities.java:151)
        at processing.app.syntax.TextAreaPainter.paintSyntaxLine(TextAreaPainter.java:647)
        at processing.app.syntax.TextAreaPainter.paintLine(TextAreaPainter.java:606)
        at processing.app.syntax.TextAreaPainter.paint(TextAreaPainter.java:415)
        at javax.swing.JComponent.paintChildren(JComponent.java:864)
        at javax.swing.JComponent.paint(JComponent.java:1038)
        at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1030)
        at javax.swing.JComponent.paintToOffscreen(JComponent.java:5124)
        at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1475)
        at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1406)
        at javax.swing.RepaintManager.paint(RepaintManager.java:1220)
        at javax.swing.JComponent._paintImmediately(JComponent.java:5072)
        at javax.swing.JComponent.paintImmediately(JComponent.java:4882)
        at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:803)
        at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
        at javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:694)
        at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:128)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
Error repainting line range {0,16}:
IDE错误提醒粘上
请兄弟们帮忙看下,,,急求急求
 楼主| 发表于 2014-12-16 08:41:36 | 显示全部楼层
以前从来没出现过这种情况,,
发表于 2014-12-16 09:07:25 | 显示全部楼层
這個看來不像是sketch 的問題, 嘗試 compile BareMinimum 看看是否有同樣的錯誤.
如果同樣出錯, 就應該是 Arduino IDE 出了問題, 又或者 JVM 有問題了.  可以嘗試重裝一次看看.
 楼主| 发表于 2014-12-16 09:32:58 | 显示全部楼层
如果同樣出錯, 就應該是  ...
但是编译其他的都没问题,就这一个代码有问题
发表于 2014-12-16 10:18:38 | 显示全部楼层
那麼, 你 compile IDE 的 example: Knob 以及 Sweep 會有問題嗎?
发表于 2014-12-16 10:20:44 | 显示全部楼层
如果 compile Knob 及 Sweep 都沒問題, 就有可能是你的程式中包含了一些特殊字符, 令編譯時產生錯誤.
发表于 2014-12-16 12:57:10 | 显示全部楼层
UNO 有22管脚么?
 楼主| 发表于 2014-12-17 10:29:52 | 显示全部楼层
i7456 发表于 2014-12-16 12:57
UNO 有22管脚么?
不是UNO,是MEGA
 楼主| 发表于 2014-12-17 10:31:19 | 显示全部楼层
每一行代码都查看了,,,为啥就是找不到呢?
发表于 2014-12-17 11:33:57 | 显示全部楼层
單看圖片很難判斷, 把你的程式用附件方式放上來給我們試試吧.
发表于 2014-12-17 23:18:33 | 显示全部楼层
业余小玩家 发表于 2014-12-17 10:29
不是UNO,是MEGA
从你楼主位的图片看,你板子类型选的是UNO。
换成MEGA后看看编译还有错误不。
发表于 2014-12-18 13:03:21 | 显示全部楼层
代码一行一行的剪切掉编译测试,找到异常字符出现在那里,然后把出问题的一行拷贝到记事本再拷贝回去。
 楼主| 发表于 2014-12-19 16:40:46 | 显示全部楼层
????不明白
发表于 2014-12-19 17:05:34 | 显示全部楼层
业余小玩家 发表于 2014-12-19 16:40
????不明白
就是先用你的 IDE 去 compile  Servo 範例中的 Knob 及 Sweep 看看是否有問題.
另外, 樓上說的也是, 你的是 Mega 板, 但 IDE 中選了 UNO, 不知會否有影響.  先把板子選好了再試.
 楼主| 发表于 2014-12-19 17:12:34 | 显示全部楼层
板子我已经调过了,,,不行啊{:soso_e101:}
GMT+8, 2026-7-28 07:10 , Processed in 0.100997 second(s), 21 queries .
