查看: 10869|回复: 0
帮忙看一下这段程序,有什么问题
发表于 2015-1-15 09:06:26 | 显示全部楼层 |阅读模式
* Auto-Generated by NUKE!
*   http://arbotix.googlecode.com
#include <ax12.h>
#include <BioloidController.h>
#include <Commander.h>
#include "nuke.h"
// Define one or the other depending upon which servo type you are using.
#define AX12_HEXAPOD
//#define AX18_HEXAPOD
Commander command = Commander();
int multiplier;
int id;
#define LEG_COUNT  6
#define RIPPLE_SPEED    1
#define AMBLE_SPEED     3
#define TRIPOD_SPEED    5
/*Servo IDs */               /定义每条腿的关节舵机id/
#define RM_TIBIA 18
#define RF_COXA 2
#define LR_TIBIA 11
#define LF_FEMUR 3
#define RF_TIBIA 6
#define RM_FEMUR 16
#define RM_COXA 14
#define RR_COXA 8
#define LF_TIBIA 5
#define LF_COXA 1
#define LR_FEMUR 9
#define RR_FEMUR 10
#define LM_TIBIA 17
#define RF_FEMUR 4
#define LM_FEMUR 15
#define RR_TIBIA 12
#define LM_COXA 13
#define LR_COXA 7
/* Actual positions, and indices of array. */
extern ik_req_t endpoints[LEG_COUNT];
#define RIGHT_FRONT    0
#define RIGHT_REAR     1
#define LEFT_FRONT     2
#define LEFT_REAR      3
#define RIGHT_MIDDLE   4
#define LEFT_MIDDLE    5
#ifdef AX12_HEXAPOD
#define TOP_SPEED      10
#endif
void setup(){
  pinMode(0,OUTPUT);
  // setup IK
  setupIK();
  gaitSelect(AMBLE_SMOOTH);
  // setup serial
  Serial.begin(38400);
// stand up slowly
  bioloid.poseSize = 18;
  bioloid.readPose();
  doIK();
  bioloid.interpolateSetup(1000);
  while(bioloid.interpolating > 0)
    bioloid.interpolateStep();
    delay(3);
  multiplier = AMBLE_SPEED;
  // take commands
   if(command.buttons&BUT_L4)              / /如果按下L4,选择左前腿//
      LEFT_FRONT;
      multiplier=AMBLE_SPEED;
          Serial.println("####################");
          Serial.println("Initializing Left_FRONTLeg Tests");
           delay(500);
     if((command.walkV) > 5 );                      //左前腿向前移动100mm//
         endpoints[LEFT_FRONT].x = endpoints[LEFT_FRONT].x+10;
       endpoints[LEFT_FRONT].y = -118;
       endpoints[LEFT_FRONT].z = 97;
         bioloid.poseSize = 3;
       bioloid.readPose();
       doIK();
         delay(3);
      if((command.walkV < -5) );         //左前腿向后移动100mm//
         endpoints[LEFT_FRONT].x = endpoints[LEFT_FRONT].x -10;
       bioloid.readPose();
       doIK();
         delay(3);
      if((command.walkH) > 5 );                        //左前腿向左移动100mm//
         endpoints[LEFT_FRONT].x = 52;
         endpoints[LEFT_FRONT].y = endpoints[LEFT_FRONT].y +10;
         bioloid.readPose();
       doIK();
         delay(3);
      if((command.walkH < -5) );                           //左前腿向右移动100mm//
                  endpoints[LEFT_FRONT].y = endpoints[LEFT_FRONT].y -10;
       bioloid.readPose();
       doIK();
         delay(3);
      if((command.lookH) > 5 );                               //左前腿抬高移动50mm//
           endpoints[LEFT_FRONT].z = endpoints[LEFT_FRONT].z -50;
       bioloid.readPose();
       doIK();
         delay(3);
      if((command.lookH < -5) );                              //左前腿降低移动50mm//
                  endpoints[LEFT_FRONT].z = endpoints[LEFT_FRONT].z+50;
       bioloid.readPose();
       doIK();
         delay(3);
GMT+8, 2026-7-28 05:11 , Processed in 0.033994 second(s), 17 queries .
