查看: 11094|回复: 2
求助:uno的I2C设置
发表于 2014-12-22 22:20:04 | 显示全部楼层 |阅读模式
我看到wire库的应用,先要begin带一个地址,然后发送数据或者命令,然后end,结束。
但是如果没有I2C的地址怎么处理呢? 比如下面这个时序,应该怎么实现呢?
谢谢。这是TM1650 四位数码管显示的应用。
 楼主| 发表于 2014-12-22 22:23:59 | 显示全部楼层
附件是C代码和datasheet。
 楼主| 发表于 2014-12-28 15:06:40 | 显示全部楼层
求助贴刷新、。
为啥一个器件刷出来8个地址
I2C Scanner
Scanning...
I2C device found at address 0x24  !
I2C device found at address 0x25  !
I2C device found at address 0x26  !
I2C device found at address 0x27  !
I2C device found at address 0x34  !
I2C device found at address 0x35  !
I2C device found at address 0x36  !
I2C device found at address 0x37  !
done
GMT+8, 2026-6-16 22:31 , Processed in 0.039133 second(s), 19 queries .
