查看: 10499|回复: 0
做一个两个舵机的小云台,只能减不能增加
发表于 2015-1-9 19:44:10 | 显示全部楼层 |阅读模式
先上程序……
#include <Servo.h>
Servo servo1;
Servo servo2;
int a,b;
int m,n;
int pos1 = 90;
int pos2 = 90;
  servo1.attach(3);
  servo2.attach(4);
  Serial.begin(9600); //波特率为9600bps
  servo1.write(pos1);
  servo2.write(pos2);
a = analogRead(2);  //521
b = analogRead(5);   //503
digitalWrite(13,LOW);
m = compute(a);
n = compute(b);
pos1 = pos1 + m;
pos2 = pos2 + n;
if(pos1 >= 180)
  pos1 = 180;
if(pos1 < 0)
  pos1 = 0;
if(pos2 >= 180)
  pos2 = 180;
if(pos2 < 0)
  pos2 = 0;
  servo1.write(pos1);
  servo2.write(pos2);
  Serial.print(a);
  Serial.print(" , ");
  Serial.println(b);
  delay(1000);
int compute( int input)
  int k;
if(input > 600)
   k = ( input - 500 )/100;
if(input < 400)
   k =( input - 500 )/100;
   k = 0;
return k;
下面的子函数输出值只有负值是怎么回事呀,数据类型错了吗?
GMT+8, 2026-6-17 11:02 , Processed in 0.064108 second(s), 17 queries .
